Goof afternoon,
just started with openhab2 and need some help with setting up a simple rule.
I am using the Alexa and a HUE motion sensor.
The rule should be, if I enter the kitchen, the motion sensor switched from OFF to ON - (Motion sensor triggers activity each 30 sec.) Once the motion sensor switched to ON Alex should start the Radio.
My Problem is, once I leave the kitchen for more then 30 sec. the Motion sensor switched to status OFF, once I return to the room the rule starts again, which means that there is a short interruption within the music.
String Echo_Living_Room_RadioStationId "TuneIn Radio Station Id" {channel="amazonechocontrol:echo:account1:echo1:radioStationId"}
rule "Start the radio once I enter the Kitchen"
Item KMotionPresence changed to ON
Echo_Living_Room_RadioStationId.sendCommand('s25260')
Hope someone understands my goal and can provide some help!
Thx
JinFin
var Bolean Radio_OFF = true
If (Radio_OFF) {
Radio_OFF = false
If the Echo_Living_Room_RadioStationId stays the same while the radio is playing and only changes when you stop or switch the station, a simple if comparison could help:
if (Echo_Living_Room_RadioStationId.state.toString != 's25260') {
Thx! This sounds like a solution, unfortunately “Echo_Living_Room_RadioStationID” is losing his value:
2018-07-22 19:53:11.157 [vent.ItemStateChangedEvent] - Echo_Living_Room_RadioStationId changed from to s25260
2018-07-22 19:53:20.943 [vent.ItemStateChangedEvent] - Echo_Living_Room_RadioStationId changed from s25260 to
Has anyone an idea why this is happening? All other items keep their values!?
THX!
This is most likely a Thing that changes the value of your String. I assume you have bound some Amazon Echo-related Thing Channel to your Item, right?
If the Thing does this, we have little chance to change this. In this case, you should refer to @hr3’s suggestion to set a variable or Switch Item (without any Thing bound to it) to remember if the music was already started.
