Sudo openhabian-config now prompts for github username
Openhab 5.2.1
Happened to launch openhabian-config but stuck at prompt.
Probably happens since 5.2.1.
Any help appreciated.
openhabian@openhabian-home:~ $ sudo openhabian-config
2026-09-02_17:22:53_CEST [openHABian] Checking for root privileges… OK
2026-09-02_17:22:53_CEST [openHABian] Making sure router advertisements are available…
$ sysctl --system
  • Applying /usr/lib/sysctl.d/50-pid-max.conf …
  • Applying /etc/sysctl.d/98-rpi.conf …
  • Applying /usr/lib/sysctl.d/99-protect-links.conf …
  • Applying /etc/sysctl.d/99-sysctl.conf …
  • Applying /etc/sysctl.conf …
    kernel.pid_max = 4194304
    kernel.printk = 3 4 1 3
    vm.min_free_kbytes = 16384
    net.ipv4.ping_group_range = 0 2147483647
    fs.protected_fifos = 1
    fs.protected_hardlinks = 1
    fs.protected_regular = 2
    fs.protected_symlinks = 1
    net.ipv6.conf.all.accept_ra = 1
    net.ipv6.conf.all.accept_ra_rt_info_max_plen = 64
    OK
    2026-09-02_17:22:53_CEST [openHABian] Loading configuration file ‘/etc/openhabian.conf’… OK
    2026-09-02_17:22:53_CEST [openHABian] openHABian configuration tool version: [openHAB]{2026-02-09T12:35:02+01:00}(7abab950)
    2026-09-02_17:22:53_CEST [openHABian] Checking for changes in origin branch openHAB… Username for ‘https://github.com’:
ran into something like this on openHABian too. that “Username for https://github.com” usually means the git fetch for the openHAB branch is getting auth-challenged (rate limit / credential helper / remote url flipped) and openhabian-config just hangs waiting on stdin.
what worked for me once was ctrl-c out of it, then as root:
cd /opt/openhabian && git remote -v && git status
if origin is GitHub - openhab/openhabian: openHABian - empowering the smart home, for Raspberry Pi and Debian systems · GitHub try a plain fetch:
GIT_TERMINAL_PROMPT=0 git fetch --dry-run origin
if that also asks for a user, set the remote to the public https url again or temporarily skip the branch check. sometimes just waiting a bit and retrying clears a github anon rate limit.
not 100% sure its the same on 5.2.1 but the stuck prompt is almost always that git step, not your openhab runtime.
i am not using Openhab, but i wanted to mention that there is apparently some server wide issues from Github that require authentication.
Happend also for TrueNas or Pihole:
or Truenas:
Workarounds are there, but just wanted to mention it here.
sudo openhabian-config still stuck at username prompt today.
I also have PiHole and Hagezi blocklists are not accessible anymore from https://raw.githubusercontent.com/hagezi .
I had to use Gerd / mirror · GitLab as per some forums.
But the ‘standard’ blocklist seems to be still accessible !
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
I have no real idea why GitHub sometimes is and sometimes is not available.
And no idea what to do.
Anyone better than me (not very difficult) ?
If openhabian-config continues fails I will start a fresh install, but this will not solve or explain the problem.
If you want a “fix”; run this
git config --system http.version HTTP/1.1
this forces git to use the old http protocol, which somehow goes around the blockage of the authentication. Make a check before how your git is configured so you can revert it back to the original state.
Well, I’m no dev, just an OpenHAB user.
I don’t directly use Github.
PiHole does, OpenHAB does, but not me, and my knowledge is quite limited.
And as Github config is done by OpenHAB, I’m a bit surprised to see ni other OH user having the same problem.
So, I configured nothing and I have no idea how and what to do.
I will try you magic spell later.
Thank you very much.
I have two openhab installations, both run version 5.2.1. When I input sudo openhabian-conifg one installation worked normal (without asking for github username, the other installation aksed.
I aborted with ctrl-c and tried again a couple if minutes later. The second try also github username was asked for. But on the third try (wihout changing anything) it suddenly run without asking.
So i suggest just try again, it may ask again but suddenly it will work :grin:
Just tried, and openhabian-config runs as normally as usual.
Just as if I had dreamt it all !
GitHub is no technology, but but craftman’s art :joy:.
Thank you all and sorry for the inconvenience.
