Hi all,
I have a strange behaviour with a Steinel MotionSwitchLED (zwave version 1.132).
Tracking down problems with toggling motion events (ping pong between on and off events), I started from scratch with factory defaults.
Configuration (Factory defaults, Slave mode, Live line association set to controller):
UID: zwave:device:2622dc76:node91
label: Heizungskeller_MotionSwitchLED2
thingTypeUID: zwave:steinel_motionswitchled_00_000
configuration:
config_10_2: 10
group_5: []
group_4: []
group_7: []
group_6: []
group_1: controller
group_3: []
group_2: []
config_1_2: 180
config_19_2: 103
config_16_2: 0
config_17_1: 8
config_8_1: 1
config_12_2: 204
config_18_1: 1
config_9_1: 2
config_11_2: 255
config_2_2: 2000
config_13_2: 204
config_5_1: 100
config_14_2: 204
config_15_1: 10
node_id: 91
config_6_1: 0
bridgeUID: zwave:serial_zstick:2622dc76
The LED of the motion switch is triggered automatically (no slave mode).
After initialization, and setting up the live line association, I see one event on an item (switch) linked to the alarm_burglar1 channel (NULL → OFF). When I trigger a motion, I don’t see a corresponing item change. The LED (switch_binary3) switches on correctly, also the item change is shown.
Looking to the logs I see the following:
- (Triggering a motion while LED is OFF):
pi@raspberry1:~ $ openhab-cli showlogs | grep "NODE 91"
2021-07-29 14:40:31.660 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 91: Application Command Request (ALIVE:STATIC_VALUES)
2021-07-29 14:40:31.661 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 91: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2021-07-29 14:40:31.662 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 91: Incoming command class COMMAND_CLASS_ALARM, endpoint 1
2021-07-29 14:40:31.663 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 91: SECURITY NOT required on COMMAND_CLASS_ALARM
2021-07-29 14:40:31.664 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 91: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2021-07-29 14:40:31.665 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 91: NOTIFICATION report - 0 = 0, event=8, status=255, plen=0
2021-07-29 14:40:31.666 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 91: Alarm Type = BURGLAR (0)
2021-07-29 14:40:31.667 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 91: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2021-07-29 14:40:31.668 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 91: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_ALARM, value=255
2021-07-29 14:40:31.670 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 91: Alarm converter processing NOTIFICATION
2021-07-29 14:40:31.671 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 91: Alarm converter NOTIFICATION event is 8, type OnOffType
2021-07-29 14:40:31.672 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 91: Commands processed 1.
2021-07-29 14:40:31.674 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 91: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4a9ed1.
2021-07-29 14:40:31.689 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 91: Application Command Request (ALIVE:STATIC_VALUES)
2021-07-29 14:40:31.690 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 91: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2021-07-29 14:40:31.691 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 91: Incoming command class COMMAND_CLASS_SWITCH_BINARY, endpoint 3
2021-07-29 14:40:31.692 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 91: SECURITY NOT required on COMMAND_CLASS_SWITCH_BINARY
2021-07-29 14:40:31.693 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 91: Received COMMAND_CLASS_SWITCH_BINARY V1 SWITCH_BINARY_REPORT
2021-07-29 14:40:31.695 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 91: Switch Binary report, value = 255
2021-07-29 14:40:31.696 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 91: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2021-07-29 14:40:31.697 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 91: Got a value event from Z-Wave network, endpoint=3, command class=COMMAND_CLASS_SWITCH_BINARY, value=255
2021-07-29 14:40:31.699 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 91: Updating channel state zwave:device:2622dc76:node91:switch_binary3 to ON [OnOffType]
2021-07-29 14:40:31.700 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 91: Commands processed 1.
2021-07-29 14:40:31.702 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 91: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@374351.
