mdepablo
(Miguel Angel De Pablo)
May 30, 2019, 10:43am
#1
Hello
I’m trying to run a rule to know the wind direction with the data that come from openweather, but it does not change the item, I was wondering if you know why, here are my sitemap and items.
Item LocalWeatherAndForecast_Current_WindDirection changed
if(LocalWeatherAndForecast_Current_WindDirection.state > 0 || LocalWeatherAndForecast_Current_WindDirection.state < 49.9 ) {
direc_viento.postUpdate(" N ")
logInfo("TIEMPO", "DIRECCION CAMBIADA N")
if(LocalWeatherAndForecast_Current_WindDirection.state > 50 || LocalWeatherAndForecast_Current_WindDirection.state < 89.9 ) {
direc_viento.postUpdate(" NE ")
logInfo("TIEMPO", "DIRECCION CAMBIADA NE")
if(LocalWeatherAndForecast_Current_WindDirection.state > 90 || LocalWeatherAndForecast_Current_WindDirection.state < 129.9 ) {
direc_viento.postUpdate(" E ")
logInfo("TIEMPO", "DIRECCION CAMBIADA E")
if(LocalWeatherAndForecast_Current_WindDirection.state > 130 || LocalWeatherAndForecast_Current_WindDirection.state < 179.9 ) {
direc_viento.postUpdate(" SE ")
logInfo("TIEMPO", "DIRECCION CAMBIADA SE")
if(LocalWeatherAndForecast_Current_WindDirection.state > 180 || LocalWeatherAndForecast_Current_WindDirection.state < 229.9 ) {
direc_viento.postUpdate(" S ")
logInfo("TIEMPO", "DIRECCION CAMBIADA S")
if(LocalWeatherAndForecast_Current_WindDirection.state > 230 || LocalWeatherAndForecast_Current_WindDirection.state < 269.9 ) {
direc_viento.postUpdate(" SW ")
logInfo("TIEMPO", "DIRECCION CAMBIADA SW")
if(LocalWeatherAndForecast_Current_WindDirection.state > 270 || LocalWeatherAndForecast_Current_WindDirection.state < 319.9 ) {
direc_viento.postUpdate(" W ")
logInfo("TIEMPO", "DIRECCION CAMBIADA W")
if(LocalWeatherAndForecast_Current_WindDirection.state > 320 || LocalWeatherAndForecast_Current_WindDirection.state < 360 ) {
direc_viento.postUpdate(" OW ")
logInfo("TIEMPO", "DIRECCION CAMBIADA OW")
ITEMS
String direc_viento "direccion del viento [%s] " >
greetings and I await your answers
opus
(Jürgen Baginski)
May 30, 2019, 10:49am
#2
Do any of the logInfo statements show in your log?
Additionally your conversion of directions is wrong!
rossko57
(Rossko57)
May 30, 2019, 11:13am
#3
I’ll bet LocalWeatherAndForecast_Current_WindDirection
has UoM and is expressed in degrees. (a Number:Angle type)
You’d need to extract the number part only, or compare with angles.
mdepablo
May 30, 2019, 11:16am
#4
thanks for the speed of response
nothing comes out in the log
Why is the conversion incorrect?
mdepablo
May 30, 2019, 11:17am
#5
that item gives a number in degrees that’s why my conversion attempt
rossko57
(Rossko57)
May 30, 2019, 11:22am
#6
Yep, so you are comparing apples with oranges.
32 ° > 30
Try
if(LocalWeatherAndForecast_Current_WindDirection.state > 0 | "°" ....
to get both sides in degrees.
opus
(Jürgen Baginski)
May 30, 2019, 11:36am
#7
When using 8 steps (N, NE, E,SE, S, SW, W, NW) each step has 45 degrees, the one for N goes from 337,5 over 360 to 22,5.
There are no log entries because of the problem mentioned by @rossko57
mdepablo
May 30, 2019, 3:08pm
#8
I think I understand the fault, but when doing the rule to the system I would not give the same unit that puts only should act on the number, I do not know if I explained, and if not how I could fix it
opus
(Jürgen Baginski)
May 30, 2019, 3:12pm
#9
Did you try the example as given by @rossko57 ?
rossko57
(Rossko57)
May 30, 2019, 3:47pm
#10
If you mean “how do I get just the number part of a number with units”?
(MyItem.state as quantityType).intValue
mdepablo
May 31, 2019, 10:57am
#11
thanks for the help @rossko57 but I do not know how to use it, I searched but I do not see how, you can give me a little light
rossko57
(Rossko57)
May 31, 2019, 11:02am
#12
Instead of
use
if ( (LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue > 0 || ...
I think to save typing I’d do it once.
var Number xx = (LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue
if ( xx > 0 || xx < 50 ) {
mdepablo
May 31, 2019, 2:20pm
#13
thank you very much, the first part if I understand it I think it would be like that
`rule “cambio de direccion”
Item LocalWeatherAndForecast_Current_WindDirection received update
if((LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue > 0 || (LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue < 49.9 ) {
if((LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue > 50 || (LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue < 89.9 ) {
if((LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue > 90 || (LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue < 129.9 ) {
if((LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue > 130 || (LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue < 179.9 ) {
if((LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue > 180 || (LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue < 229.9 ) {
if((LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue > 230 || (LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue < 269.9 ) {
if((LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue > 270 || (LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue < 319.9 ) {
if((LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue > 320 || (LocalWeatherAndForecast_Current_WindDirection.state as QuantityType<Number>).intValue < 360 ) {
I’m sorry but the second part I do not understand
when the rule works we will start if the conversion of the degrees is correct @opus
opus
(Jürgen Baginski)
May 31, 2019, 6:12pm
#14
For a solution look into that one .
mdepablo
May 31, 2019, 9:10pm
#15
hello the rule already works … but badly this is the log
2019-05-31 22:12:26.606 [INFO ] [clipse.smarthome.model.script.TIEMPO] - DIRECCION CAMBIADA N
2019-05-31 22:12:26.651 [INFO ] [clipse.smarthome.model.script.TIEMPO] - DIRECCION CAMBIADA NE
2019-05-31 22:12:26.695 [INFO ] [clipse.smarthome.model.script.TIEMPO] - DIRECCION CAMBIADA E
2019-05-31 22:12:26.753 [INFO ] [clipse.smarthome.model.script.TIEMPO] - DIRECCION CAMBIADA SE
2019-05-31 22:12:26.787 [INFO ] [clipse.smarthome.model.script.TIEMPO] - DIRECCION CAMBIADA S
2019-05-31 22:12:26.814 [INFO ] [clipse.smarthome.model.script.TIEMPO] - DIRECCION CAMBIADA SW
2019-05-31 22:12:26.839 [INFO ] [clipse.smarthome.model.script.TIEMPO] - DIRECCION CAMBIADA W
2019-05-31 22:12:26.867 [INFO ] [clipse.smarthome.model.script.TIEMPO] - DIRECCION CAMBIADA OW
he ignores the more and less, and I do not understand why.
thank you very much @opus then I will see how to modify the values
rossko57
(Rossko57)
May 31, 2019, 10:14pm
#16
You haven’t asked for more and less, you wrote more or less. Try
if ( xx >= 0 && xx < 50 )
mdepablo
June 1, 2019, 6:30pm
#17
thank you very much to the two already works perfectly with this doubt I have learned to handle the variables “and, or”
