I have configured squeezeboxsoeak action that should speak when a button is pressed.
The player is a max2play on rpi2 and wotks very good.
However the squeezeboxspeak gives below error in the debug logs and nothing can be heard.
2015-11-28 10:38:55.571 [DEBUG] [io.squeezeserver.SqueezeServer] - No connection to SqueezeServer, will attempt to reconnect now…
2015-11-28 10:38:55.575 [INFO ] [io.squeezeserver.SqueezeServer] - Squeeze Server connection started.
2015-11-28 10:38:55.575 [DEBUG] [io.squeezeserver.SqueezeServer] - Squeeze Server listener started.
2015-11-28 10:38:55.578 [DEBUG] [io.squeezeserver.SqueezeServer] - Sending command: 80:1F:02:AF:46:08 mixer volume 30
2015-11-28 10:38:55.583 [DEBUG] [io.squeezeserver.SqueezeServer] - Sending command: players 0
2015-11-28 10:38:55.585 [DEBUG] [io.squeezeserver.SqueezeServer] - Sending command: listen 1
2015-11-28 10:38:55.587 [DEBUG] [io.squeezeserver.SqueezeServer] - Sending command: 80:1F:02:AF:46:08 playlist add http://translate.google.com/translate_tts?tl=en&q=This%20is%20a%20Voice%20test.
2015-11-28 10:38:56.589 [DEBUG] [io.squeezeserver.SqueezeServer] - Sending command: 80:1F:02:AF:46:08 playlist index -1
2015-11-28 10:38:56.591 [DEBUG] [io.squeezeserver.SqueezeServer] - Sending command: 80:1F:02:AF:46:08 play
2015-11-28 10:38:58.102 [DEBUG] [io.squeezeserver.SqueezeServer] - Message received: 80%3A1F%3A02%3AAF%3A46%3A08 mixer volume 30
2015-11-28 10:38:58.115 [ERROR] [io.squeezeserver.SqueezeServer] - Error in Squeeze Server listener
java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(SocketInputStream.java:189) ~[na:1.8.0]
at java.net.SocketInputStream.read(SocketInputStream.java:121) ~[na:1.8.0]
at sun.nio.cs.StreamDecoder.readBytes(StreamDecoder.java:284) ~[na:1.8.0]
at sun.nio.cs.StreamDecoder.implRead(StreamDecoder.java:326) ~[na:1.8.0]
at sun.nio.cs.StreamDecoder.read(StreamDecoder.java:178) ~[na:1.8.0]
at java.io.InputStreamReader.read(InputStreamReader.java:184) ~[na:1.8.0]
at java.io.BufferedReader.fill(BufferedReader.java:161) ~[na:1.8.0]
at java.io.BufferedReader.readLine(BufferedReader.java:324) ~[na:1.8.0]
at java.io.BufferedReader.readLine(BufferedReader.java:389) ~[na:1.8.0]
at org.openhab.io.squeezeserver.SqueezeServer$SqueezeServerListener.run(SqueezeServer.java:550) ~[na:na]
2015-11-28 10:38:58.118 [WARN ] [io.squeezeserver.SqueezeServer] - Squeeze Server listener exiting.
Anyone an idea?
