What would be a good way of testing the Range daylight is happening, but not raised by the triggered START but another event e.g. if a switch is made, then check if it is daylight and then perform an action?
Do you mean something like this?
I see what you did there, but as I see astro can give you an string of either if it is spring, or winter, how come it will not just give you a string if it is daylight, night, etc…
Because it wasn’t coded that way. Most people use the events to trigger things to happen.
@gerrieg People are continuously asking about that feature. I would also be happy to see a simple channel updated with something similar to “Sunrise, Morning, Daytime, Evening, Sunset, Night”. What do you think?
added new sun channel with this PR: phase#name
Amazing @gerrieg, thank you!
Hi @ThomDietrich,
I know I’m digging up an old thread here but I would ask if you can cast an expert eye on my system startup rule, which I see is similar to yours…
In the Smarthome Designer I’m seeing red markers trying to declare the sunrise and sunset variables based on them being defined in my Astro.items file.
According to the log the rule worked though (i.e. 3 minutes later the updates were made)
Here is a screenshot of the code in Designer:
The issue:
This seems to show up in the openhab.log when I restart OH2:
2017-06-07 17:09:01.633 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Astro.items'
2017-06-07 17:09:01.748 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2017-06-07 17:09:01.772 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Kodi.items'
2017-06-07 17:09:01.826 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Light.items'
2017-06-07 17:09:01.855 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Presence.items'
2017-06-07 17:09:01.868 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Virtual.items'
2017-06-07 17:09:01.903 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Weather.items'
2017-06-07 17:09:01.977 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Zoneminder.items'
2017-06-07 17:09:04.552 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Presence.rules'
2017-06-07 17:09:05.038 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Lighting.rules'
2017-06-07 17:09:05.487 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'DayNight.rules'
2017-06-07 17:09:06.365 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'Startup.rules', using it anyway:
Cannot reference the field 'Sunrise_Start' before it is defined
Cannot reference the field 'Sunset_Start' before it is defined
2017-06-07 17:09:06.367 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Startup.rules'
2017-06-07 17:09:07.081 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'Windows.sitemap', using it anyway:
Frames must not contain other frames
2017-06-07 17:09:07.083 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Windows.sitemap'
2017-06-07 17:09:09.108 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
2017-06-07 17:09:09.263 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-06-07 17:09:09.295 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-06-07 17:09:09.327 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-06-07 17:09:12.407 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled astro job-daily-sun at midnight for thing astro:sun:f3c3056b
2017-06-07 17:09:15.359 [WARN ] [me.internal.engine.RuleContextHelper] - Variable 'sunrise' on rule file 'Startup.rules' cannot be initialized with value 'org.eclipse.xtext.xbase.impl.XConstructorCallImplCustom@1c8d8b2 (invalidFeatureIssueCode: null, validFeature: false, explicitConstructorCall: true, anonymousClassConstructorCall: false)': org.eclipse.smarthome.core.library.types.DateTimeType
2017-06-07 17:09:15.361 [WARN ] [me.internal.engine.RuleContextHelper] - Variable 'sunset' on rule file 'Startup.rules' cannot be initialized with value 'org.eclipse.xtext.xbase.impl.XConstructorCallImplCustom@1a9d429 (invalidFeatureIssueCode: null, validFeature: false, explicitConstructorCall: true, anonymousClassConstructorCall: false)': org.eclipse.smarthome.core.library.types.DateTimeType
2017-06-07 17:09:15.583 [INFO ] [.astro.internal.job.AbstractDailyJob] - Scheduled astro event-jobs for thing astro:sun:f3c3056b
2017-06-07 17:11:19.880 [INFO ] [.model.script.Craig presence updated] - Craig is AWAY
2017-06-07 17:12:10.206 [INFO ] [.model.script.Craig presence updated] - Craig is HOME
2017-06-07 17:12:15.457 [INFO ] [home.model.script.NightState updated] - --> NightState set to OFF
2017-06-07 17:12:15.469 [INFO ] [.model.script.LateNightState updated] - --> LateNightState set to OFF
I’ve tried for ages to find why the designer is unhappy.
Here is the code…
val sunrise = new DateTime((Sunrise_Start.state as DateTimeType).calendar.timeInMillis)
val sunset = new DateTime((Sunset_Start.state as DateTimeType).calendar.timeInMillis)
val latenight = now.withTimeAtStartOfDay.plusHours(22).millis // 10 PM
rule "Switch NightState and lights on / off depending on night or day"
System started
createTimer(now.plusSeconds(180)) [ |
// Switch NightState to on if it is dark otherwise switch it to off
if(now.isAfter(sunset) && now.isBefore(sunrise)){
postUpdate(NightState, ON)
logInfo("NightState updated", "--> NightState set to " + NightState.state)
else {
postUpdate(NightState, OFF)
// Switch LateNightState on if it is after 22h00 and before sunrise
if(now.isAfter(latenight) && now.isBefore(sunrise)){
postUpdate(LateNightState, ON)
logInfo("LateNightState updated", "--> LateNightState set to " + LateNightState.state)
else {
postUpdate(LateNightState, OFF)
The items definition:
DateTime Sunrise_Start "Sunrise Start [%1$tH:%1$tM]" (gAstro) {channel="astro:sun:f3c3056b:rise#start"}
DateTime Sunset_Start "Sunset Start [%1$tH:%1$tM]" (gAstro) {channel="astro:sun:f3c3056b:set#start"}
Also it seems unhappy with my ‘IF’ statements, here is the issue:
Am I anywhere close to getting it right?
many thanks in advance,
Craig
Hey Craig,
is there any special reason to have these three lines above all? Could you try moving them inside the rule?
