My configuration is openHAB 2.4.0~M4-1, Squeezebox Server installed on piCorePlayer + 2 players which works fine but only for 1-3 days.Then I’m getting " no connection to squeeze server when trying to send command, returning…"
Restarting bundle helps but is not a solution.
Below is debug log.
2018-10-20 17:08:00.560 [INFO ] [.eclipse.smarthome.model.script.Info] - Entrance door lock status is now: OFF for 6 minutes
2018-10-20 17:08:00.612 [INFO ] [.eclipse.smarthome.model.script.Info] - Playing: doorlock_keptunlocked.mp3
2018-10-20 17:08:00.618 [INFO ] [.eclipse.smarthome.model.script.Info] - Playing: doorlock_keptunlocked.mp3
2018-10-20 17:08:00.629 [DEBUG] [eezebox.internal.SqueezeBoxAudioSink] - Processing audioStream http://192.168.1.181:8080/audio/e85a907c-c2a3-4cb3-834a-d639d1495259.mp3 of format AudioFormat [codec=MP3, container=NONE, ]
2018-10-20 17:08:00.638 [DEBUG] [eezebox.internal.SqueezeBoxAudioSink] - Processing audioStream http://192.168.1.181:8080/audio/d9f85dc6-4e04-4fb0-a3c5-6e8ef417f6dc.mp3 of format AudioFormat [codec=MP3, container=NONE, ]
2018-10-20 17:08:00.641 [DEBUG] [ebox.handler.SqueezeBoxPlayerHandler] - Play notification sound on player b8:27:eb:0f:fa:a9 at URI http://192.168.1.181:8080/audio/d9f85dc6-4e04-4fb0-a3c5-6e8ef417f6dc.mp3
2018-10-20 17:08:00.640 [DEBUG] [ebox.handler.SqueezeBoxPlayerHandler] - Play notification sound on player b8:27:eb:e2:3a:a3 at URI http://192.168.1.181:8080/audio/e85a907c-c2a3-4cb3-834a-d639d1495259.mp3
2018-10-20 17:08:00.660 [DEBUG] [ezebox.handler.SqueezeBoxPlayerState] - Cur State: vol=50, mut=NOT MUTED, pwr=ON, stp=NOT STOPPED, ctl=PLAYING, shf=OFF, rpt=OFF, tix=0, tnm=1, tim=56
2018-10-20 17:08:00.665 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Setting up player for notification
2018-10-20 17:08:00.673 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:e2:3a:a3 stop
2018-10-20 17:08:00.692 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Adding notification message to playlist
2018-10-20 17:08:00.652 [DEBUG] [ezebox.handler.SqueezeBoxPlayerState] - Cur State: vol=80, mut=NOT MUTED, pwr=ON, stp=STOPPED, ctl=PAUSED, shf=OFF, rpt=OFF, tix=0, tnm=0, tim=0
2018-10-20 17:08:00.700 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Setting up player for notification
2018-10-20 17:08:00.702 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Adding notification message to playlist
2018-10-20 17:08:00.703 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:e2:3a:a3 playlist add http://192.168.1.181:8080/audio/e85a907c-c2a3-4cb3-834a-d639d1495259.mp3 Notification
2018-10-20 17:08:00.716 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:0f:fa:a9 playlist add http://192.168.1.181:8080/audio/d9f85dc6-4e04-4fb0-a3c5-6e8ef417f6dc.mp3 Notification
2018-10-20 17:08:00.720 [INFO ] [.eclipse.smarthome.model.script.Info] - Sending telegram to bot1: :info: Drzwi wejściowe odblokowane od 6 minut. Zamknij: https://goo.gl/hSyEyB
2018-10-20 17:08:00.863 [INFO ] [.eclipse.smarthome.model.script.Info] - Sending telegram to bot2: :info: Drzwi wejściowe odblokowane od 6 minut. Zamknij: https://goo.gl/hSyEyB
2018-10-20 17:08:01.250 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Playlist updated
2018-10-20 17:08:01.255 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Playing notification
2018-10-20 17:08:01.252 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Playlist updated
2018-10-20 17:08:01.259 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Playing notification
2018-10-20 17:08:01.262 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:0f:fa:a9 playlist index 0
2018-10-20 17:08:01.268 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:e2:3a:a3 playlist index 1
2018-10-20 17:08:02.781 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Restoring player state
2018-10-20 17:08:02.785 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:0f:fa:a9 mixer volume 0
2018-10-20 17:08:02.789 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Removing notification message from playlist
