Starting runtime openhab2
Problems with the runtime Openhab2 .
After having played for a while with openhab1 I now want to look at v2.
However, when I run the start of the demo project using the link http://localhost:8080 I get no response .
Any ideas?
You really need to check the debug logs. Run OH2 in debug mode (same as you run OH1 in debug mode) and see what the log says (hopefully it will provide some useful information)… Feel free to post the log here, but really we need more information than ‘it doesn’t work’ :smile:
Chris
Hi Chris,
Here is my debug log.
ava.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=nl_NL
Command-line arguments:  -console
!ENTRY org.eclipse.osgi 4 0 2015-08-20 22:12:30.781
!MESSAGE Bundle reference:file:org.eclipse.debug.core_3.9.1.v20140805-1629.jar@4 not found.
!ENTRY org.eclipse.osgi 4 0 2015-08-20 22:12:30.795
!MESSAGE Bundle reference:file:org.eclipse.jdt.core_3.10.2.v20150120-1634.jar@4 not found.
!ENTRY org.eclipse.osgi 4 0 2015-08-20 22:12:30.798
!MESSAGE Bundle reference:file:org.eclipse.jdt.launching_3.7.102.v20141111-0953.jar@4 not found.
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:34.245
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.persistence.manager. The reference is: Reference[name = ModelRepository, interface = org.eclipse.smarthome.model.core.ModelRepository, policy = dynamic, cardinality = 0..1, target = null, bind = setModelRepository, unbind = unsetModelRepository]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:34.248
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.persistence.manager. The reference is: Reference[name = PersistenceService, interface = org.eclipse.smarthome.core.persistence.PersistenceService, policy = dynamic, cardinality = 0..n, target = null, bind = addPersistenceService, unbind = removePersistenceService]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:34.252
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.persistence.manager. The reference is: Reference[name = ItemRegistry, interface = org.eclipse.smarthome.core.items.ItemRegistry, policy = dynamic, cardinality = 0..1, target = null, bind = setItemRegistry, unbind = unsetItemRegistry]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:34.260
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.model.persistence.extensions. The reference is: Reference[name = PersistenceService, interface = org.eclipse.smarthome.core.persistence.PersistenceService, policy = dynamic, cardinality = 0..n, target = null, bind = addPersistenceService, unbind = removePersistenceService]
!ENTRY org.eclipse.emf.codegen 4 0 2015-08-20 22:12:35.183
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.codegen [37]
  Unresolved requirement: Require-Bundle: org.eclipse.jdt.core; bundle-version="[3.5.0,4.0.0)"
	at org.eclipse.osgi.container.Module.start(Module.java:434)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.emf.codegen.ecore 4 0 2015-08-20 22:12:35.188
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.codegen.ecore [38]
!ENTRY org.eclipse.jdt.debug 4 0 2015-08-20 22:12:35.211
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jdt.debug [54]
  Unresolved requirement: Require-Bundle: org.eclipse.debug.core; bundle-version="[3.9.0,4.0.0)"
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:35.306
!MESSAGE Could not bind a reference of component ConfigDescriptionRegistry. The reference is: Reference[name = ConfigDescriptionProvider, interface = org.eclipse.smarthome.config.core.ConfigDescriptionProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addConfigDescriptionProvider, unbind = removeConfigDescriptionProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:35.319
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistry. The reference is: Reference[name = DiscoveryService, interface = org.eclipse.smarthome.config.discovery.DiscoveryService, policy = dynamic, cardinality = 0..n, target = null, bind = addDiscoveryService, unbind = removeDiscoveryService]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:35.479
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.binding.BindingInfoRegistry. The reference is: Reference[name = BindingInfoProvider, interface = org.eclipse.smarthome.core.binding.BindingInfoProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addBindingInfoProvider, unbind = removeBindingInfoProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:35.538
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.itemregistry. The reference is: Reference[name = ItemProvider, interface = org.eclipse.smarthome.core.items.ItemProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addProvider, unbind = removeProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:35.541
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.itemregistry. The reference is: Reference[name = EventPublisher, interface = org.eclipse.smarthome.core.events.EventPublisher, policy = dynamic, cardinality = 0..1, target = null, bind = setEventPublisher, unbind = unsetEventPublisher]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:35.544
