Hello Guys.
I’m trying to “store” the old value of a dimmer, before i dim up when movement is detected…
In the rule file i define a “var mem_light”
in the beginning of the rule i try to store the actual value of the dimmer to this value:
“mem_light = outside_dimmer.state” but the compiler wouldn’t allow it… I’ve also tested with the as DecimalType but still no success…
The outside_dimmer is defined in the items as a “Dimmer”
There is no compiler so I’m confused as to what it is that doesn’t allow it. It is unclear if the var is a global or local to a rule/ Dimmer is a reserved word, you should use a more descriptive name for your Items.
If that is a literal writing your Rules file rather than pseudocode, I recommend reviewing the Rules wiki page as that code is syntactically incorrect.
Case matters, there is no such thing as “Var”, “Rule”, or “If” .They are var, rule, and if.
A rule must follow the format described on that wiki page with a rule, when, then and end. There must be a triggering event defined inbetween the when and the then.
Hello… Yes i know - was just porsted from my iPhone - seems like it has changed the words… Anyway, here’s my actual code:
Item file:
Dimmer Spots_Outside_Entreance "Spot i Indhakket" <switch> (Garden
The Rule file:
var mem_outside_light
rule "Udvendigt Lys Nord (Bevægelse)"
Item PIR_Entrance changed
mem_outside_light = Spots_Outside_Entreance.state
if (Lux_Outside_South.state < (Lux_Setpoint_North.state as DecimalType))
sendCommand(Spots_Outside_Entreance, 50)
sendCommand(CUBE_Outside_North, ON)
logInfo("Outside", "Lys tændt på bevægelse")
if (presence_north_timer == null)
presence_north_timer = createTimer(now.plusMinutes(5), [|
logInfo("Outside", "Lys slukket efter timeout på bevægelse")
sendCommand(Spots_Outside_Entreance, 0)
sendCommand(CUBE_Outside_North, OFF)
The smarthome designer doesn’t like the following, where i wanna store the actual value from the dimmer before the rule does anything…
For the past 25-20 days there has been an open issue on Designer where it no longer recognizes Items and Actions. Double check that you don’t have a typo in the Item name for Spots_Outside_Entreance and run it to see if it works. If it doesn’t run, come back and tell us what the error is as reported by Designer and in your logs.
