The max luminance value is 2000, so perhaps you have some sort of division going on there? What do your items entries look like?
I agree the switches seem a bit weird. I can switch the lights on with “Switch” and off with “Power”. They only come on for the time period set though. I was expecting one switch which I could use like a normal light switch. I’ve not spent time fiddling to see if I can improve this.
I only have created items for all data point the thing have, but only you displaying at them moment. I have no rules interacting with these items. I display them all via the attached group…
I’ve got one of these, currently working well. I set it to work in Slave mode and to time out the motion events after 10 seconds, just using it as an external trigger to my openhab setup which then controls the relay directly. With the latest snapshot it’s working well, even the luminance sensor is working, showing 0-2000 and back at dawn and dusk but it tops out at 2000 all day – this is fine for me.
It does go off occasionally when there is no movement, this is normally due to strong sunlight, a common problem with PIR sensors.
Do you mean the device goes offline and needs to be power-cycled to bring it back? I had this too but setting the controller to the lifeline group (and no other associations set), using the latest snapshot, it’s been online for a few days now without freezing.
There is also a setting I haven’t seen before, disabling checking of the controller, which may also prevent freezing. This is bit 2 of parameter 9. I’m trying that now.
As this device seems to have some “features” that users might need to implement, can I ask someone to provide this information into the database? @tarcus - it looks like you might be heading toward the local expert status ?
The database has a “Usage Information” box which is intended as a place to add information that people might find useful (or necessary!) when using the device. This is a reasonably new feature in the database, and it’s not used much (yet anyway), but the idea is to feed this into the documentation that gets generated. This way, hopefully people can find it rather than having to search through the forum, which I know can be difficult.
If people can take a few minutes to add information into this, then I think it will benefit the community .
The only thing I’ve found so far to add over the documentation (which is what I used to set mine up) is that using it in slave mode, with the controller in the “lifeline” association group and the “Key01” association group, means I get movement on/off messages to alarm_burglar1 with an extra off (for some reason). I then control the relay directly via openhab.
While I’m happy to add something to the documentation, I don’t want to do it just yet as I’m still working out minor bugs, once I’m happy I’ve got both the polling loop sorted, the on/off alerts on motion working fully, and it can survive a network heal (my system has some devices that work before the heal but not after), I’ll throw some words together.
That’s cool - no problem, and also no pressure . I’m just trying to raise awareness of this feature in an effort to improve the overall documentation in the longer term.
Yep it will be helpful, particularly on devices like the Steinel which would be great if they were a bit easier to set up… So some advice from those who have gone before would certainly be useful.
My neighbours think I’m mad because I keep leaning out of my back door and waving…
You can make it act like a separate PIR, Lux sensor and relay by setting slave mode, set parameter 9 to “1” or use the new snapshot’s settings to enable slave mode and disable central controller checking. Then you can control the switch via the Power entry and use the “Time” parameter (number 1) to control how long the motion detector stays on for. At first it seems to turn the light on and off itself but quickly settles down and just sends back on/off messages to the alarm_burglar1 channel. I’ll get around to writing something up at some point.
My Steinel XLED was working quite well although I never understood why there are two luminance values while for me only luminance 2 is working. Or better was working I should say as my installation doesn’t receive any values anymore within the last four weeks - maybe in connection with upgrading to the lastest snapshots releases in this period?
2000 is the maximum that the sensor can read. I’ll have to check the minimum reading that I get when it’s dark. It depends on how often the sensor is set to poll and how quickly it gets light in the morning to how many steps occur in the change. My next step in your situation would be to check the update interval, you can set up a rule to show what time that update happens, let me know if you need that and I’ll work out what I’m doing.
I checked the update interval and changed it from 1 day to 10 minutes.
I can see in the log that no updates arrive from this item. The question is why did it work before even with a lower polling period and what led to the malfunction of luminance in my case.