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.itemregistry. The reference is: Reference[name = StateDescriptionProvider, interface = org.eclipse.smarthome.core.types.StateDescriptionProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addStateDescriptionProvider, unbind = removeStateDescriptionProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:35.601
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.thing.ThingRegistry. The reference is: Reference[name = ThingProvider, interface = org.eclipse.smarthome.core.thing.ThingProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addProvider, unbind = removeProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:35.608
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.thing.link.ItemChannelLinkRegistry. The reference is: Reference[name = ItemChannelLinkProvider, interface = org.eclipse.smarthome.core.thing.link.ItemChannelLinkProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addProvider, unbind = removeProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:35.614
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.thing.type.ThingTypeRegistry. The reference is: Reference[name = ThingTypeProvider, interface = org.eclipse.smarthome.core.thing.binding.ThingTypeProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addThingTypeProvider, unbind = removeThingTypeProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:35.625
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.thing.link.ItemThingLinkRegistry. The reference is: Reference[name = ItemThingLinkProvider, interface = org.eclipse.smarthome.core.thing.link.ItemThingLinkProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addProvider, unbind = removeProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:35.632
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.thing.setup.ThingSetupManager. The reference is: Reference[name = ThingHandlerFactory, interface = org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory, policy = dynamic, cardinality = 0..n, target = null, bind = addThingHandlerFactory, unbind = removeThingHandlerFactory]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:42.489
!MESSAGE Could not bind a reference of component org.openhab.persistence.rrd4j. The reference is: Reference[name = ItemRegistry, interface = org.openhab.core.items.ItemRegistry, policy = dynamic, cardinality = 0..1, target = null, bind = setItemRegistry, unbind = unsetItemRegistry]
!ENTRY org.eclipse.equinox.cm 4 0 2015-08-20 22:12:42.496
!MESSAGE
!STACK 0
java.lang.NullPointerException
	at org.openhab.persistence.rrd4j.internal.RRD4jService.updated(RRD4jService.java:348)
	at org.eclipse.equinox.internal.cm.ManagedServiceTracker$1.run(ManagedServiceTracker.java:276)
	at org.eclipse.equinox.internal.cm.SerializedTaskQueue$1.run(SerializedTaskQueue.java:36)
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:42.499
!MESSAGE Could not bind a reference of component org.openhab.core.compat1x.actionservicefactory. The reference is: Reference[name = ActionService, interface = org.openhab.core.scriptengine.action.ActionService, policy = dynamic, cardinality = 0..n, target = null, bind = addActionService, unbind = removeActionService]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:42.506
!MESSAGE Could not bind a reference of component org.openhab.core.compat1x.autoupdateproviderdelegate. The reference is: Reference[name = AutoUpdateBindingProvider, interface = org.openhab.core.autoupdate.AutoUpdateBindingProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addAutoUpdateBindingProvider, unbind = removeAutoUpdateBindingProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:42.514
!MESSAGE Could not bind a reference of component org.openhab.core.compat1x.chartproviderfactory. The reference is: Reference[name = ChartProvider, interface = org.openhab.ui.chart.ChartProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addChartProvider, unbind = removeChartProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:42.528
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.ui. The reference is: Reference[name = ItemUIProvider, interface = org.eclipse.smarthome.ui.items.ItemUIProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addItemUIProvider, unbind = removeItemUIProvider]
!ENTRY org.eclipse.smarthome.model.persistence 4 0 2015-08-20 22:12:42.541
!MESSAGE [SCR] Error while trying to bind reference Reference[name = PersistenceService, interface = org.eclipse.smarthome.core.persistence.PersistenceService, policy = dynamic, cardinality = 0..n, target = null, bind = addPersistenceService, unbind = removePersistenceService]
	Details:
	Problematic reference = Reference[name = PersistenceService, interface = org.eclipse.smarthome.core.persistence.PersistenceService, policy = dynamic, cardinality = 0..n, target = null, bind = addPersistenceService, unbind = removePersistenceService]
	of service component = org.eclipse.smarthome.core.persistence.manager
	component implementation class = org.eclipse.smarthome.model.persistence.internal.PersistenceManager
	located in bundle with symbolic name = org.eclipse.smarthome.model.persistence
	bundle location = initial@reference:file:plugins/org.eclipse.smarthome.model.persistence_0.8.0.201505251448.jar
!STACK 0
java.lang.reflect.InvocationTargetException
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.eclipse.equinox.internal.ds.model.ComponentReference.bind(ComponentReference.java:376)
