Sun (raised / set) indicator
Hi Graig,
Even though I do not live in an area that suffers much from power outages, outages sometimes occur.
Besides that, I am very much in favor of making a fault tolerant system. And because the Raspberry PIs are reasonably cheap, I also consider making a redundant system with two RPi’s power and Li-Ion battery backup.
(Noticed there are others who are also working on HA/Redundancy.)
So, i am very much interested if your rule with initialization and wonder if you had the time to test it further?
Hi @deltabert,
Apologies for my late response.
To give you an update, my lighting and startup rules are working very reliably. It’s been working very well for months now on my SD card (I’ll be migrating to SSD soon). Only once did my sunrise rule not trigger for some reason, so my wife unplugged the Pi and plugged it back in and the startup rule set the lights accordingly.
I don’t have access to y setup as I am away but I’ll post it when I’m back.
It looks similar to my dummy setup on my laptop which is as follows:
Light.items
/* -----------------Groups---------------- */
Group:Dimmer:OR(ON,OFF) Lights_All			"All Lights [%d]"			<light>
Group:Dimmer:OR(ON,OFF) Lights_Outdoor		"Outdoor Lights [%d]"		<light>		(Lights_All)
Group:Dimmer:OR(ON,OFF) Lights_Indoor		"Indoor Lights [%d]"		<light>		(Lights_All)
/* -----------------Lights----------------- */
// Outdoor
Dimmer Light_Front_Door_1		"Front Door 1 [%d %%]"		   	<light>		                 {channel=""}
Dimmer Light_Front_Door_2		"Front Door 2 [%d %%]"		   	<light>		                 {channel=""}
Dimmer Light_Front_Door			"Front Door [%d %%]"			<light>		(Lights_Outdoor)
Dimmer Light_Patio_1			"Patio 1 [%d %%]"		   		<light>		                 {channel=""}
Dimmer Light_Patio_2			"Patio 2 [%d %%]"		   		<light>		                 {channel=""}
Dimmer Light_Patio				"Patio [%d %%]"			    	<light>		(Lights_Outdoor)
Dimmer Light_Braai 				"Braai [%d %%]"				    <light>		(Lights_Outdoor) {channel=""}
Dimmer Light_Kitchen_Porch		"Kitchen Entrance [%d %%]"		<light>		(Lights_Outdoor) {channel=""}
Dimmer Light_Backyard 			"Back yard [%d %%]"			    <light>		(Lights_Outdoor) {channel=""}
Dimmer Light_Adi_Deck			"Adi's deck [%d %%]"		    <light>		(Lights_Outdoor) {channel=""}
// Indoor
Dimmer Light_Study 				"Study [%d %%]"				    <light>		(Lights_Indoor)  {channel=" "}
Virtual.items (for proxy switches)
/* -----------------General---------------- */
Switch NightState         	"Night"
Switch LateNightState     	"Late at Night"
Dimmer Dummy_Slider		  	"Dummy slider"
Dimmer Dummy_Switch		  	"Dummy switch"
DateTime Current_Time	  	"Date [%1$tA, %1$tm/%1$td/%1$tY %1$tT]"		<calendar>		{channel="ntp:ntp:local:dateTime"}
// Create string items for panel names to link dashboards
Astro.items:
Group gAstro "Astronomical Data"
/* -----------------Astro---------------- */
// Sun
DateTime	Sunrise_Start	"Sunrise Start [%1$tH:%1$tM]"	(gAstro)	{channel="astro:sun:f0276b48:rise#start"}
DateTime	Sunset_Start	"Sunset Start [%1$tH:%1$tM]"	(gAstro)	{channel="astro:sun:f0276b48:set#start"}
And my rules…
Startup.rules:
rule "OpenHAB system started - Astro"
    System started
    logInfo("System started rule trigerred", "--> System started")
	val LateAtNight = now.withTimeAtStartOfDay.plusHours(22).millis // 10 PM
    createTimer(now.plusSeconds(60)) [ |
        if (now.isAfter((Sunset_Start.state as DateTimeType).calendar.timeInMillis) ||
            now.isBefore((Sunrise_Start.state as DateTimeType).calendar.timeInMillis))
        	logInfo("NightState updated", "--> NightState set to ON")
            postUpdate(NightState, ON)
        } else {
        	logInfo("NightState updated", "--> NightState set to OFF")