2021-07-29 14:40:38.147 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 91: Application Command Request (ALIVE:STATIC_VALUES)
2021-07-29 14:40:38.148 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 91: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2021-07-29 14:40:38.149 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 91: Incoming command class COMMAND_CLASS_ALARM, endpoint 1
2021-07-29 14:40:38.151 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 91: SECURITY NOT required on COMMAND_CLASS_ALARM
2021-07-29 14:40:38.152 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 91: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2021-07-29 14:40:38.153 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 91: NOTIFICATION report - 0 = 0, event=0, status=255, plen=1
2021-07-29 14:40:38.155 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 91: Alarm Type = BURGLAR (0)
2021-07-29 14:40:38.156 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 91: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2021-07-29 14:40:38.158 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 91: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_ALARM, value=255
2021-07-29 14:40:38.160 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 91: Alarm converter processing NOTIFICATION
2021-07-29 14:40:38.161 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 91: Alarm converter NOTIFICATION event is 0, type OnOffType
2021-07-29 14:40:38.162 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 91: Updating channel state zwave:device:2622dc76:node91:alarm_burglar1 to OFF [OnOffType]
2021-07-29 14:40:38.164 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 91: Commands processed 1.
2021-07-29 14:40:38.166 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 91: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1cb6ccc.
Not being an expert in zwave, I would assume, that this corresponds to:
alarm_burglar1 → ON/ALARM (Alarm converter NOTIFICATION event is 8, type OnOffType)
switch_binary3 → ON (Updating channel state zwave:device:2622dc76:node91:switch_binary3 to ON [OnOffType])
alarm_burglar1 → OFF (Alarm converter NOTIFICATION event is 0, type OnOffType)
switch_binary3 correctly changes to OFF after 180 seconds.
If I trigger a motion event while the LED is ON, I get a similar response:
2021-07-29 14:41:04.004 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 91: Application Command Request (ALIVE:STATIC_VALUES)
2021-07-29 14:41:04.006 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 91: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2021-07-29 14:41:04.007 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 91: Incoming command class COMMAND_CLASS_ALARM, endpoint 1
2021-07-29 14:41:04.009 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 91: SECURITY NOT required on COMMAND_CLASS_ALARM
2021-07-29 14:41:04.010 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 91: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2021-07-29 14:41:04.011 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 91: NOTIFICATION report - 0 = 0, event=8, status=255, plen=0
2021-07-29 14:41:04.012 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 91: Alarm Type = BURGLAR (0)
2021-07-29 14:41:04.014 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 91: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2021-07-29 14:41:04.015 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 91: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_ALARM, value=255
2021-07-29 14:41:04.016 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 91: Alarm converter processing NOTIFICATION
2021-07-29 14:41:04.017 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 91: Alarm converter NOTIFICATION event is 8, type OnOffType
2021-07-29 14:41:04.019 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 91: Commands processed 1.
2021-07-29 14:41:04.020 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 91: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1ac4221.
2021-07-29 14:41:10.102 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 91: Application Command Request (ALIVE:STATIC_VALUES)
2021-07-29 14:41:10.104 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 91: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2021-07-29 14:41:10.105 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 91: Incoming command class COMMAND_CLASS_ALARM, endpoint 1
2021-07-29 14:41:10.107 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 91: SECURITY NOT required on COMMAND_CLASS_ALARM
2021-07-29 14:41:10.109 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 91: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2021-07-29 14:41:10.110 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 91: NOTIFICATION report - 0 = 0, event=0, status=255, plen=1
2021-07-29 14:41:10.112 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 91: Alarm Type = BURGLAR (0)
2021-07-29 14:41:10.114 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 91: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2021-07-29 14:41:10.115 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 91: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_ALARM, value=255
2021-07-29 14:41:10.117 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 91: Alarm converter processing NOTIFICATION
2021-07-29 14:41:10.119 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 91: Alarm converter NOTIFICATION event is 0, type OnOffType
2021-07-29 14:41:10.121 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 91: Updating channel state zwave:device:2622dc76:node91:alarm_burglar1 to OFF [OnOffType]
2021-07-29 14:41:10.123 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 91: Commands processed 1.
2021-07-29 14:41:10.126 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 91: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@b5e5e.
corresponding to
alarm_burglar1 → ON
It seems like the event
is not correctly mapped to ON?
