Hello.
Since days I try to setup the openhab within a FreeBSD (jail) environment.
I got it running with homematic (via CCU2) binding and also got some sensors values read out. Also the basic presentation via web is working.
Now the main problem right now is: I’m only managed to run openhab as root user.
I created “openhab” user within a “openhab” group.
I assigned the read/write/execute rights for entire openhab folder to this user/group.
But if I run the same start.sh as openhab user, it happens ‘nothing’.
Just “Launching the openHAB runtime…” as last message.
I did not found any proper guide for this “standard” user case “run openhab as “normal” user”.
Please help.
Thank you in advanced.