@ThomDietrich: not only inside the rule, but inside the lambda right after:
You might like to think about what you are trying to achieve with variables ‘sunrise’ etc.
Like the Designer warning says, you cannot reference Items outside of rules.
You have also defined them as val meaning they can never be altered - i.e. could never keep track of sunrise tomorrow.
The definition with now in it is also going to go wrong for you eventually - ‘now’ would be when the rules file is loaded, and again is one-time-only, would never update for tomorrow.
Exactly what I was getting at
Thank you guys for the advice, it’s invaluable
What I’m trying to achieve is that in case of a power failure, let’s say 2 minutes before this sunset event triggers my power goes down and then comes back on 5 minutes after the sunset event would have triggered. Persistence 'restore on startup 'would not help me here.I would imagine just about everyone would would have a similar rule in their setup no?
May I ask for a clarification in @ThomDietrich’s example above using the || condition? In order for the system to know that it is night time why not use the && condition? The nightstate must be set to ‘ON’ if the current time is after sunset AND before sunrise. Does it matter?
I guess part of my requirement is redundant now as I see there is a ‘Sun Phase’ channel, so I’ll only need my ‘LateAtNight’ item maintained, e.g
I’m not sure what the possible ‘Sun Phase’ channel values could be so I’ll monitor it.
Now I don’t use the Sunset_Start trigger event anymore since I can use the Sun_Phase channel to tell me if it’s light or not. Maybe this helps someone out there who want to achieve this (assuming my logic is OK, which it is according to my new friend the Designer )
Here is my setup:
.items:
String Sun_Phase "Sun phase" (gAstro) {channel="astro:sun:f3c3056b:phase#name"}
Startup rule:
val LateAtNight = now.withTimeAtStartOfDay.plusHours(22).millis // 10 PM
rule "OpenHAB system started - astro"
System started
logInfo("RULE", "--> astro init")
if (Sun_Phase.state == 'DAYLIGHT'){
logInfo("RULE", "--> Switch all lights off")
else {
if(now.isAfter(LateAtNight)){
else {
And the rule based on the changes in the Sun_Phase channel…
rule "Switch lights on at night"
Item Sun_Phase changed
logInfo("Daytime", "--> Lights off")
sendCommand(Lights_All, OFF)
} else {
if (LateNightState.state == ON){
logInfo("Late at night", "--> Outside lights on full")
sendCommand(Lights_Outdoor, 100)
sendCommand(Light_Study, OFF)
} else {
logInfo("Night time", "--> Lights on")
sendCommand(Lights_Outdoor, 40)
sendCommand(Light_Study, 40)
Not sure how successful I’ll be but I’ll start testing it. If there’s a better way to achieve this I would be glad to hear it.
Thanks again for all your input
Bear in mind that as that is outside of any rule, it only gets executed once at rules file load time, and never gets re-evaluated.
on the other hand I may be able to avoid using the separate startup.rule by including the System started trigger as such:
System started or
} else {
} else {
I would just need to set the LateAtNight value somewhere
And I just saw the DAYLIGHT condition is not going to work since it is now ‘NOON’. Back to the drawing board
It does matter and it must be || because SunsetTime and SunriseTime are calculated at midnight every night. So if the current time is 23:00 6/8/2017 then SunSetTime would be something like 20:30 6/8/2017 and SunriseTime would be 05:30 6/8/2017. The key thing to pay attention to is that the date is included.
The SunsetTime and SunriseTime are for today. In order for the if statement to work using && SunsetTime would need to be for today and SunriseTime needs to be for tomorrow. Since both are calculated for today at midnight the if statement will never evaluate to true if you use &&.
Perfect explanation thanks Rich.
@rlkoshak beat me to it. Excellent, more time for other tasks
Hello Craig
As I read your post, especially the following part, I asked me a few questions…
Is it right, that you have every day a power outage when the sun sets?
If yes, have you ever thought about an Ups (uninterruptable power supply)?
Pepending on your hardware (RPIs, Notebook, full PC, Server…) a small battery pack can solve this problem…
Sorry for this off-topic
Hi Michael,
Actually if I switch the power off and on again then the lights come on at 100% brightness.So if the power trips during the day and the system powers up, I would be left with the lights burning, hence the rule I’m creating which would purposefully switch them off if it is daytime. OH2 may well receive the updates that the lights are on but I need it to physically switch them off.I’m away from home for a few more weeks and when I get back I’ll test the situation out properly. What happens if you switch you main-power off and on again? My Wemo lights will come one I believe,
I take your point about a UPS but I think the issue is not about keeping the Pi powered up but the actual mains-board going down and coming back up again. Since I live in semi-rural South Africa power outages are likely to happen Maybe others have this requirement.
My rule works reliably not so I’m looking forward to testing in in reality.
