I have a project where i use a GSM modem, am using gammu in order to get data off the modem (network name, signal strength, balance, credit expiry date), i am fetching this through a shell script that run everyhour and export the output to files, and then on the Item level i use exec cat the file to get the value.
It is noticeable that Number items i created populates fast (when page is refreshed or app is opened like the credit and signal strength, while the Network name and expiry date) takes around a couple of seconds (sometimes more ) to populate.
once populated, if i refresh the page it gets blank again, has someone experienced such an issue ?
//GSM Balance
String GSMName "Network Name:" <none> (GSM) {exec="<[/home/pi/meshx86/scripts/ussd/gammumon.sh name:10000:]"}
Number GSMBalance "Balance: [%.3f KD]" <none> (GSM) {exec="<[/home/pi/meshx86/scripts/ussd/getbalance.sh:10000:]"}
String GSMExpDate "Balance Expiary Date:" <none> (GSM) {exec="<[/home/pi/meshx86/scripts/ussd/getexpdate.sh:10000:]"}
Number GSMSignal "Signal Strength [%.1f %%]" <none> (GSM) {exec="<[/home/pi/meshx86/scripts/ussd/gammumon.sh signal:10000:]"}
