3DJupp
(Dominic Spatz)
October 20, 2015, 1:06pm
1
I Just want to ask you, how can i import my SSL Certificate
there a now a few more xml files:
ls /opt/openhab/runtime/server/configuration/org.eclipse.osgi/149/0/.cp/jettyhome/etc/
jetty-deployer.xml jetty-https.xml jetty-selector.xml jetty-ssl.xml jetty.xml
on OpenHAB 1.x i did it this way (there was only one file, the jetty.xml, which was Saved)
cp /BCKUP/jetty.xml /OpenHAB/etc
openssl pkcs12 -export -inkey /BCKUP/server.key -in /BCKUP/chain.pem -out /tmp/oh.p12
keytool -importkeystore -srckeystore /tmp/oh.p12 -srcstoretype PKCS12 -destkeystore /OpenHAB/etc/keystore
Stratehm
(Stratehm)
October 23, 2015, 11:15am
2
You can try to replace the already present certificate in the runtime/etc/keystore file by using the following commands instead of your last one (not tested, you may have to adapt the command lines):
Delete the old certificate:
keytool -delete -alias mykey -keystore /OpenHAB2InstallDir/runtime/etc/keystore
Add your own certificate:
keytool -importkeystore -srckeystore /tmp/oh.p12 -srcstoretype pkcs12 -destkeystore /OpenHAB2InstallDir/runtime/etc/keystore
-deststoretype jks -deststorepass openhab -destalias mykey
With this solution, you do not have to manipulate jetty configuration files (In OpenHAB 2, they are now embedded in a bundle).
EdwardV
(Edward Voermans)
April 29, 2019, 3:45pm
3
Hi all,
After struggling with official TLD certificates on OpenHAB I was able to get a structured approach that will allow you to add an official certificate in minutes instead of hours (even days).
I used the other posts on SSL in OpenHAB as a base but had to combine a bunch of them to be successful.
Anyway, these are the steps using a DigiCert wildcard certificate on a Openhabian installation on Raspberry Pi 3B+. I did also test this methodology on a Ubuntu VM in HyperV in a Linux OpenHAB install. Works like a charm.
Hope this helps. Will post this as a single post as well.
BACKUP your default keystore !!!
cd /var/lib/OpenHABInstallDir/etc/
cp keystore keystore.backup
Passwords are ‘openhab’ or assumed to be.
STOP OpenHAB
sudo systemctl stop OpenHABInstallDir
This example uses a DigiCert wildcard certificate
cat DigiCertCA.crt yourOfficialTLD_cert.crt > yourOfficialTLD_cert_chain.pem
openssl pkcs12 -export -inkey yourOfficialTLD_cert.key -in yourOfficialTLD_cert__chain.pem -out yourOfficialTLD_oh.p12 [Make sure password is openhab]
keytool -keystore /var/lib/OpenHABInstallDir/etc/keystore -list -v [Note alias: should be mykey]
keytool -delete -alias mykey -keystore /var/lib/OpenHABInstallDir/etc/keystore
keytool -list -keystore /tmp/cert/yourOfficialTLD_oh.p12 -storetype pkcs12 [Note alias: should be 1]
keytool -importkeystore -srckeystore /tmp/cert/yourOfficialTLD_oh.p12 -srcstoretype PKCS12 -destkeystore /var/lib/OpenHABInstallDir/etc/keystore -deststoretype jks -destalias mykey -srcalias 1
START OpenHAB
#sudo systemctl start OpenHABInstallDir
Cheers.
Edward
Rafal
(Rafal Lukawiecki)
April 26, 2020, 4:23pm
4
If you stumble here and still looking for a way to do it in OH2.5, see the little script I posted on this thread: Securing Openhab with free ssl Let's Encrypt Certificates - #26 by Rafal
