Hello Guys..
I am migrating from the KNX v1 to v2 binding, then i need to change all my “Things” to link to items…
so far i created a lot o things, one thing for each knx component i have, but that seems to be generating a lot of unstructured Things that is created…
Was thinking maybe it was better making one “Thing” called “Control Cabinet” - then create all the components i have inside the Control Cabinet here?
Then create another Thing called “PushButtons” and in here make all the pushbuttons…
What has you guys done?
Thing device gulvvarme_control "Gulvvarme aktuator" @ "KNX" [ address="1.1.220", fetch=false, pingInterval=600, readInterval=0 ]
Type number : Ch_A "Channel A" [ ga="5.001:0/3/101+<0/3/102" ]
Type number : Ch_B "Channel B" [ ga="5.001:0/2/101+<0/2/103" ]
Type number : Ch_C "Channel C" [ ga="5.001:0/7/101+<0/7/102" ]
Type number : Ch_D "Channel D" [ ga="5.001:0/1/103+<0/1/104" ]
Type number : Ch_E "Channel E" [ ga="5.001:1/1/101+<1/1/102" ]
Type number : Ch_F "Channel F" [ ga="5.001:1/0/101+<1/0/102" ]
Type number : Ch_G "Channel G" [ ga="5.001:1/3/101+<1/3/102" ]
Type number : Ch_H "Channel H" [ ga="5.001:1/2/103+<1/2/102" ]
Type number : Ch_I "Channel I" [ ga="5.001:2/0/102+<2/0/103" ]
Type number : Ch_J "Channel J" [ ga="5.001:0/3/104+<0/3/103" ]
Type number : Ch_K "Channel K" [ ga="5.001:1/1/103+<1/1/104" ]
//Tryk:
Thing device tp_1 "Tryk ved Hoveddør" @ "KNX" [ address="1.1.100", fetch=false, pingInterval=600, readInterval=0 ]
Type number : Act_Temp "Actual Temperature" [ ga="0/5/100" ]
Type switch : Button_3_R "Button 3 Right 0" [ ga="2/0/2" ]
Thing device tp_2 "Tryk Garage Vest" @ "KNX" [ address="1.1.101", fetch=false, pingInterval=600, readInterval=0 ]
Type number : Act_Temp "Actual Temperature" [ ga="2/0/100" ]
Type switch : Button_1_L "Button 1 Left" [ ga="2/0/10" ]
Type switch : Button_1_R "Button 1 Right" [ ga="2/0/2" ]
Type switch : Button_3_0_R "Button 3.0 Right" [ ga="2/0/40" ]
Type switch : Button_3_1_R "Button 3.1 Right" [ ga="2/0/41" ]
But in the begginning when defining a Thing, the KNX device address is entered - what happens if all in this thing is mixed from multiple knx devices?