2018-10-20 17:08:02.797 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:0f:fa:a9 playlist delete 0
2018-10-20 17:08:02.841 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Restoring player state
2018-10-20 17:08:02.844 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:e2:3a:a3 mixer volume 0
2018-10-20 17:08:02.848 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Removing notification message from playlist
2018-10-20 17:08:02.854 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:e2:3a:a3 playlist delete 1
2018-10-20 17:08:03.203 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Playlist updated
2018-10-20 17:08:03.206 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:0f:fa:a9 playlist index 0
2018-10-20 17:08:03.208 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:0f:fa:a9 time 0
2018-10-20 17:08:03.212 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Stopping the player
2018-10-20 17:08:03.215 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:0f:fa:a9 stop
2018-10-20 17:08:03.218 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:0f:fa:a9 mixer volume 80
2018-10-20 17:08:04.508 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Playlist updated
2018-10-20 17:08:04.510 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:e2:3a:a3 playlist index 0
2018-10-20 17:08:04.512 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:e2:3a:a3 time 56
2018-10-20 17:08:04.518 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Resuming last item playing
2018-10-20 17:08:04.520 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:e2:3a:a3 mixer volume 50
2018-10-20 17:08:04.563 [INFO ] [.Weatherstation Uptime Duration is: ] - 04 days, 11 hours, 37 minutes, 18 seconds
2018-10-20 17:08:13.251 [INFO ] [.eclipse.smarthome.model.script.Info] - Entrance door lock status is now: ON, hour is now: 22
2018-10-20 17:08:13.269 [INFO ] [.eclipse.smarthome.model.script.Info] - Entrance door lock status is now: ON
2018-10-20 17:08:13.303 [INFO ] [.eclipse.smarthome.model.script.Info] - Playing: doorlock_locked.mp3
2018-10-20 17:08:13.310 [INFO ] [.eclipse.smarthome.model.script.Info] - Playing: doorlock_locked.mp3
2018-10-20 17:08:13.312 [DEBUG] [eezebox.internal.SqueezeBoxAudioSink] - Processing audioStream http://192.168.1.181:8080/audio/6f084bb0-9d7f-48aa-a608-9aef496c3f7e.mp3 of format AudioFormat [codec=MP3, container=NONE, ]
2018-10-20 17:08:13.330 [DEBUG] [ebox.handler.SqueezeBoxPlayerHandler] - Play notification sound on player b8:27:eb:e2:3a:a3 at URI http://192.168.1.181:8080/audio/6f084bb0-9d7f-48aa-a608-9aef496c3f7e.mp3
2018-10-20 17:08:13.341 [DEBUG] [ezebox.handler.SqueezeBoxPlayerState] - Cur State: vol=50, mut=NOT MUTED, pwr=ON, stp=NOT STOPPED, ctl=PLAYING, shf=OFF, rpt=OFF, tix=0, tnm=1, tim=7
2018-10-20 17:08:13.354 [DEBUG] [eezebox.internal.SqueezeBoxAudioSink] - Processing audioStream http://192.168.1.181:8080/audio/093f9193-d30e-47b2-8260-c7b0eacea10a.mp3 of format AudioFormat [codec=MP3, container=NONE, ]
2018-10-20 17:08:13.355 [DEBUG] [ebox.handler.SqueezeBoxPlayerHandler] - Play notification sound on player b8:27:eb:0f:fa:a9 at URI http://192.168.1.181:8080/audio/093f9193-d30e-47b2-8260-c7b0eacea10a.mp3
2018-10-20 17:08:13.343 [INFO ] [.eclipse.smarthome.model.script.Info] - Sending telegram to bot1: :info: Drzwi wejściowe zablokowane
2018-10-20 17:08:13.356 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Setting up player for notification
2018-10-20 17:08:13.347 [INFO ] [.eclipse.smarthome.model.script.Info] - Sending telegram to bot2: :info: Drzwi wejściowe zablokowane
2018-10-20 17:08:13.367 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:e2:3a:a3 stop
2018-10-20 17:08:13.377 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Adding notification message to playlist
2018-10-20 17:08:13.357 [DEBUG] [ezebox.handler.SqueezeBoxPlayerState] - Cur State: vol=80, mut=NOT MUTED, pwr=ON, stp=STOPPED, ctl=PAUSED, shf=OFF, rpt=OFF, tix=0, tnm=0, tim=0
