- Administration → Settings → Things → samsung-thing → Channels → Key-Code (String) → Add Link to Item → Create a new Item → set name of item to something meaningful, for example
tv_keyCode → Link (bottom of page)
- Choose the Item → klick at the state (NULL)
- You should get the complete list as dropdown (something like this, but one key per line):
"KEY_0", "KEY_1", "KEY_2", "KEY_3", "KEY_4", "KEY_5", "KEY_6", "KEY_7", "KEY_8", "KEY_9", "KEY_11", "KEY_12", "KEY_3SPEED",
"KEY_4_3", "KEY_16_9", "KEY_AD", "KEY_ADDDEL", "KEY_ALT_MHP", "KEY_AMBIENT", "KEY_ANGLE", "KEY_ANTENA", "KEY_ANYNET", "KEY_ANYVIEW",
"KEY_APP_LIST", "KEY_ASPECT", "KEY_AUTO_ARC_ANTENNA_AIR", "KEY_AUTO_ARC_ANTENNA_CABLE", "KEY_AUTO_ARC_ANTENNA_SATELLITE",
"KEY_AUTO_ARC_ANYNET_AUTO_START", "KEY_AUTO_ARC_ANYNET_MODE_OK", "KEY_AUTO_ARC_AUTOCOLOR_FAIL", "KEY_AUTO_ARC_AUTOCOLOR_SUCCESS",
"KEY_AUTO_ARC_CAPTION_ENG", "KEY_AUTO_ARC_CAPTION_KOR", "KEY_AUTO_ARC_CAPTION_OFF", "KEY_AUTO_ARC_CAPTION_ON", "KEY_AUTO_ARC_C_FORCE_AGING",
"KEY_AUTO_ARC_JACK_IDENT", "KEY_AUTO_ARC_LNA_OFF", "KEY_AUTO_ARC_LNA_ON", "KEY_AUTO_ARC_PIP_CH_CHANGE", "KEY_AUTO_ARC_PIP_DOUBLE",
"KEY_AUTO_ARC_PIP_LARGE", "KEY_AUTO_ARC_PIP_LEFT_BOTTOM", "KEY_AUTO_ARC_PIP_LEFT_TOP", "KEY_AUTO_ARC_PIP_RIGHT_BOTTOM",
"KEY_AUTO_ARC_PIP_RIGHT_TOP", "KEY_AUTO_ARC_PIP_SMALL", "KEY_AUTO_ARC_PIP_SOURCE_CHANGE", "KEY_AUTO_ARC_PIP_WIDE", "KEY_AUTO_ARC_RESET",
"KEY_AUTO_ARC_USBJACK_INSPECT", "KEY_AUTO_FORMAT", "KEY_AUTO_PROGRAM", "KEY_AV1", "KEY_AV2", "KEY_AV3", "KEY_BACK_MHP", "KEY_BOOKMARK",
"KEY_BT_VOICE", "KEY_CALLER_ID", "KEY_CAPTION", "KEY_CATV_MODE", "KEY_CHDOWN", "KEY_CHUP", "KEY_CH_LIST", "KEY_CLEAR", "KEY_CLOCK_DISPLAY",
"KEY_COMPONENT1", "KEY_COMPONENT2", "KEY_CONTENTS", "KEY_CONVERGENCE", "KEY_CONVERT_AUDIO_MAINSUB", "KEY_CUSTOM", "KEY_CYAN", "KEY_BLUE",
"KEY_DEVICE_CONNECT", "KEY_DISC_MENU", "KEY_DMA", "KEY_DNET", "KEY_DNIE", "KEY_DNSE", "KEY_DOOR", "KEY_DOWN", "KEY_DSS_MODE", "KEY_DTV",
"KEY_DTV_LINK", "KEY_DTV_SIGNAL", "KEY_DVD_MODE", "KEY_DVI", "KEY_DVR", "KEY_DVR_MENU", "KEY_DYNAMIC", "KEY_ENTER", "KEY_ENTERTAINMENT",
"KEY_ESAVING", "KEY_EXIT", "KEY_EXT1", "KEY_EXT2", "KEY_EXT3", "KEY_EXT4", "KEY_EXT5", "KEY_EXT6", "KEY_EXT7", "KEY_EXT8", "KEY_EXT9",
