I got a input with dimmer type, I can’t get this to work no matter how I try, the oddly part is I got similar structure it works. only this one with dimmer type,
I would guess the JSONPATH is returning a value that cannot be parsed into a Number. For example, if the JSONPATH returns "32" or with leading or trailing white space these are not parsable into a Number.
Also, if the device message is exactly stat/sonoff-LED/RESULT {"Dimmer":32} JSONPATH will not work because this is not valid JSON. The stat/sonoff-LED/RESULT part is not valid JSON. You may need to use a REGEX transform instead.
That would be my first guess. Change the Item type to a String and check what your JSONPATH is actually returning in events.log or on the sitemap or in a rule and look for stray characters that would make the result non-parsable into a number. If there are, you may need to move to a REGEX or JS Transform to pull out the data.
