I had a problem a while back with RPi running Openhab2 after a power outage. Fixed that problem, but in the process did not properly delete prior nodes. Everything has been working fine, except I get a bunch of warnings in my log file.
2017-11-05 14:55:03.561 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '416.001' for item 'ZWaveNode3DSB09HomeEnergyMeter_ElectricMeterKWh' to handler for channel 'zwave:device:899d499c:node3:meter_kwh', because no thing with the UID 'zwave:device:899d499c:node3' could be found.
The working devices have a different code
zwave:device:cce0383e:node3:meter_kwh
I have been living with it but would like to clean it up. Have tried to restart openhab2, but that doesn’t work.
Ideas?
