- Platform information:
- Hardware: Intel Nuc NUC7CJYH Intel(R) Celeron(R) J4005/8GiB Systemspeicher/500GB Samsung SSD 860
- OS: Ubuntu 22.04.3 LTS jammy
- Java Runtime Environment: openjdk version “17.0.9” 2023-10-17 LTS OpenJDK Runtime / Environment Zulu17.46+19-CA (build 17.0.9+8-LTS) / OpenJDK 64-Bit Server VM Zulu17.46+19-CA (build 17.0.9+8-LTS, mixed mode, sharing)
- openHAB version: openHAB 4.1.0
I started seting up openhab with version 4.0.x (don’t rember x) and installed the AVM binding and some other things. Then I added my han-fun items and everything went well.
Some days ago I updated to OH4.1, that means I run sudo apt-get update && sudo apt-get dist-upgrade and got the new openhab version. (Btw, this is the normal update route?)
Today the AVM binding to my fritz!box stopped connecting :" Status: OFFLINE COMMUNICATION_ERROR FRITZ!Box does not respond.". I tried to disable/enable the thing without luck. The delete the thing and added it again from the inbox. No luck again. Interestingly the han-fun channels do not show up also. The thing code is:
UID: avmfritz:fritzbox:e0bbd4b2d3
label: FRITZ!Box
thingTypeUID: avmfritz:fritzbox
configuration:
syncTimeout: 2000
password: <password>
protocol: http
asyncTimeout: 10000
ipAddress: 198.168.178.1
pollingInterval: 15
user: <user>
channels:
- id: incoming_call
channelTypeUID: avmfritz:incoming_call
label: Eingehender Anruf
description: Zeigt Informationen zu anrufender und angerufener Telefonnummer an
("%2$s" anrufende Telefonnummer, "%1$s" angerufene Telefonnummer).
configuration: {}
- id: outgoing_call
channelTypeUID: avmfritz:outgoing_call
label: Ausgehender Anruf
description: Zeigt Informationen zu angerufener und genutzter Telefonnummer an
("%1$s" angerufene Telefonnummer, "%2$s" genutzte Telefonnummer).
configuration: {}
- id: active_call
channelTypeUID: avmfritz:active_call
label: Aktiver Anruf
description: Zeigt Informationen zur bestehenden Verbindung an ("%1$s" anrufende
Telefonnummer, "%2$s" ist leer).
configuration: {}
- id: call_state
channelTypeUID: avmfritz:call_state
label: Anrufzustand
description: Zeigt an, ob eine Anrufaktivität stattfindet.
configuration: {}
- id: apply_template
channelTypeUID: avmfritz:apply_template
label: Vorlage anwenden
description: Ermöglicht die Anwendung einer vordefinierten Vorlage.
configuration: {}
events.log:
events.log (26.7 KB)
The question is: “What can I do?”