Or do I have any misconfiguration, e.g. do I have to link another type of item? (some kind of Boolean item?)
The strange thing is, that for another MotionSwitchLED device the item changes correctly (but with the mentioned strange ping pong behaviour (and in slave mode)):
2021-07-29 18:24:11.678 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Application Command Request (ALIVE:ASSOCIATIONS)
2021-07-29 18:24:11.680 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2021-07-29 18:24:11.681 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: Incoming command class COMMAND_CLASS_ALARM, endpoint 1
2021-07-29 18:24:11.682 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: SECURITY NOT required on COMMAND_CLASS_ALARM
2021-07-29 18:24:11.683 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 90: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2021-07-29 18:24:11.686 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 90: NOTIFICATION report - 0 = 0, event=0, status=255, plen=1
2021-07-29 18:24:11.687 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 90: Alarm Type = BURGLAR (0)
2021-07-29 18:24:11.688 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 90: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2021-07-29 18:24:11.690 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 90: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_ALARM, value=255
2021-07-29 18:24:11.691 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 90: Alarm converter processing NOTIFICATION
2021-07-29 18:24:11.692 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 90: Alarm converter NOTIFICATION event is 0, type OnOffType
2021-07-29 18:24:11.694 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 90: Updating channel state zwave:device:2622dc76:node90:alarm_burglar1 to OFF [OnOffType]
2021-07-29 18:24:11.695 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Commands processed 1.
2021-07-29 18:24:11.696 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@14f8c2f.
2021-07-29 18:24:11.764 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Application Command Request (ALIVE:ASSOCIATIONS)
2021-07-29 18:24:11.765 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2021-07-29 18:24:11.766 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: Incoming command class COMMAND_CLASS_ALARM, endpoint 1
2021-07-29 18:24:11.768 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: SECURITY NOT required on COMMAND_CLASS_ALARM
2021-07-29 18:24:11.770 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 90: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2021-07-29 18:24:11.772 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 90: NOTIFICATION report - 0 = 0, event=0, status=255, plen=1
2021-07-29 18:24:11.774 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 90: Alarm Type = BURGLAR (0)
2021-07-29 18:24:11.775 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 90: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2021-07-29 18:24:11.776 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 90: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_ALARM, value=255
2021-07-29 18:24:11.778 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 90: Alarm converter processing NOTIFICATION
2021-07-29 18:24:11.780 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 90: Alarm converter NOTIFICATION event is 0, type OnOffType
2021-07-29 18:24:11.782 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 90: Updating channel state zwave:device:2622dc76:node90:alarm_burglar1 to OFF [OnOffType]
2021-07-29 18:24:11.783 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Commands processed 1.
2021-07-29 18:24:11.785 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@fc3c8f.
2021-07-29 18:24:11.810 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Application Command Request (ALIVE:ASSOCIATIONS)
2021-07-29 18:24:11.811 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2021-07-29 18:24:11.813 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: Incoming command class COMMAND_CLASS_ALARM, endpoint 1
2021-07-29 18:24:11.814 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: SECURITY NOT required on COMMAND_CLASS_ALARM
2021-07-29 18:24:11.815 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 90: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2021-07-29 18:24:11.817 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 90: NOTIFICATION report - 0 = 0, event=8, status=255, plen=0
2021-07-29 18:24:11.821 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 90: Alarm Type = BURGLAR (0)
2021-07-29 18:24:11.823 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 90: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2021-07-29 18:24:11.824 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 90: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_ALARM, value=255
2021-07-29 18:24:11.826 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 90: Alarm converter processing NOTIFICATION
2021-07-29 18:24:11.828 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 90: Alarm converter NOTIFICATION event is 8, type OnOffType
2021-07-29 18:24:11.829 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Commands processed 1.
2021-07-29 18:24:11.831 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@902cce.
