You cannot modify what gets logged in events.log. events.log is logging from the Event Bus. All the statements come from the same class so there is no way to filter anything out. You can either turn off events.log entirely or you can get all events from all Items logged to it.
ok. Thing is, I really don’t need updated items on every run (like weather1 every 15min). And I want to reduce writings on SDCard. But perhaps I just change the logging to either my NAS or an external USB-HD…
Activating WARN loglevel for events, I lose all the other INFO item states, I’d like to have (e.g. for other bindings like KNX or something).
Or turn events.log off. Those are your options. events.log is intended to log everything that happens on the Event Bus. You can’t pick and choose because it isn’t an individual binding making the logs, it is the Event Bus.
It has not and will not change. The events.log is the logger for the Event Bus. The Event Bus doesn’t know where the events are coming from, just that the event occurred.
Log4j does support filters. There are a couple of tutorials on the forum.
Thank you for the answer. I was just looking at my log and pretty much all I see are System_Info logs from my Master and 5 remote servers. Thanks again for all your help.
