I am pritty new with openHAB so I am learning so many thx to the community otherwise I would not have started with openHAB (learningcurve)…
Could be that my solution is somewhere on the Community Blog but I did not find it. Sorry if it is.
I have made a rule that for exaple dims my bedroom lights “original rule”.
I want to use this rule in “another rule”.
Now I copy paste the “original rule” in “another rule” but if I change something in the “original rule” I have to remember to copy paste it in the “another rule”.
Is there a way to start “original rule” in “another rule”?
Thx Tom for your quick reaction!
But for example I use this Progressive Dimmer rule as a wake up dimmer.
But I have changed/added some things (the dimLevel to 90 instead of 100).
I have made another rule to do the same when I trigger a switch.
But now I would rather have de dimLevel to 70 so I have to change it twice.
Is there a way to make a “standard rule” to dim the lights and refer to it in another rule?
The new rule engine allows for you to execute a rule’s action from another rule’s action. This can be done in rules created through the UI or scripted automation. Actually, you can create just actions without triggers, so not a full rule, and execute those from rules.
