Still 1067 Installation error .. Windows 10
First up apologies.. it seems that versions of this error have been reported before .. but none of the answers so far help me.
openHAB2 Version 2.2.0
Running Windows 10 .. 64 .. Build 1709
Tried the latest versions of both JRE and JDK JAVA.. echo show pointing to the versions
Everything goes well until I enter the Admin Command Prompt
C:\openHAB2\userdata\bin\openHAB2-service.bat install seems to go as it should .. I get the next line prompt
net start “openHAB2”
Microsoft Windows [Version 10.0.16299.192]
(c) 2017 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>c:\openHAB2\userdata\bin\openHAB2-service.bat install
wrapper  | openHAB2 installed.
C:\WINDOWS\system32>net start "openHAB2"
The openHAB2 service is starting.
The openHAB2 service could not be started.
A system error has occurred.
System error 1067 has occurred.
The process terminated unexpectedly.
The openHAB log shows
2018-02-04 16:11:38.106 [ERROR] [.service.internal.HttpServiceStarted] - Could not start the servlet context for context path []
java.net.BindException: Address already in use: bind
	at sun.nio.ch.Net.bind0(Native Method)[:1.8.0_162]
	at sun.nio.ch.Net.bind(Unknown Source)[:1.8.0_162]
	at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source)[:1.8.0_162]
	at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source)[:1.8.0_162]
	at org.eclipse.jetty.server.ServerConnector.open(ServerConnector.java:321)
	at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:80)
	at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:236)
	at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
	at org.eclipse.jetty.server.Server.doStart(Server.java:366)
	at org.ops4j.pax.web.service.jetty.internal.JettyServerImpl$1.start(JettyServerImpl.java:287)
	at org.ops4j.pax.web.service.internal.HttpServiceStarted.registerServlet(HttpServiceStarted.java:222)
	at org.ops4j.pax.web.service.internal.HttpServiceStarted.registerServlet(HttpServiceStarted.java:196)
	at org.ops4j.pax.web.service.internal.HttpServiceStarted.registerServlet(HttpServiceStarted.java:180)
	at org.ops4j.pax.web.service.internal.HttpServiceProxy.registerServlet(HttpServiceProxy.java:64)
	at org.eclipse.smarthome.ui.icon.internal.IconServlet.activate(IconServlet.java:79)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_162]
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)[:1.8.0_162]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)[:1.8.0_162]
	at java.lang.reflect.Method.invoke(Unknown Source)[:1.8.0_162]
	at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:224)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:617)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:501)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:302)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:294)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:297)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:108)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:748)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:429)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:403)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:278)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)[31:org.apache.felix.scr:2.0.6]
	at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)[31:org.apache.felix.scr:2.0.6]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482)[org.osgi.core-6.0.0.jar:]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415)[org.osgi.core-6.0.0.jar:]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232)[org.osgi.core-6.0.0.jar:]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)[org.osgi.core-6.0.0.jar:]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.container.Module.start(Module.java:457)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
Does anyone have a suggestion .. or a answer ?
this hints that you have another process running on tcp port 8080.
did you shutdown openHAB console before you tried to start OH with the net start command?
Thank you for that suggestion… releasing the port didn’t fix it directly but did seem to help.
I still needed to do lots more fiddling including texting with JRE and JDK versions of Java.. only JDK seems to actually work here.
Frustratingly I really don’t know what finally got it to work .. it would be nice to be able to pass on the fix…
So no to learn everything else that HAB has to offer, and if it ends up doing what I (think) I want to do.
Cheers
A
