Cheers for that, so i went ahead and installed paho-mqtt as suggested but am still getting the same error message? It all works fine on a seperate Pi but i’d like it to run on the same pi as openhab.
Here’s the code
# Copyright(c) 2018 Khor Chin Heong (koochyrat@gmail.com)
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
import select
import socket
import time
import datetime
import threading
from datetime import timedelta
import paho.mqtt.client as mqtt
DOMAIN = "comfort2"
ALARMSTATETOPIC = DOMAIN+"/alarm"
ALARMCOMMANDTOPIC = DOMAIN+"/alarm/set"
ALARMAVAILABLETOPIC = DOMAIN+"/alarm/online"
ALARMMESSAGETOPIC = DOMAIN+"/alarm/message"
ALARMTIMERTOPIC = DOMAIN+"/alarm/timer"
ALARMINPUTTOPIC = DOMAIN+"/input%d" #input1,input2,... input96 for every input
ALARMVIRTUALINPUTRANGE = range(17,65) #set this according to your system
ALARMINPUTCOMMANDTOPIC = DOMAIN+"/input%d/set" #input17,input18,... input64 for virtual inputs
ALARMNUMBEROFOUTPUTS = 16 #set this according to your system
ALARMOUTPUTTOPIC = DOMAIN+"/output%d" #output1,output2,... for every output
ALARMOUTPUTCOMMANDTOPIC = DOMAIN+"/output%d/set" #output1/set,output2/set,... for every output
ALARMNUMBEROFRESPONSES = 255 #set this according to your system
ALARMRESPONSECOMMANDTOPIC = DOMAIN+"/response%d/set" #response1,response2,... for every response
ALARMNUMBEROFFLAGS = 255 #set this according to your system
ALARMFLAGTOPIC = DOMAIN+"/flag%d" #flag1,flag2,...flag255
ALARMFLAGCOMMANDTOPIC = DOMAIN+"/flag%d/set" #flag1/set,flag2/set,... flag255/set
ALARMNUMBEROFCOUNTERS = 255 # set according to system
ALARMCOUNTERINPUTRANGE = DOMAIN+"/counter%d" #each counter represents a CBus value
ALARMCOUNTERCOMMANDTOPIC = DOMAIN+"/counter%d/set" # set the counter to a value for between 0 (off) to 255 (full on)
MQTTBROKERIP = "localhost"
MQTTBROKERPORT = 1883
MQTTUSERNAME = "comfort"
MQTTPASSWORD = "#######"
COMFORTIP = "######"
COMFORTPORT = 1001
PINCODE = "####"
BUFFER_SIZE = 4096
TIMEOUT = timedelta(seconds=30) #Comfort will disconnect if idle for 120 secs, so make sure this is less than that
RETRY = timedelta(seconds=5)
class ComfortLUUserLoggedIn(object):
def __init__(self, datastr="", user=0):
if datastr:
self.user = int(datastr[2:4], 16)
else:
self.user = int(user)
class ComfortIPInputActivationReport(object):
def __init__(self, datastr="", input=0, state=0):
if datastr:
self.input = int(datastr[2:4], 16)
self.state = int(datastr[4:6], 16)
else:
self.input = int(input)
self.state = int(state)
class ComfortCTCounterActivationReport(object): # in format CT1EFF00 ie CT (counter) 1E = 30; state FF00 = 65280
if datastr:
self.counter = int(datastr[2:4], 16)
self.state = int(datastr[4:6], 16) # Comfort code document says always 4 digits
else:
self.counter = int(counter)
class ComfortOPOutputActivationReport(object):
def __init__(self, datastr="", output=0, state=0):
if datastr:
self.output = int(datastr[2:4], 16)
else:
self.output = int(output)
class ComfortFLFlagActivationReport(object):
def __init__(self, datastr="", flag=0, state=0):
if datastr:
self.flag = int(datastr[2:4], 16)
else:
self.flag = int(flag)
class ComfortZ_ReportAllZones(object):
def __init__(self, data={}):
self.inputs = []
b = (len(data) - 2) // 2 #variable number of zones reported
for i in range(1,b+1):
inputbits = int(data[2*i:2*i+2],16)
for j in range(0,8):
self.inputs.append(ComfortIPInputActivationReport("", 8*(i-1)+1+j,(inputbits>>j) & 1))
class ComfortY_ReportAllOutputs(object):
self.outputs = []
b = (len(data) - 2) // 2 #variable number of outputs reported
outputbits = int(data[2*i:2*i+2],16)
self.outputs.append(ComfortOPOutputActivationReport("", 8*(i-1)+1+j,(outputbits>>j) & 1))
