Hi All,
I’m having a difficult day with OpenHab!
I simply can’t get the .state command to work for me.
I have a rule that runs when an item called setpos is updated.
rule “Timer Transformation”
Item setpos received update
logDebug("rule_debug","Timer Transformation Rule Starting")
logDebug("rule_debug", setpos.state)
val String payload = setpos.state
logDebug("rule_debug", payload)
val String payload = payload.substring(1,3)
postUpdate(setpos1, payload)
This doesn’t work and the only log I get is the first one. To note is that setpos is a mix of text and numbers.
Does this problem have anything to do with formatting of strings?