2018-10-20 17:08:13.387 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:e2:3a:a3 playlist add http://192.168.1.181:8080/audio/6f084bb0-9d7f-48aa-a608-9aef496c3f7e.mp3 Notification
2018-10-20 17:08:13.387 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Setting up player for notification
2018-10-20 17:08:13.398 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Adding notification message to playlist
2018-10-20 17:08:13.400 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:0f:fa:a9 playlist add http://192.168.1.181:8080/audio/093f9193-d30e-47b2-8260-c7b0eacea10a.mp3 Notification
2018-10-20 17:08:13.907 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Playlist updated
2018-10-20 17:08:13.911 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Playing notification
2018-10-20 17:08:13.914 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Playlist updated
2018-10-20 17:08:13.914 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - Sending command: b8:27:eb:0f:fa:a9 playlist index 0
2018-10-20 17:08:13.916 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Playing notification
2018-10-20 17:08:13.920 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - no connection to squeeze server when trying to send command, returning...
2018-10-20 17:08:14.641 [INFO ] [.Weatherstation Uptime Duration is: ] - 04 days, 11 hours, 37 minutes, 18 seconds
2018-10-20 17:08:24.551 [INFO ] [.Weatherstation Uptime Duration is: ] - 04 days, 11 hours, 37 minutes, 38 seconds
2018-10-20 17:08:31.524 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - no connection to squeeze server when trying to send command, returning...
2018-10-20 17:08:33.669 [INFO ] [.SmartWeatherStationDiscoveryService] - Already have thing with ID=<weatherflowsmartweather:sky:HB-00003071:SK-00010471>
2018-10-20 17:08:34.612 [INFO ] [.Weatherstation Uptime Duration is: ] - 04 days, 11 hours, 37 minutes, 48 seconds
2018-10-20 17:08:36.338 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Notification message timed out after 20 seconds
2018-10-20 17:08:36.345 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Restoring player state
2018-10-20 17:08:36.346 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Restoring player state
2018-10-20 17:08:36.349 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - no connection to squeeze server when trying to send command, returning...
2018-10-20 17:08:36.357 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Removing notification message from playlist
2018-10-20 17:08:36.357 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - no connection to squeeze server when trying to send command, returning...
2018-10-20 17:08:36.366 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - no connection to squeeze server when trying to send command, returning...
2018-10-20 17:08:36.366 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Removing notification message from playlist
2018-10-20 17:08:36.372 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - no connection to squeeze server when trying to send command, returning...
2018-10-20 17:08:39.855 [INFO ] [.SmartWeatherStationDiscoveryService] - Already have thing with ID=<weatherflowsmartweather:air:HB-00003071:AR-00007657>
2018-10-20 17:08:39.874 [INFO ] [ather.handler.SmartWeatherAirHandler] - parsing observation record: [1.540048117E9, 1010.1, 10.15, 75.0, 0.0, 0.0, 3.44, 1.0]
2018-10-20 17:08:41.589 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Update playlist timed out after 5 seconds
2018-10-20 17:08:41.639 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Update playlist timed out after 5 seconds
2018-10-20 17:08:42.153 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Exception while removing notification from playlist: Unable to update playlist.
2018-10-20 17:08:42.154 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Exception while removing notification from playlist: Unable to update playlist.