            postUpdate(NightState, OFF)
        if (now.isAfter(LateAtNight) || now.isBefore((Sunrise_Start.state as DateTimeType).calendar.timeInMillis)){
        	logInfo("LateNightState updated", "--> LateNightState set to ON")
        	postUpdate(LateNightState, ON)
        } else {
        	logInfo("LateNightState updated", "--> LateNightState set to OFF")
        	postUpdate(LateNightState, OFF)
        val Craig_Presence = Presence_Craig.state
        postUpdate(Presence_Craig, Craig_Presence)
DayNight.rules:
rule "Switch NightState to ON at sunset"
    Channel 'astro:sun:f3c3056b:set#start' triggered START
    logInfo("NightState updated", "--> NightState set to " + NightState.state)
rule "Switch NightState and LateNightState to OFF at sunrise"
    Channel 'astro:sun:f3c3056b:rise#start' triggered START
rule "Switch LateNightState to ON at 22h00"
    Time cron "0 0 22 1/1 * ? *"
    logInfo("LateNightState updated", "--> LateNightState set to " + LateNightState.state)
Lighting.rules:
rule "Switch lights on at night"
	Item NightState changed
	if (NightState.state == OFF) {
		logInfo("Daytime", "--> Lights " + NightState.state)
		sendCommand(Lights_All, OFF)
	} else {
		sendCommand(Lights_Outdoor, 40)
		logInfo("Night time", "--> Lights on")
		sendCommand(Light_Study, 40)
rule "Adjust lights late at night"
	Item LateNightState changed to ON
	logInfo("Late at night", "--> Outside lights on full")
	sendCommand(Lights_Outdoor, 100)
	sendCommand(Light_Study, OFF)
rule "Update patio lights"
	Item Light_Patio changed
	val SliderValue = Light_Patio.state as Number
	sendCommand(Light_Patio_1, SliderValue)
	sendCommand(Light_Patio_2, SliderValue)
rule "Update front door lights"
	Item Light_Front_Door changed
	val SliderValue = Light_Front_Door.state as Number
	sendCommand(Light_Front_Door_1, SliderValue)
	sendCommand(Light_Front_Door_2, SliderValue)
Please note my design goal was to have as few rule components as possible and so I use proxy switched (virtual items) for monitoring events and triggers.
Any comments / criticism welcome.
I hope that helps,
Craig
Nice, I have to steal some of those ideas :slight_smile:
The main difference in my setup is that I try to merge outside light levels into the decision whether my rollershutters should go up or down…
I was thinking about doing a similar thing with light levels. For instance, if you have a room that is particularly dark, such as a cellar, and you have a motion sensor in it, when you walk in the lights should come on at the same level as the current ambient light in another room filled with natural light. This would probably need a lux sensor in the brighter room to provide the reference level. The effect would be that the person entering the room would not even notice that it is lit. Has anyone achieved this?
Hi Creg,
Thank you very much for sharing your configs. My vacation came in between, but now i am again working on my oh system and using your example. I am working on switching lights some time after sunset, and would like to vary this time daily, to simulate normal habitation.
It is late, but again, thank you.
Regards, Bert
rule “Switch NightState to ON at sunset”
Channel ‘astro:sun:f3c3056b:set#start’ triggered START
logInfo(“NightState updated”, "–> NightState set to " + NightState.state)
Hi Craig,
Is it possible to add offset to the rule event?
For instance I want turn the lights on 30 minutes before sunrise..
I know you can add offset to the event in the Paper UI, but is it also possible to do this in the rules file?
Greetings
Jonathan
Not directly, but why not using the things configuration, see the docs examples:
http://docs.openhab.org/addons/bindings/astro/readme.html#full-example