class Comfortf_ReportAllFlags(object):
self.flags = []
b = (len(data) - 4) // 2 #b = 32
for i in range(2,b+2):
flagbits = int(data[2*i:2*i+2],16)
self.flags.append(ComfortFLFlagActivationReport("", 8*(i-2)+1+j,(flagbits>>j) & 1))
#mode = { 00=Off, 01=Away, 02=Night, 03=Day, 04=Vacation }
class ComfortM_SecurityModeReport(object):
self.mode = int(data[2:4],16)
if self.mode == 0: self.modename = "disarmed"
elif self.mode == 1: self.modename = "armed_away"
elif self.mode == 2: self.modename = "armed_night"
elif self.mode == 3: self.modename = "armed_home"
elif self.mode == 4: self.modename = "armed_vacation"
#zone = 00 means system can be armed, no open zones
class ComfortERArmReadyNotReady(object):
self.zone = int(data[2:4],16)
class ComfortAMSystemAlarmReport(object):
self.alarm = int(data[2:4],16)
self.triggered = True #for comfort alarm state Alert, Trouble, Alarm
self.parameter = int(data[4:6],16)
if self.alarm == 0: self.message = "Intruder, Zone "+str(self.parameter)
elif self.alarm == 1: self.message = "Zone "+str(self.parameter)+" Trouble"
elif self.alarm == 2: self.message = "Low Battery"
elif self.alarm == 3: self.message = "Power Failure"
elif self.alarm == 4: self.message = "Phone Trouble"
elif self.alarm == 5: self.message = "Duress"
elif self.alarm == 6: self.message = "Arm Failure"
elif self.alarm == 8: self.message = "Disarm"; self.triggered = False
elif self.alarm == 9: self.message = "Arm"; self.triggered = False
elif self.alarm == 10: self.message = "Tamper"
elif self.alarm == 12: self.message = "Entry Warning, Zone "+str(self.parameter); self.triggered = False
elif self.alarm == 13: self.message = "Alarm Abort"; self.triggered = False
elif self.alarm == 14: self.message = "Siren Tamper"
elif self.alarm == 15: self.message = "Bypass, Zone "+str(self.parameter); self.triggered = False
elif self.alarm == 17: self.message = "Dial Test"; self.triggered = False
elif self.alarm == 19: self.message = "Entry Alert, Zone "+str(self.parameter); self.triggered = False
elif self.alarm == 20: self.message = "Fire"
elif self.alarm == 21: self.message = "Panic"
elif self.alarm == 22: self.message = "GSM Trouble"
elif self.alarm == 23: self.message = "New Message"; self.triggered = False
elif self.alarm == 24: self.message = "Doorbell"; self.triggered = False
elif self.alarm == 25: self.message = "Comms Failure RS485"
elif self.alarm == 26: self.message = "Signin Tamper"
class ComfortEXEntryExitDelayStarted(object):
self.type = int(data[2:4],16)
self.delay = int(data[4:6],16)
class Comfort2(mqtt.Client):
def init(self, mqtt_ip, mqtt_port, mqtt_username, mqtt_password, comfort_ip, comfort_port, comfort_pincode):
self.mqtt_ip = mqtt_ip
self.mqtt_port = mqtt_port
self.comfort_ip = comfort_ip
self.comfort_port = comfort_port
self.comfort_pincode = comfort_pincode
self.connected = False
self.username_pw_set(mqtt_username, mqtt_password)
# The callback for when the client receives a CONNACK response from the server.
def on_connect(self, client, userdata, flags, rc):
print("Connected with result code "+str(rc))
self.subscribe(ALARMCOMMANDTOPIC)
for i in range(1, ALARMNUMBEROFOUTPUTS + 1):
self.subscribe(ALARMOUTPUTCOMMANDTOPIC % i)
for i in range(1, ALARMNUMBEROFRESPONSES + 1):
self.subscribe(ALARMRESPONSECOMMANDTOPIC % i)
for i in ALARMVIRTUALINPUTRANGE: #for virtual inputs 17-64
self.subscribe(ALARMINPUTCOMMANDTOPIC % i)
for i in range(1, ALARMNUMBEROFFLAGS + 1):
self.subscribe(ALARMFLAGCOMMANDTOPIC % i)
for i in range(1, ALARMNUMBEROFCOUNTERS + 1):
self.subscribe(ALARMCOUNTERCOMMANDTOPIC % i)
self.readcurrentstate()
def on_disconnect(self, client, userdata, rc):
print("Disconnected with result code "+str(rc))
