I have installed OH3 from scratch. Now all of a sudden it shuts down and I can’t see the reason behind. Can you see anything in the log, or do I need to raise log-level and wait until it occours again?
Platform information:
Hardware: Raspberry Pi 3 Model B Plus Rev 1.3
OS: Linux openhabian 5.10.11-v7+
Java Runtime Environment: openjdk version “11.0.10” 2021-01-19 LTS
openHAB version: 3.0.1
Issue of the topic: Error message as title describes.
Please post configurations (if applicable): None that I understand.
If logs where generated please post these here using code fences:
2021-03-05 15:33:45.383 [INFO ] [openhab.event.ChannelTriggeredEvent ] - neeo:brain:9b9a81a2:forwardActions triggered {"action":"poweroff","device":"Projector","room":"Vardagsrum","recipe":"PlayStation"}
2021-03-05 15:39:22.248 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Stopped HABPanel
2021-03-05 15:39:22.327 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2021-03-05 15:39:22.419 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2021-03-05 15:39:26.767 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'sonos:SYMFONISK:RINCON_347E5CF38BF801400' changed from ONLINE to UNINITIALIZED
2021-03-05 15:39:26.810 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'sonos:SYMFONISK:RINCON_347E5CF38BF801400' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-03-05 15:39:26.816 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'sonos:SYMFONISK:RINCON_347E5C3B524A01400' changed from ONLINE to UNINITIALIZED
2021-03-05 15:39:26.851 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'sonos:SYMFONISK:RINCON_347E5C3B524A01400' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-03-05 15:39:26.889 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:c4e72aed8a:node8' changed from ONLINE to UNINITIALIZED
2021-03-05 15:39:26.969 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:c4e72aed8a:node8' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-03-05 15:39:26.974 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:c4e72aed8a:node1' changed from ONLINE to UNINITIALIZED
2021-03-05 15:39:27.071 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:c4e72aed8a:node1' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-03-05 15:39:27.076 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:c4e72aed8a:node9' changed from UNINITIALIZED (DISABLED) to UNINITIALIZED
2021-03-05 15:39:27.113 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:c4e72aed8a:node9' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2021-03-05 15:39:27.119 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:c4e72aed8a:node2' changed from ONLINE to UNINITIALIZED
2021-03-05 15:39:27.194 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:c4e72aed8a:node2' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-03-05 15:39:27.200 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:c4e72aed8a:node4' changed from UNINITIALIZED (DISABLED) to UNINITIALIZED
2021-03-05 15:39:27.238 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:c4e72aed8a:node4' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2021-03-05 15:39:27.243 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:c4e72aed8a:node5' changed from ONLINE to UNINITIALIZED
2021-03-05 15:39:27.409 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:c4e72aed8a:node5' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-03-05 15:39:27.414 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:c4e72aed8a:node7' changed from ONLINE to UNINITIALIZED
2021-03-05 15:39:27.572 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:c4e72aed8a:node7' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-03-05 15:39:27.577 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:c4e72aed8a' changed from ONLINE to UNINITIALIZED
2021-03-05 15:39:32.613 [WARN ] [core.thing.internal.ThingManagerImpl] - Disposing handler for thing 'zwave:serial_zstick:c4e72aed8a' takes more than 5000ms.
2021-03-05 15:39:32.639 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:c4e72aed8a' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-03-05 15:39:36.327 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'smhi:forecast:746eec1ad4' changed from ONLINE to UNINITIALIZED
2021-03-05 15:39:36.356 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'smhi:forecast:746eec1ad4' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-03-05 15:39:36.381 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'neeo:room:9b9a81a2:6232364707638935552' changed from ONLINE to UNINITIALIZED
2021-03-05 15:39:36.414 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'neeo:room:9b9a81a2:6232364707638935552' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-03-05 15:39:36.417 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'neeo:brain:9b9a81a2' changed from ONLINE to UNINITIALIZED
2021-03-05 15:39:36.828 [INFO ] [org.openhab.ui.internal.UIService ] - Stopped UI
2021-03-05 15:39:36.534 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'neeo:brain:9b9a81a2' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-03-05 15:39:36.559 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'astro:sun:local' changed from ONLINE to UNINITIALIZED
2021-03-05 15:39:36.607 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'astro:sun:local' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
