Hi all,
I transferd my knx items and things files to oh3.
These files look as they are working.
With OH2.10 my knx_01_01_002 device is online and working correctly.
(i can give a picture of that becaus i reinstalled my rpi3 with full new os and oh3)
And i get stranger when i create a new thing and items with files. This one is not working.
my tunnel.things file
Bridge knx:ip:tunnel108 "KNX tunnel" @ "Bridge"
ipAddress="192.168.3.100",
portNumber=3671,
localIp="192.168.3.103",
type="TUNNEL",
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=1,
localSourceAddr="1.1.108"
my knx device.things file
Thing knx:device:knx0101002 "KNX_01_01_002" (knx:ip:tunnel108) @ "WC"
address="1.1.2",
fetch=false,
pingInterval=300,
readInterval=3600
// bediening
Type switch : sw09 "licht wc (sw09)" [ga="0/1/1+<0/1/101"]
Type switch : sw10 "licht boven spiegel (sw10)" [ga="0/1/2+<0/1/102"]
Type switch : sw11 "ventilator (sw11)" [ga="0/1/3+<0/1/103"]
// status terugmelding
Type switch : st09 "status licht wc (st09)" [ga="0/1/101"]
Type switch : st10 "status licht boven spiegel (st10)" [ga="0/1/102"]
Type switch : st11 "status ventilator (st11)" [ga="0/1/103"]
my knxdevice.items file
Switch sw09 "licht wc (sw09) [%s]" <button01> {channel="knx:device:knx0101002:sw09"}
Switch sw10 "licht boven spiegel (sw10) [%s]" <button01> {channel="knx:device:knx0101002:sw10"}
Switch sw11 "ventilator (sw11) [%s]" <button01> {channel="knx:device:knx0101002:sw11"}
Switch st09 "status licht wc (st09) [%s]" <lampgeel> {channel="knx:device:knx0101002:st09"}
Switch st10 "status licht boven spiegel (st10) [%s]" <lampgeel> {channel="knx:device:knx0101002:st10"}
Switch st11 "status ventilator (st11) [%s]" <lampgeel> {channel="knx:device:knx0101002:st11"}
my new added device.things file
Thing knx:device:knx0101050 "KNX_01_01_050" (knx:ip:tunnel108) @ "Badkamer beneden"
address="1.1.50",
fetch=false,
pingInterval=300,
readInterval=3600
Type contact : lock "Lock=0 Unlock=1" [ga="1.017:<0/5/3"]
Type switch : sw100 "sw100 O1" [switch="0/5/5+<0/5/6"]
Type switch : st100 "st100 O1" [switch="0/5/6"]
Type contact : lock100 "lock100 lock=1 unlock=0" [ga="1.017:<0/5/7"]
Type number : seconds100 "seconds100" [ga="13:100:<0/5/8"]
Type number : hours100 "hours100" [ga="7:007:<0/5/9"]
Type number : nrsw100 "nr of switches 100" [ga="12:001:<0/5/25"]
Type number : nrsw100min "nr of switches 100/min." [ga="7:001:<0/5/27"]
Type switch : sw101 "sw101 O2" [switch="0/5/10+<0/5/11"]
Type switch : st101 "st101 O2" [switch="0/5/11"]
Type contact : lock101 "lock101 lock=1 unlock=0" [ga="1.017:<0/5/12"]
Type number : seconds101 "seconds101" [ga="13:100:<0/5/13"]
Type number : hours101 "hours101" [ga="7:007:<0/5/14"]
Type number : nrsw101 "nr of switches 101" [ga="12:001:<0/5/28"]
Type number : nrsw101min "nr of switches 101/min." [ga="7:001:<0/5/29"]
Type switch : sw102 "sw102 O3" [switch="0/5/15+<0/5/16"]
Type switch : st102 "st102 O3" [switch="0/5/16"]
Type contact : lock102 "lock102 lock=1 unlock=0" [ga="1.017:<0/5/17"]
Type number : seconds102 "seconds102" [ga="13:100:<0/5/18"]
Type number : hours102 "hours102" [ga="7:007:<0/5/19"]
Type number : nrsw102 "nr of switches 102" [ga="12:001:<0/5/29"]
Type number : nrsw102min "nr of switches 102/min." [ga="7:001:<0/5/30"]
