Stability of V 1.7.1 gone worse
Version 1.7.1 has introduced a some update on Upnp.
After the update, I am getting every 20 second the warning below.
9515	2015-08-20 02:16:06.797 [WARN ] [.c.p.RetrieveRemoteDescriptors] - Received service descriptor without or with invalid Content-Type: http://192.168.178.108:5003/ssdp/dummy.xml
9516	2015-08-20 02:16:06.797 [WARN ] [.c.p.RetrieveRemoteDescriptors] - Received empty descriptor:http://192.168.178.108:5003/ssdp/dummy.xml
The upnp search obviously is not compatible with my synology which is listening at port 5003 for html.
Change this port on the synology will result that the warning is changing the port accordingly.
This search below is repeated every 30-40 seconds!
Totally meaningless and flawed.
upnp is activated by using the sonos binding.
which leads to a crash after about 1,5 days.
It seems that the existing “cling” bug has seriously turned worse.
Would it be possible to step back to the old upnp libraray and staying at 1.7.1?
Additionally the infamous loading bug, that occurs if you have more than one rule file, now creates an meaningless error entry that spans over 2 pages. It would be great, if we are not able to fix the bug, to reduce this log.
example see below:
2015-08-19 21:52:47.089 [ERROR] [r.i.DefaultResourceDescription] - main.rules (Das System kann die angegebene Datei nicht finden)
java.io.FileNotFoundException: main.rules (Das System kann die angegebene Datei nicht finden)
at java.io.FileInputStream.open0(Native Method) ~[na:1.8.0_45]
at java.io.FileInputStream.open(Unknown Source) ~[na:1.8.0_45]
at java.io.FileInputStream.(Unknown Source) ~[na:1.8.0_45]
at org.eclipse.emf.ecore.resource.impl.FileURIHandlerImpl.createInputStream(FileURIHandlerImpl.java:99) ~[org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:354) ~[org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1256) ~[org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.xtext.resource.impl.DefaultResourceDescription.computeExportedObjects(DefaultResourceDescription.java:73) ~[org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.DerivedStateAwareResourceDescriptionManager$1.getLookUp(DerivedStateAwareResourceDescriptionManager.java:61) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.impl.AbstractResourceDescription.getExportedObjects(AbstractResourceDescription.java:32) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.DerivedStateAwareResourceDescriptionManager.internalGetResourceDescription(DerivedStateAwareResourceDescriptionManager.java:45) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.impl.DefaultResourceDescriptionManager$1.get(DefaultResourceDescriptionManager.java:60) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.impl.DefaultResourceDescriptionManager$1.get(DefaultResourceDescriptionManager.java:1) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.util.OnChangeEvictingCache.get(OnChangeEvictingCache.java:75) [org.eclipse.xtext.util_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.impl.DefaultResourceDescriptionManager.getResourceDescription(DefaultResourceDescriptionManager.java:58) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.impl.ResourceSetBasedResourceDescriptions.getResourceDescription(ResourceSetBasedResourceDescriptions.java:97) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.impl.ResourceSetBasedResourceDescriptions$1$1.computeNext(ResourceSetBasedResourceDescriptions.java:61) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.resource.impl.ResourceSetBasedResourceDescriptions$1$1.computeNext(ResourceSetBasedResourceDescriptions.java:1) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at com.google.common.collect.AbstractIterator.tryToComputeNext(AbstractIterator.java:141) [com.google.guava_10.0.1.v201203051515.jar:na]
at com.google.common.collect.AbstractIterator.hasNext(AbstractIterator.java:136) [com.google.guava_10.0.1.v201203051515.jar:na]
at com.google.common.collect.Iterators$7.computeNext(Iterators.java:643) [com.google.guava_10.0.1.v201203051515.jar:na]
at com.google.common.collect.Iterators$8.hasNext(Iterators.java:777) [com.google.guava_10.0.1.v201203051515.jar:na]
at com.google.common.collect.Iterables$3.hasNext(Iterables.java:501) [com.google.guava_10.0.1.v201203051515.jar:na]
at com.google.common.collect.Iterators$5.hasNext(Iterators.java:539) [com.google.guava_10.0.1.v201203051515.jar:na]
at org.eclipse.xtext.common.types.access.impl.IndexedJvmTypeAccess.getIndexedJvmType(IndexedJvmTypeAccess.java:64) [org.eclipse.xtext.common.types_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.common.types.access.impl.IndexedJvmTypeAccess.getIndexedJvmType(IndexedJvmTypeAccess.java:53) [org.eclipse.xtext.common.types_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.common.types.access.impl.ClasspathTypeProvider.findTypeByName(ClasspathTypeProvider.java:77) [org.eclipse.xtext.common.types_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.common.types.util.TypeReferences.findDeclaredType(TypeReferences.java:234) [org.eclipse.xtext.common.types_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.common.types.util.TypeReferences.findDeclaredType(TypeReferences.java:211) [org.eclipse.xtext.common.types_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.common.types.util.TypeReferences.getTypeForName(TypeReferences.java:177) [org.eclipse.xtext.common.types_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.typing.XbaseTypeProvider._type(XbaseTypeProvider.java:943) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.typing.XbaseTypeProvider.type(XbaseTypeProvider.java:179) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.typing.AbstractTypeProvider$2.doComputation(AbstractTypeProvider.java:292) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.typing.AbstractTypeProvider$2.doComputation(AbstractTypeProvider.java:1) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.typing.AbstractTypeProvider$CyclicHandlingSupport$3.get(AbstractTypeProvider.java:658) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.typing.AbstractTypeProvider$CyclicHandlingSupport$3.get(AbstractTypeProvider.java:1) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.typing.AbstractTypeProvider$1.get(AbstractTypeProvider.java:159) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.typing.AbstractTypeProvider$CyclicHandlingSupport.getType(AbstractTypeProvider.java:655) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.typing.AbstractTypeProvider.doGetType(AbstractTypeProvider.java:348) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.typing.AbstractTypeProvider.getType(AbstractTypeProvider.java:364) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.typing.AbstractTypeProvider.getType(AbstractTypeProvider.java:360) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.linking.FeatureCallChecker._case(FeatureCallChecker.java:291) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at sun.reflect.GeneratedMethodAccessor70.invoke(Unknown Source) ~[na:na]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[na:1.8.0_45]
at java.lang.reflect.Method.invoke(Unknown Source) ~[na:1.8.0_45]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) [org.eclipse.xtext.util_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.linking.FeatureCallChecker.checkWithoutTypes(FeatureCallChecker.java:179) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.linking.BestMatchingJvmFeatureScope.getBestMatch(BestMatchingJvmFeatureScope.java:118) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.linking.BestMatchingJvmFeatureScope.getSingleElement(BestMatchingJvmFeatureScope.java:78) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getLinkedObjects(DefaultLinkingService.java:121) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:179) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.resource.XbaseResource.access$0(XbaseResource.java:1) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.resource.XbaseResource$2.exec(XbaseResource.java:239) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.resource.XbaseResource$2.exec(XbaseResource.java:1) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:124) [org.eclipse.xtext.util_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.resource.XbaseResource.getEObject(XbaseResource.java:237) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:223) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:197) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:257) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1473) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.xtext.xbase.impl.XAbstractFeatureCallImpl.getFeature(XAbstractFeatureCallImpl.java:175) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.impl.XAbstractFeatureCallImpl.eGet(XAbstractFeatureCallImpl.java:434) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.impl.XBinaryOperationImpl.eGet(XBinaryOperationImpl.java:209) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1011) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1003) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:998) [org.eclipse.emf.ecore_2.8.3.v20130125-0546.jar:na]
at org.eclipse.xtext.xbase.resource.XbaseResource.trackResolution(XbaseResource.java:202) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.resource.XbaseResource.getFeature(XbaseResource.java:187) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.resource.LinkingAssumptions.getFeature(LinkingAssumptions.java:120) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.typing.AbstractTypeProvider.getFeature(AbstractTypeProvider.java:307) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.typing.AbstractTypeProvider.getFeature(AbstractTypeProvider.java:311) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.typing.XbaseTypeProvider._type(XbaseTypeProvider.java:1140) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.typing.XbaseTypeProvider.type(XbaseTypeProvider.java:153) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.scoping.XbaseScopeProvider.createFeatureCallScopeForReceiver(XbaseScopeProvider.java:400) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.scoping.XbaseScopeProvider.createFeatureCallScope(XbaseScopeProvider.java:335) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.scoping.XbaseScopeProvider.getScope(XbaseScopeProvider.java:179) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.xbase.linking.XbaseLinkingScopeProvider.getScope(XbaseLinkingScopeProvider.java:42) [org.eclipse.xtext.xbase_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getScope(DefaultLinkingService.java:59) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getLinkedObjects(DefaultLinkingService.java:119) [org.eclipse.xtext_2.3.0.v201206120633.jar:na]
