I am running openHAB 4.0.3 on openHABian on a RPI4 / 8GB. With this, I connect to a Rademacher HomePilot using the HTTP binding to communicate with the JSON interface. This is described in various posts (e.g. here) and is generally working.
Nevertheless, I encountered an issue I don’t have an explanation for.
My HomePilot and its attached smarthome system is… huge. 80+ physical and 200+ virtual devices. This gives it quite a job to read, but it’s not too bad, as I found out that there are two status addresses which contain more or less all measurement data I need. Each of these addresses answer with a large JSON file. I’d like to update this every 5 seconds. As I got HTTP timeouts, I added a delay of 100ms which made it working well at first. Here is the config:
UID: http:url:HomePilot
label: HomePilot
thingTypeUID: http:url
configuration:
authMode: BASIC
ignoreSSLErrors: true
baseURL: http://<HomePilotURL>
delay: 100
stateMethod: GET
refresh: 5
commandMethod: PUT
contentType: application/json
timeout: 3000
bufferSize: 2048
Here is an example of some channel configurations:
- id: Heizung_Arbeitszimmer_Istwert
channelTypeUID: http:number
label: Heizung Arbeitszimmer Istwert
description: null
configuration:
mode: READONLY
escapedUrl: false
stateExtension: /v4/devices
stateTransformation: JSONPATH:$.devices[?(@.did==<myDID>)].statusesMap.acttemperatur∩JS:toDegrees.js
- id: Heizung_Arbeitszimmer_Sollwert
label: Heizung Arbeitszimmer Sollwert
description: null
configuration:
mode: READONLY
escapedUrl: false
stateTransformation: JSONPATH:$.devices[?(@.did==<myDID>)].statusesMap.Position∩JS:toDegrees.js
with this kind of configurations growing, especially one time when I saw that this is generally working and copy-pasted over 100 of such configs into my .things file, I suddenly ended up with an error in the logfile:
2023-09-23 21:45:05.444 [WARN ] [nding.http.internal.HttpThingHandler] - 134 channels in thing http:url:HomePilot with a delay of 100 incompatible with the configured refresh time. Refresh-Time increased to the minimum of 14
This kind of surprised me heavily. There is one thing which is common to all of these many, many configurations: they all have the stateExtension: /v4/devices.
From all I have read in the forum and the docs, I would have expected that this would not happen due to the automatic caching of the HTTP binding. It should query http://<HomePilotURL>/v4/devices once every five seconds, store it in the cache and work through the parsing work for all channels with this stateExtension using the cached data.
I additionally checked that adding n channels with stateExtension: /v4/devices leads to the number in the log warning growing by n as well.
Of course I cannot tell if either I am doing something wrong, misunderstood something, the pre-check which issues the warning is wrong or the caching as such is really not working as expected. Therefore I would like to ask for help here.
