I have had this device for 2 years now - and it has worked wonderfully until about 2 months ago. I cannot replicate if this has to do with an OH upgrade (am currently on 2.5.3).
It comes up online in my things-list - but I dont get any updates from the device at all anymore. I have looked in the logs and used Chris’ log-tool to look at it as well - but nothing.
did you managed to get the device working? I bought it newly, the device seems to be working, I can it add to the network, but it does not send any data to controller. At least in papper ui I do not see any updates of illuminance sensor, neither motion sensor send any data.
What is the proper configuration? I set slave mode, but is the same.
It looks to me that the docs specify 1 to 4, which is what is in the database, except someone has also added Group 0 which doesn’t exist. I’ve removed group 0, and I think that this is correct.
Ah - just looked in the other manual on the database, and it shows 1 to 5, so there are possibly different versions of this device. I think it’s fine for now to leave this as 1 to 4 - if someone complains about group 5 missing then we might need to split this into two devices.
