Currently Lxone returns Color_Temp/Brightness ( temp(xxx,yyy) ) as HSBType - so the actual value for Color Temerature is lost.
But - I’d need those values to pass it to my Tradfri bulbs.
So I hacked the source function “fromBrightnessTemperature(String value)” to “encode” the value into the hue/sat fields …
int lsb = temperature % 100;
int msb = temperature / 100;
return new HSBType(String.valueOf(msb)+","+String.valueOf(lsb)+","+String.valueOf(brightness));
… which does the job - but now my other lamps - using “real” hsv values, won’t work.
Is there a way to change the loxone-channel-code, so that I could pass a flag “temp=true”, to choose, how to behave?
Or maybe a better solution - if the channel is defined as NumberType - it would return brigthness/temp as a decimal number, brigness beeing the digits in front the decimal point, color temparature beeing the digits behind the decimal point?