# The callback for when a PUBLISH message is received from the server.
def on_message(self, client, userdata, msg):
#print("on message")
msgstr = msg.payload.decode()
print(msg.topic+" "+msgstr)
if msg.topic == ALARMCOMMANDTOPIC:
if self.connected:
if msgstr == "ARM_HOME":
self.comfortsock.sendall(("\x03m!03"+self.comfort_pincode+"\r").encode()) #arm to 03 day mode
elif msgstr == "ARM_NIGHT":
self.comfortsock.sendall(("\x03m!02"+self.comfort_pincode+"\r").encode()) #arm to 02 night mode
elif msgstr == "ARM_AWAY":
self.comfortsock.sendall(("\x03m!01"+self.comfort_pincode+"\r").encode()) #arm to 01 away mode
elif msgstr == "DISARM":
self.comfortsock.sendall(("\x03m!00"+self.comfort_pincode+"\r").encode()) #arm to 00 disarm mode
elif msg.topic.startswith(DOMAIN+"/output") and msg.topic.endswith("/set"):
output = int(msg.topic.split("/")[1][6:])
state = int(msgstr)
if self.connected:
self.comfortsock.sendall(("\x03O!%02X%02X\r" % (output, state)).encode())
elif msg.topic.startswith(DOMAIN+"/response") and msg.topic.endswith("/set"):
response = int(msg.topic.split("/")[1][8:])
if self.connected:
self.comfortsock.sendall(("\x03R!%02X\r" % response).encode())
elif msg.topic.startswith(DOMAIN+"/input") and msg.topic.endswith("/set"):
virtualinput = int(msg.topic.split("/")[1][5:])
state = int(msgstr)
if self.connected:
self.comfortsock.sendall(("\x03I!%02X%02X\r" % (virtualinput, state)).encode())
elif msg.topic.startswith(DOMAIN+"/flag") and msg.topic.endswith("/set"):
flag = int(msg.topic.split("/")[1][4:])
state = int(msgstr)
if self.connected:
self.comfortsock.sendall(("\x03F!%02X%02X\r" % (flag, state)).encode())
elif msg.topic.startswith(DOMAIN+"/counter") and msg.topic.endswith("/set"): # counter set
counter = int(msg.topic.split("/")[1][7:])
state = int(msgstr)
if self.connected:
self.comfortsock.sendall(("\x03C!%02X%02X00\r" % (counter, state)).encode()) # counter needs 16 bit number
def on_publish(self, client, obj, mid):
#print("mid: " + str(mid))
pass
def on_subscribe(self, client, userdata, mid, granted_qos):
#print("subscribed "+str(userdata))
pass
def on_log(self, client, userdata, level, buf):
#print("log: ",buf)
pass
def entryexit_timer(self):
#print("timer: "+str(self.entryexitdelay))
self.publish(ALARMTIMERTOPIC, self.entryexitdelay)
self.entryexitdelay -= 1
if self.entryexitdelay >= 0:
threading.Timer(1, self.entryexit_timer).start()
def readlines(self, recv_buffer=BUFFER_SIZE, delim='\r'):
buffer = ''
data = True
while data:
try:
data = self.comfortsock.recv(recv_buffer).decode()
except socket.timeout as e:
err = e.args[0]
# this next if/else is a bit redundant, but illustrates how the
# timeout exception is setup
if err == 'timed out':
#sleep(1)
#print ('recv timed out, retry later')
self.comfortsock.sendall("\x03cc00\r".encode()) #echo command for keepalive
continue
else:
print (e)
#sys.exit(1)
except socket.error as e:
# Something else happened, handle error, exit, etc.
print (e)
raise
#sys.exit(1)
else:
if len(data) == 0:
print ('orderly shutdown on server end')
#sys.exit(0)
else:
# got a message do something :)
buffer += data
while buffer.find(delim) != -1:
line, buffer = buffer.split('\r', 1)
yield line
return
def login(self):
self.comfortsock.sendall(("\x03LI"+self.comfort_pincode+"\r").encode())
def readcurrentstate(self):
if self.connected == True:
#get security mode
self.comfortsock.sendall("\x03M?\r".encode())
#get all zone input states
self.comfortsock.sendall("\x03Z?\r".encode())
#get all output states
self.comfortsock.sendall("\x03Y?\r".encode())
#get all flag states
self.comfortsock.sendall("\x03f?00\r".encode())
self.publish(ALARMAVAILABLETOPIC, 1)
self.publish(ALARMMESSAGETOPIC, "")
def setdatetime(self):
if self.connected == True: #set current date and time
now = datetime.datetime.now()
self.comfortsock.sendall(("\x03DT%02d%02d%02d%02d%02d%02d\r" % (now.year, now.month, now.day, now.hour, now.minute, now.second)).encode())
def run(self):
self.connect_async(self.mqtt_ip, self.mqtt_port, 60)
self.loop_start()
self.publish(ALARMAVAILABLETOPIC, 0)
try:
while True:
try:
self.comfortsock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
print("connecting to "+self.comfort_ip+" "+str(self.comfort_port))
self.comfortsock.connect((self.comfort_ip, self.comfort_port))
self.comfortsock.settimeout(TIMEOUT.seconds)
self.login()
for line in self.readlines():
if line[1:] != "cc00":
print(line[1:])
if line[0] == "\x03": #check for valid prefix
if line[1:3] == "LU":
luMsg = ComfortLUUserLoggedIn(line[1:])
if luMsg.user != 0:
print("login ok")
self.connected = True
#client.publish(ALARMSTATETOPIC, "disarmed")
self.publish(ALARMCOMMANDTOPIC, "comm test")
self.setdatetime()
elif line[1:3] == "IP":
ipMsg = ComfortIPInputActivationReport(line[1:])
print("input %d state %d" % (ipMsg.input, ipMsg.state))
self.publish(ALARMINPUTTOPIC % ipMsg.input, ipMsg.state)
elif line[1:3] == "CT":
ipMsgCT = ComfortCTCounterActivationReport(line[1:])
print("counter %d state %d" % (ipMsgCT.counter, ipMsgCT.state))
self.publish(ALARMCOUNTERINPUTRANGE % ipMsgCT.counter, ipMsgCT.state)
elif line[1:3] == "Z?":
zMsg = ComfortZ_ReportAllZones(line[1:])
for ipMsgZ in zMsg.inputs:
#print("input %d state %d" % (ipMsgZ.input, ipMsgZ.state))
self.publish(ALARMINPUTTOPIC % ipMsgZ.input, ipMsgZ.state)
elif line[1:3] == "M?" or line[1:3] == "MD":
mMsg = ComfortM_SecurityModeReport(line[1:])
print("alarm mode "+mMsg.modename)
self.publish(ALARMSTATETOPIC, mMsg.modename)
self.entryexitdelay = 0 #zero out the countdown timer
elif line[1:3] == "ER":
erMsg = ComfortERArmReadyNotReady(line[1:])
if not erMsg.zone == 0:
print("zone not ready: "+str(erMsg.zone))
self.comfortsock.sendall("\x03KD1A\r".encode()) #force arm
elif line[1:3] == "AM":
amMsg = ComfortAMSystemAlarmReport(line[1:])
self.publish(ALARMMESSAGETOPIC, amMsg.message)
if amMsg.triggered:
self.publish(ALARMSTATETOPIC, "triggered")
elif line[1:3] == "EX":
exMsg = ComfortEXEntryExitDelayStarted(line[1:])
self.entryexitdelay = exMsg.delay
self.entryexit_timer()
self.publish(ALARMSTATETOPIC, "pending")
elif line[1:3] == "RP":
self.publish(ALARMMESSAGETOPIC, "Phone Ring")
elif line[1:3] == "DB":
self.publish(ALARMMESSAGETOPIC, "Door Bell")
elif line[1:3] == "OP":
ipMsg = ComfortOPOutputActivationReport(line[1:])
print("output %d state %d" % (ipMsg.output, ipMsg.state))
self.publish(ALARMOUTPUTTOPIC % ipMsg.output, ipMsg.state)
elif line[1:3] == "Y?":
yMsg = ComfortY_ReportAllOutputs(line[1:])
for opMsgY in yMsg.outputs:
#print("output %d state %d" % (opMsgY.output, opMsgY.state))
self.publish(ALARMOUTPUTTOPIC % opMsgY.output, opMsgY.state)
elif line[1:3] == "f?":
fMsg = Comfortf_ReportAllFlags(line[1:])
for fMsgf in fMsg.flags:
#print("flag %d state %d" % (fMsgf.flag, fMsgf.state))
self.publish(ALARMFLAGTOPIC % fMsgf.flag, fMsgf.state)
elif line[1:3] == "FL":
flMsg = ComfortFLFlagActivationReport(line[1:])
print("flag %d state %d" % (flMsg.flag, flMsg.state))
self.publish(ALARMFLAGTOPIC % flMsg.flag, flMsg.state)
elif line[1:3] == "RS":
#on rare occassions comfort ucm might get reset (RS11), our session is no longer valid, need to relogin
print("reset detected")
self.login()
except socket.error as v:
#errorcode = v[0]
print("socket error "+str(v))
#raise
print("lost connection to comfort, reconnecting...")
time.sleep(RETRY.seconds)
finally:
infot = self.publish(ALARMAVAILABLETOPIC, 0)
infot.wait_for_publish()
mqttc = Comfort2(DOMAIN)
mqttc.init(MQTTBROKERIP, MQTTBROKERPORT, MQTTUSERNAME, MQTTPASSWORD, COMFORTIP, COMFORTPORT, PINCODE)
mqttc.run()