2018-10-20 17:08:42.154 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - no connection to squeeze server when trying to send command, returning...
2018-10-20 17:08:42.156 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - no connection to squeeze server when trying to send command, returning...
2018-10-20 17:08:42.159 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - no connection to squeeze server when trying to send command, returning...
2018-10-20 17:08:42.167 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - no connection to squeeze server when trying to send command, returning...
2018-10-20 17:08:42.174 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Stopping the player
2018-10-20 17:08:42.182 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - no connection to squeeze server when trying to send command, returning...
2018-10-20 17:08:42.158 [DEBUG] [handler.SqueezeBoxNotificationPlayer] - Resuming last item playing
2018-10-20 17:08:42.186 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - no connection to squeeze server when trying to send command, returning...
2018-10-20 17:08:42.192 [DEBUG] [ebox.handler.SqueezeBoxPlayerHandler] - SqueezeBoxTimeoutException during notification: Notification message timed out
2018-10-20 17:08:42.201 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - no connection to squeeze server when trying to send command, returning...
2018-10-20 17:08:42.221 [DEBUG] [ebox.handler.SqueezeBoxPlayerHandler] - SqueezeBoxTimeoutException during notification: Notification message timed out
2018-10-20 17:08:44.518 [INFO ] [.Weatherstation Uptime Duration is: ] - 04 days, 11 hours, 37 minutes, 58 seconds
2018-10-20 17:08:54.601 [INFO ] [.Weatherstation Uptime Duration is: ] - 04 days, 11 hours, 37 minutes, 58 seconds
2018-10-20 17:09:04.528 [INFO ] [.Weatherstation Uptime Duration is: ] - 04 days, 11 hours, 38 minutes, 18 seconds
2018-10-20 17:09:14.570 [INFO ] [.Weatherstation Uptime Duration is: ] - 04 days, 11 hours, 38 minutes, 28 seconds
2018-10-20 17:09:24.564 [INFO ] [.Weatherstation Uptime Duration is: ] - 04 days, 11 hours, 38 minutes, 38 seconds
2018-10-20 17:09:31.611 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - no connection to squeeze server when trying to send command, returning...
2018-10-20 17:09:33.670 [INFO ] [.SmartWeatherStationDiscoveryService] - Already have thing with ID=<weatherflowsmartweather:sky:HB-00003071:SK-00010471>
2018-10-20 17:09:34.641 [INFO ] [.Weatherstation Uptime Duration is: ] - 04 days, 11 hours, 38 minutes, 48 seconds
2018-10-20 17:09:37.241 [INFO ] [del.script.UPS Runtime Duration is: ] - 01 hours, 06 minutes, 00 seconds
2018-10-20 17:09:39.857 [INFO ] [.SmartWeatherStationDiscoveryService] - Already have thing with ID=<weatherflowsmartweather:air:HB-00003071:AR-00007657>
2018-10-20 17:09:39.875 [INFO ] [ather.handler.SmartWeatherAirHandler] - parsing observation record: [1.540048177E9, 1010.1, 10.18, 75.0, 0.0, 0.0, 3.45, 1.0]
2018-10-20 17:09:44.543 [INFO ] [.Weatherstation Uptime Duration is: ] - 04 days, 11 hours, 38 minutes, 58 seconds
2018-10-20 17:09:54.586 [INFO ] [.Weatherstation Uptime Duration is: ] - 04 days, 11 hours, 39 minutes, 08 seconds
2018-10-20 17:10:04.595 [INFO ] [.Weatherstation Uptime Duration is: ] - 04 days, 11 hours, 39 minutes, 18 seconds
2018-10-20 17:10:14.693 [INFO ] [.Weatherstation Uptime Duration is: ] - 04 days, 11 hours, 39 minutes, 18 seconds
2018-10-20 17:10:24.651 [INFO ] [.Weatherstation Uptime Duration is: ] - 04 days, 11 hours, 39 minutes, 38 seconds
2018-10-20 17:10:31.614 [DEBUG] [ebox.handler.SqueezeBoxServerHandler] - no connection to squeeze server when trying to send command, returning...
How to fix it?