2021-07-29 18:24:11.840 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Application Command Request (ALIVE:ASSOCIATIONS)
2021-07-29 18:24:11.842 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2021-07-29 18:24:11.846 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: Incoming command class COMMAND_CLASS_ALARM, endpoint 1
2021-07-29 18:24:11.847 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: SECURITY NOT required on COMMAND_CLASS_ALARM
2021-07-29 18:24:11.849 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 90: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2021-07-29 18:24:11.850 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 90: NOTIFICATION report - 0 = 0, event=8, status=255, plen=0
2021-07-29 18:24:11.851 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 90: Alarm Type = BURGLAR (0)
2021-07-29 18:24:11.853 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 90: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2021-07-29 18:24:11.854 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 90: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_ALARM, value=255
2021-07-29 18:24:11.856 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 90: Alarm converter processing NOTIFICATION
2021-07-29 18:24:11.857 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 90: Alarm converter NOTIFICATION event is 8, type OnOffType
2021-07-29 18:24:11.858 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Commands processed 1.
2021-07-29 18:24:11.859 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@fb4f20.
2021-07-29 18:24:11.907 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Application Command Request (ALIVE:ASSOCIATIONS)
2021-07-29 18:24:11.909 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2021-07-29 18:24:11.910 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: Incoming command class COMMAND_CLASS_ALARM, endpoint 1
2021-07-29 18:24:11.911 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: SECURITY NOT required on COMMAND_CLASS_ALARM
2021-07-29 18:24:11.912 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 90: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2021-07-29 18:24:11.914 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 90: NOTIFICATION report - 0 = 0, event=8, status=255, plen=0
2021-07-29 18:24:11.915 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 90: Alarm Type = BURGLAR (0)
2021-07-29 18:24:11.916 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 90: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2021-07-29 18:24:11.918 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 90: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_ALARM, value=255
2021-07-29 18:24:11.919 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 90: Alarm converter processing NOTIFICATION
2021-07-29 18:24:11.920 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 90: Alarm converter NOTIFICATION event is 8, type OnOffType
2021-07-29 18:24:11.922 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Commands processed 1.
2021-07-29 18:24:11.923 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1ba81a4.
2021-07-29 18:24:11.937 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Application Command Request (ALIVE:ASSOCIATIONS)
2021-07-29 18:24:11.940 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2021-07-29 18:24:11.942 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: Incoming command class COMMAND_CLASS_ALARM, endpoint 1
2021-07-29 18:24:11.944 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: SECURITY NOT required on COMMAND_CLASS_ALARM
2021-07-29 18:24:11.945 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 90: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2021-07-29 18:24:11.947 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 90: NOTIFICATION report - 0 = 0, event=8, status=255, plen=0
2021-07-29 18:24:11.948 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 90: Alarm Type = BURGLAR (0)
2021-07-29 18:24:11.950 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 90: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2021-07-29 18:24:11.951 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 90: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_ALARM, value=255
2021-07-29 18:24:11.953 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 90: Alarm converter processing NOTIFICATION
2021-07-29 18:24:11.954 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 90: Alarm converter NOTIFICATION event is 8, type OnOffType
2021-07-29 18:24:11.956 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Commands processed 1.
2021-07-29 18:24:11.957 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@6fc4d8.
2021-07-29 18:24:12.000 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Application Command Request (ALIVE:ASSOCIATIONS)
2021-07-29 18:24:12.001 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2021-07-29 18:24:12.002 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: Incoming command class COMMAND_CLASS_BASIC, endpoint 1
2021-07-29 18:24:12.003 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 90: SECURITY NOT required on COMMAND_CLASS_BASIC
2021-07-29 18:24:12.004 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 90: Received COMMAND_CLASS_BASIC V0 BASIC_SET
2021-07-29 18:24:12.006 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 90: Basic report, value = 255
2021-07-29 18:24:12.007 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 90: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2021-07-29 18:24:12.008 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 90: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_BASIC, value=255
2021-07-29 18:24:12.010 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 90: Updating channel state zwave:device:2622dc76:node90:alarm_burglar1 to ON [OnOffType]
2021-07-29 18:24:12.012 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Commands processed 1.
2021-07-29 18:24:12.013 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 90: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1466e47.
Thanks in advance!
