Hi trying to setup a development environment on x64 Windows 10 Using VSCode.
Following the guides:
Also have set up local openHAB on the same machine following: openHAB on Windows
- openHAB version 4.4
- ENV Variable %JAVA_HOME% = C:\Program Files\Java\jdk-17
ORACLE JDK 17
Java --version
java 17.0.9 2023-10-17 LTS
Java(TM) SE Runtime Environment (build 17.0.9+11-LTS-201)
Java HotSpot(TM) 64-Bit Server VM (build 17.0.9+11-LTS-201, mixed mode, sharing)
Trying to get the ‘startup.bat debug’ command to work as specified VSCode
- Section heading: Steps for each Bundle
- Step: 7.
But I get the following
c:\openHAB>C:\openHAB\start.bat debug
Launching the openHAB runtime...
The system cannot find the batch label specified - RUN_LOOP
I can’t find any mention of this issue in the forum.
I also noticed there is a start_debug.bat file in my openHAB directory, tried running that batch file too
and get exactly the same output.
c:\openHAB>start_debug.bat
I can run the ‘startup.bat’ command with no issues and get the familiar openHAB page on http://localhost:8080.
Any guidance welcomed.
