Java Runtime Environment: which java platform is used and what version
openHAB version: any version
Issue of the topic: I need to interface with electric power/energy devices for home automation. I have tried using Home Assistant, Domonitz, and OpenHab had only limited success with reading 2 measurements out of 6 from the Aeotec Smart switch model ZW078. I see that it is not supported in the Things Summary >https://www.openhab.org/addons/bindings/zwave/doc/things.html#things-supported-by-the-z-wave-binding
What can I do from here? This switch is the only 40A, 220Vac rich measurement set that I found at a reasonable price.
Right now I am using HA because there are others using it also. But it only captures kW and kWh. I need more. Open Hab was recommended by Aeotec but could not find it in the things summary.
Using a zooz Zstick S2 plus, if this is significant.
Please post configurations (if applicable):
Items configuration related to the issue
Sitemap configuration related to the issue
Rules code related to the issue
Services configuration related to the issue
If logs where generated please post these here using code fences:
The ZW078 has been in the Z-Wave binding device database for about 2.5 years. Do you have openHAB setup with the Z-Wave binding? What do you need help with?
Why would you want to use 2.5.6? I would strongly suggest to use the latest version. If there’s a problem with your device, it’s very likely to exist in 2.5.6 as well
