I tried to run an addon on my computer but encountered this error, which said
Non-resolvable parent POM org.openhab:openhab-super-pom:[1.0, 2.0) for org.openhab.addons:org.openhab.addons.reactor:2.5.9-SNAPSHOT: No versions matched the requested parent version range ‘[1.0, 2.0)’ and ‘parent.relativePath’ points at wrong local POM
I checked .m2 folder and the openhab super pom was downloaded with no problem. Does anyone know how to get rid of this error?
What are you trying to do, just running an openHAB instance with an addon or running a openHAB instance in Eclipse in order to change the code of the add-on?
Are you running eclipse 2020-06? Because I’ve seen this error with that eclipse version. I don’t know what causes it. I didn’t see it with older versions of eclipse.