"KEY_EXT10", "KEY_EXT11", "KEY_EXT12", "KEY_EXT13", "KEY_EXT14", "KEY_EXT15", "KEY_EXT16", "KEY_EXT17", "KEY_EXT18", "KEY_EXT19", "KEY_EXT20",
"KEY_EXT21", "KEY_EXT22", "KEY_EXT23", "KEY_EXT24", "KEY_EXT25", "KEY_EXT26", "KEY_EXT27", "KEY_EXT28", "KEY_EXT29", "KEY_EXT30", "KEY_EXT31",
"KEY_EXT32", "KEY_EXT33", "KEY_EXT34", "KEY_EXT35", "KEY_EXT36", "KEY_EXT37", "KEY_EXT38", "KEY_EXT39", "KEY_EXT40", "KEY_EXT41", "KEY_FACTORY",
"KEY_FAVCH", "KEY_FF", "KEY_FM_RADIO", "KEY_GAME", "KEY_GREEN", "KEY_GUIDE", "KEY_HDMI", "KEY_HDMI1", "KEY_HDMI2", "KEY_HDMI3", "KEY_HDMI4", "KEY_HELP",
"KEY_HOME", "KEY_ID_INPUT", "KEY_ID_SETUP", "KEY_INFO", "KEY_INSTANT_REPLAY", "KEY_LEFT", "KEY_LINK", "KEY_LIVE", "KEY_MAGIC_BRIGHT",
"KEY_MAGIC_CHANNEL", "KEY_MDC", "KEY_MENU", "KEY_MIC", "KEY_MORE", "KEY_MOVIE1", "KEY_MS", "KEY_MTS", "KEY_MULTI_VIEW", "KEY_MUTE", "KEY_NINE_SEPERATE",
"KEY_OPEN", "KEY_PANNEL_CHDOWN", "KEY_PANNEL_CHUP", "KEY_PANNEL_ENTER", "KEY_PANNEL_MENU", "KEY_PANNEL_POWER", "KEY_PANNEL_SOURCE", "KEY_PANNEL_VOLDOW",
"KEY_PANNEL_VOLUP", "KEY_PANORAMA", "KEY_PAUSE", "KEY_PCMODE", "KEY_PERPECT_FOCUS", "KEY_PICTURE_SIZE", "KEY_PIP_CHDOWN", "KEY_PIP_CHUP", "KEY_PIP_ONOFF",
"KEY_PIP_SCAN", "KEY_PIP_SIZE", "KEY_PIP_SWAP", "KEY_PLAY", "KEY_PLUS100", "KEY_PMODE", "KEY_POWER", "KEY_POWEROFF", "KEY_POWERON", "KEY_PRECH",
"KEY_PRINT", "KEY_PROGRAM", "KEY_QUICK_REPLAY", "KEY_REC", "KEY_RED", "KEY_REPEAT", "KEY_RESERVED1", "KEY_RETURN", "KEY_REWIND", "KEY_RIGHT", "KEY_RSS",
"KEY_INTERNET", "KEY_RSURF", "KEY_SCALE", "KEY_SEFFECT", "KEY_SETUP_CLOCK_TIMER", "KEY_SLEEP", "KEY_SOUND_MODE", "KEY_SOURCE", "KEY_SRS", "KEY_STANDARD",
"KEY_STB_MODE", "KEY_STILL_PICTURE", "KEY_STOP", "KEY_SUB_TITLE", "KEY_SVIDEO1", "KEY_SVIDEO2", "KEY_SVIDEO3", "KEY_TOOLS", "KEY_TOPMENU", "KEY_TTX_MIX",
"KEY_TTX_SUBFACE", "KEY_TURBO", "KEY_TV", "KEY_TV_MODE", "KEY_UP", "KEY_VCHIP", "KEY_VCR_MODE", "KEY_VOLDOWN", "KEY_VOLUP", "KEY_WHEEL_LEFT",
"KEY_WHEEL_RIGHT", "KEY_W_LINK", "KEY_YELLOW", "KEY_ZOOM1", "KEY_ZOOM2", "KEY_ZOOM_IN", "KEY_ZOOM_MOVE", "KEY_ZOOM_OUT"
For getting the complete list as text:
4. Administration → Developer tools → API Explorer → items → GET /items/[itemname} → Try it out → write the item’s name into the item name field → Execute → Copy the content of Response body