Type switch : sw103 "sw103 O4" [switch="0/5/20+<0/5/21"]
Type switch : st103 "st103 O4" [switch="0/5/21"]
Type contact : lock103 "lock103 lock=1 unlock=0" [ga="1.017:<0/5/22"]
Type number : seconds103 "seconds103" [ga="13:100:<0/5/23"]
Type number : hours103 "hours103" [ga="7:007:<0/5/24"]
Type number : nrsw103 "nr of switches 103" [ga="12:001:<0/5/31"]
Type number : nrsw103min "nr of switches 103/min." [ga="7:001:<0/5/32"]
my new added device.items file
Contact lock "Lock module [%s]" <signalrood> ["Point"] {channel="knx:device:knx0101050:lock"}
Switch sw100 "O1 sw100 [%s]" <button01> ["Point"] {channel="knx:device:knx0101050:sw100"}
Switch st100 "O1 st100 [%s]" <lampgeel> ["Point"] {channel="knx:device:knx0101050:st100"}
Contact lock100 "O1 lock 100 [%s]" <signalrood> ["Point"] {channel="knx:device:knx0101050:lock100"}
Number seconds100 "O1 seconds 100 [%s]" ["Point"] {channel="knx:device:knx0101050:seconds100"}
Number hours100 "O1 hours 100 [%s]" ["Point"] {channel="knx:device:knx0101050:hours100"}
Number nrsw100 "O1 nr of sw 100 [%s]" ["Point"] {channel="knx:device:knx0101050:nrsw100"}
Number nrsw100min "O1 nr of sw / min 100 [%s]" ["Point"] {channel="knx:device:knx0101050:nrsw100min"}
Switch sw101 "O2 sw101 [%s]" <button01> ["Point"] {channel="knx:device:knx0101050:sw101"}
Switch st101 "O2 st101 [%s]" <lampgeel> ["Point"] {channel="knx:device:knx0101050:st101"}
Contact lock101 "O2 lock 101[%s]" <signalrood> ["Point"] {channel="knx:device:knx0101050:lock101"}
Number seconds101 "O2 seconds 101 [%s]" ["Point"] {channel="knx:device:knx0101050:seconds101"}
Number hours101 "O2 hours 101 [%s]" ["Point"] {channel="knx:device:knx0101050:hours101"}
Number nrsw101 "O2 nr of sw 101 [%s]" ["Point"] {channel="knx:device:knx0101050:nrsw101"}
Number nrsw101min "O2 nr of sw / min 101 [%s]" ["Point"] {channel="knx:device:knx0101050:nrsw101min"}
Switch sw102 "O3 sw102 [%s]" <button01> ["Point"] {channel="knx:device:knx0101050:sw102"}
Switch st102 "O3 st102 [%s]" <lampgeel> ["Point"] {channel="knx:device:knx0101050:st102"}
Contact lock102 "O3 lock 102 [%s]" <signalrood> ["Point"] {channel="knx:device:knx0101050:lock102"}
Number seconds102 "O3 seconds 102 [%s]" ["Point"] {channel="knx:device:knx0101050:seconds102"}
Number hours102 "O3 hours 102 [%s]" ["Point"] {channel="knx:device:knx0101050:hours102"}
Number nrsw102 "O3 nr of sw 102 [%s]" ["Point"] {channel="knx:device:knx0101050:nrsw102"}
Number nrsw102min "O3 nr of sw / min 102 [%s]" ["Point"] {channel="knx:device:knx0101050:nrsw102min"}
Switch sw103 "O4 sw103 [%s]" <button01> ["Point"] {channel="knx:device:knx0101050:sw103"}
Switch st103 "O4 st103 [%s]" <lampgeel> ["Point"] {channel="knx:device:knx0101050:st103"}
Contact lock103 "O4 lock 103[%s]" <signalrood> ["Point"] {channel="knx:device:knx0101050:lock103"}
Number seconds103 "O4 seconds 103 [%s]" ["Point"] {channel="knx:device:knx0101050:seconds103"}
Number hours103 "O4 hours 103 [%s]" ["Point"] {channel="knx:device:knx0101050:hours103"}
Number nrsw103 "O4 nr of sw 103 [%s]" ["Point"] {channel="knx:device:knx0101050:nrsw103"}
Number nrsw103min "O4 nr of sw / min 103 [%s]" ["Point"] {channel="knx:device:knx0101050:nrsw103min"}
some one any idea what is going wrong ?
regards
Ronny