	at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.bindReference(ServiceComponentProp.java:444)
	at org.eclipse.equinox.internal.ds.InstanceProcess.dynamicBind(InstanceProcess.java:416)
	at org.eclipse.equinox.internal.ds.Resolver.getEligible(Resolver.java:334)
	at org.eclipse.equinox.internal.ds.SCRManager.serviceChanged(SCRManager.java:222)
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127)
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:482)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:998)
	at org.openhab.core.persistence.internal.PersistenceServiceFactory.registerDelegateService(PersistenceServiceFactory.java:82)
	at org.openhab.core.persistence.internal.PersistenceServiceFactory.activate(PersistenceServiceFactory.java:40)
	at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(ServiceComponent.java:235)
	at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(ServiceComponentProp.java:146)
	at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:345)
	at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620)
	at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:197)
	at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473)
	at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217)
	at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816)
	at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783)
	at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89)
	at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NullPointerException
	at org.eclipse.smarthome.model.persistence.internal.PersistenceManager.removeTimers(PersistenceManager.java:455)
	at org.eclipse.smarthome.model.persistence.internal.PersistenceManager.stopEventHandling(PersistenceManager.java:200)
	at org.eclipse.smarthome.model.persistence.internal.PersistenceManager.addPersistenceService(PersistenceManager.java:144)
	... 37 more
Root exception:
!ENTRY org.eclipse.smarthome.model.persistence 4 0 2015-08-20 22:12:42.545
	Details:
!STACK 0
	... 37 more
Root exception:
!ENTRY org.eclipse.equinox.ds 1 0 2015-08-20 22:12:42.549
!MESSAGE Could not bind a reference of component org.openhab.core.compat1x.ttsservicefactory. The reference is: Reference[name = TTSService, interface = org.openhab.io.multimedia.tts.TTSService, policy = dynamic, cardinality = 0..n, target = null, bind = addTTSService, unbind = removeTTSService]
!ENTRY org.eclipse.smarthome.io.rest.sitemap 4 0 2015-08-20 22:12:42.773
!MESSAGE [SCR] Method was not found: setModelRepository(...)
	Details:
	Problematic reference = Reference[name = ModelRepository, interface = org.eclipse.smarthome.model.core.ModelRepository, policy = dynamic, cardinality = 1..1, target = null, bind = setModelRepository, unbind = unsetModelRepository]
	of service component = org.eclipse.smarthome.io.rest.sitemap
	component implementation class = org.eclipse.smarthome.io.rest.sitemap.internal.SitemapResource
	located in bundle with symbolic name = org.eclipse.smarthome.io.rest.sitemap
	bundle location = initial@reference:file:plugins/org.eclipse.smarthome.io.rest.sitemap_0.8.0.201505251448.jar
!ENTRY org.eclipse.smarthome.io.rest.sitemap 4 0 2015-08-20 22:12:42.776
	Details:
!ENTRY org.eclipse.smarthome.io.rest.sitemap 2 0 2015-08-20 22:12:42.779
!MESSAGE [SCR] ComponentReference.bind(): bind method 'setModelRepository' is not found or it is not accessible!
	Details:
!ENTRY org.eclipse.equinox.ds 4 0 2015-08-20 22:12:42.782
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.io.rest.sitemap. The reference is: Reference[name = ModelRepository, interface = org.eclipse.smarthome.model.core.ModelRepository, policy = dynamic, cardinality = 1..1, target = null, bind = setModelRepository, unbind = unsetModelRepository]
Clearly there are some fundamental issues as core bundles are not loaded…
One thought I had is what version of Java are you using? OH2 requires (from memory) Java 1.7, where OH1 would have worked ok with an older version (minimum 1.5 I think, but I might be wrong). If you have a version of Java older than 1.7 this might stop some bindings starting, which might cause this sort of issue…
Chris
It seems that the version that I downloaded is not correct.
I get error messages on file versions that are not there.
I can find no other version . has anyone a version which is complete and it would like to share ?
I use Java version 8u60 under Windows 10
Where did you download your copy? Cloudbees, or somewhere else?
Chris
@Ferryb4, please use proper preformatting for log excerpts, I have added that to your post now.
And as Chris asks, it would be helpful to know what you have downloaded and how you are starting it. The log appears rather like a log from the Designer than the runtime to me…
Hi Kai en Chris,
I’ve added the log as ico file because I can not upload txt file .
The files I downloaded from :
After that I unpacked the runtime and unpacked the demos about it.
After this, the runtime started start.bat and typed in my browser http : // localhost: 8080
Version 1.7 I was running immediately without problems but no way to get this working.
Thanks for helping me.
1440189833870.ico (31.4 KB)
I downloaded a new version of cloudbees and now it works fine.
thanks
