Hello everybody
I am new in our community, but I am reading a lot in your forum. I had set up my “Smart Home” half a year ago. But since a couple of weeks I have an issue, which i do not understand. I reset the whole system, reinstall it, took out the items and things and made it all new, but one of my blind controls make some trouble. I had also search here in this forum for such an issue, but I didn’t got any answers. Hopefully, someone of you can give me a hind.
This is my system which I am running:
- Platform information:
- Hardware: Synology NAS, Aeotec zwave USB Stick and a Fibaro RollerShutter 2
- OS: DSM 6.2.1-23824 Update 4
- Java Runtime Environment: Java 8
- openHAB version: openhab 2.3.0.005
It all went quite good for a period of half of a year. But now the problem is that. If I want to move the Roller Shutter down to an other state, it won’t do it at the first time. For example: when it has a state of 100 and I want to bring it to 0, after 2 seconds it will fall back to 100. Sometimes I have to do it 3 or 4 times and then it will follow my trigger. I also have a rule behind it and this is why I had recognise this fault.
Here is also the log of a typical fall back:
2019-01-28 23:13:44.640 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Command received zwave:device:b99c62c5:node5:blinds_control → 0
2019-01-28 23:13:44.646 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 5: Creating new message for command SWITCH_MULTILEVEL_SET
2019-01-28 23:13:44.651 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2019-01-28 23:13:44.651 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2019-01-28 23:13:44.654 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 05 03 26 01 00 25 A8 4A
2019-01-28 23:13:44.657 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 5: Sending REQUEST Message = 01 0A 00 13 05 03 26 01 00 25 A8 4A
2019-01-28 23:13:44.667 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2019-01-28 23:13:44.670 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2019-01-28 23:13:44.673 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2019-01-28 23:13:44.675 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2019-01-28 23:13:44.677 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2019-01-28 23:13:44.679 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: Sent Data successfully placed on stack.
2019-01-28 23:13:44.685 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 A8 00 00 02 41
2019-01-28 23:13:44.688 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2019-01-28 23:13:44.690 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 A8 00 00 02 00 00 4F
2019-01-28 23:13:44.692 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 A8 00 00 02 00 00 4F
2019-01-28 23:13:44.694 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=A8 00 00 02
2019-01-28 23:13:44.696 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: SendData Request. CallBack ID = 168, Status = Transmission complete and ACK received(0)
2019-01-28 23:13:44.698 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Starting initialisation from DONE
2019-01-28 23:13:44.700 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@44d035 already registered
2019-01-28 23:13:44.703 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=5, callback=168, payload=05 03 26 01 00
2019-01-28 23:13:44.705 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=A8 00 00 02
2019-01-28 23:13:44.707 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=168, expected=SendData, cancelled=false transaction complete!
2019-01-28 23:13:44.709 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2019-01-28 23:13:44.710 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2019-01-28 23:13:44.712 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 5: Response processed after 53ms/2830ms.
2019-01-28 23:13:46.744 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 05 03 26 03 0A DB
2019-01-28 23:13:46.747 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2019-01-28 23:13:46.749 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 05 03 26 03 0A DB
2019-01-28 23:13:46.751 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 05 03 26 03 0A DB
2019-01-28 23:13:46.753 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 03 26 03 0A
2019-01-28 23:13:46.755 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE)
2019-01-28 23:13:46.757 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Starting initialisation from DONE
2019-01-28 23:13:46.759 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@44d035 already registered
2019-01-28 23:13:46.761 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Incoming command class SWITCH_MULTILEVEL
2019-01-28 23:13:46.763 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 5: Received SWITCH_MULTILEVEL command V3
2019-01-28 23:13:46.764 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 05 06 31 05 04 22 00 00 E6
2019-01-28 23:13:46.765 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 5: Switch Multi Level report, value = 10
2019-01-28 23:13:46.767 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2019-01-28 23:13:46.769 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2019-01-28 23:13:46.771 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint = 0, command class = SWITCH_MULTILEVEL, value = 10
2019-01-28 23:13:46.774 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:b99c62c5:node5:blinds_control to 10 [PercentType]
2019-01-28 23:13:46.778 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=5, callback=168, payload=05 03 26 01 00
2019-01-28 23:13:46.784 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 03 26 03 0A
2019-01-28 23:13:46.787 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=168, expected=SendData, cancelled=false MISMATCH
2019-01-28 23:13:46.789 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2019-01-28 23:13:46.793 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0C 00 04 00 05 06 31 05 04 22 00 00 E6
2019-01-28 23:13:46.797 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0C 00 04 00 05 06 31 05 04 22 00 00 E6
2019-01-28 23:13:46.800 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 06 31 05 04 22 00 00
2019-01-28 23:13:46.802 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE)
2019-01-28 23:13:46.803 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Starting initialisation from DONE
2019-01-28 23:13:46.805 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@44d035 already registered
2019-01-28 23:13:46.807 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Incoming command class SENSOR_MULTILEVEL
2019-01-28 23:13:46.808 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 5: Received COMMAND_CLASS_SENSOR_MULTILEVEL command V2
2019-01-28 23:13:46.810 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 5: Sensor Multi Level REPORT received
2019-01-28 23:13:46.812 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 5: Sensor Type = Power(4), Scale = 0
2019-01-28 23:13:46.814 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 5: Sensor Value = 0E+1
2019-01-28 23:13:46.816 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2019-01-28 23:13:46.818 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2019-01-28 23:13:46.819 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 0E+1
2019-01-28 23:13:46.821 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:b99c62c5:node5:sensor_power to 0 [DecimalType]
2019-01-28 23:13:46.825 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=5, callback=168, payload=05 03 26 01 00
2019-01-28 23:13:46.828 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 06 31 05 04 22 00 00
2019-01-28 23:13:46.830 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=168, expected=SendData, cancelled=false MISMATCH
