Ok, sorry for getting back to this so late. Last weekend, I did rebuild a full 3.3.0 configuration on a SD card, I was able to load my backup openhab config and to recover my backup Influxdb database…
And it was successful.
Then, I moved the / directory to the NAS (using rsync as above shown), and all was good. Including installation of the bindings etc…
But, I think there is still a problem, as for nearly all bindings I try to install after having moved to the network system partition I get a significant bunch of java errors and ultimately I need to uninstall them (and then recover a properly working openhab).
I’m nearly sure that when I’ll upgrade to the soem next version of openhab, I’ll have the same problems… At this stage, my conclusion is : when I move the openhabian system to the NAS, there is something that breaks openhab, not to the point that it stops working, as I have it working like this for a long time, but to the point that it is not able to add bindings, or to upgrade etc…
So I need to study this more. @rlkoshak I know what I’m trying to do is not exactly what openhabian is supporting, so I’ll understand if you can’t help. But I’m hoping someone could have a similar config and be able to share some experience. This can’t be that different from the SSD based configs?
@Lionello_Marrelli , thanks for the link you shared, I don’t think what is mentionned could apply to me, as in my case the system works very well after I move the / entirely to the NAS. Do you think I am missing something?
What is strange is that e.g. neither grafana, nor influxdb, nor any other Raspeberry OS seems to have the same problem, as they all update without problem and work just fine over time, even with / on the NAS.
I rsync the / config using -H option to preserve the hard links, so I would hope that this works well.
One thing I noticed is that the problems displayed in the log are very often related to “bundleFiles” in the cache. I don’t know if this can help locating the possible challenge?
Thanks a lot in advance for any help…
