Hi
I have a minor issue on startup of 2.2. I get some strange log messages from some rules…
2018-01-22 18:13:05.396 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule ‘Populate Functional Groups’: ‘endsWith’ is not a member of ‘java.lang.String’; line 20, column 31, length 30
The rule then get’s processed correctly later on. Here’s the whole rule
rule "Populate Functional Groups"
System started or
Item sRepopulate_Groups changed from OFF to ON
logInfo("Rules","Populating functional groups")
gRoot.allMembers.filter(s | s.name.endsWith("Battery")).forEach[ item | fgBatteries.addMember(item)]
gRoot.allMembers.filter(s | s.name.endsWith("DOOR_Sensor")).forEach[ item | fgDoors.addMember(item)]
gRoot.allMembers.filter(s | s.name.endsWith("WINDOW_Sensor")).forEach[ item | fgWindows.addMember(item)]
gRoot.allMembers.filter(s | s.name.endsWith("Network")).forEach[ item | fgNetDevices.addMember(item)]
sRepopulate_Groups.postUpdate(OFF)
Any reason why this would happen?
