States mapping (transformations)
as i read in the other thread, there are no possibilities at the moment to deal with mappings/transformations right in the dashboard, without creating a separate item and a rule to fill up that separate item.
Is there a chance to implement that into HAPpanel? Something like using “MAP(weather_de.map):%s” instead of just %s or nothing in the appropriate field while creating a widget.
Cheers
I have requested a new widget as per the following
If you like the idea or have ideas to improve on it then please comment.
I do transforms this way since habpanel dont really support it natively..
<div ng-if="itemValue('Lower_LivingRoom_Motion_Sensor')=='OPEN'">
  <span style="color: red; font-size: 8pt">MOTION!</span>
</div>
<div ng-if="itemValue('Lower_LivingRoom_Motion_Sensor')=='CLOSED'">
  <span style="color: green; font-size: 8pt">NONE</span>
</div
works really well
Is there a way to get this code in to a dummy widget, and link it to a .map file ?
