I have the following problem. I have a switch item linked to a channel of an knx thing (switch actor). I use opnehab 2.4 with the knx2 binding from version 2.4.
Irregular, the item switched to ON (see log), but only the item state changed. The channel from the thing is not switched (actor channel is physically still OFF).
2019-03-17 17:59:13.290 [ome.event.ItemCommandEvent] - Item 'Switch1_KanalJ' received command OFF
2019-03-17 17:59:13.323 [vent.ItemStateChangedEvent] - Switch1_KanalJ changed from ON to OFF
2019-03-17 18:00:32.450 [vent.ItemStateChangedEvent] - Switch1_KanalJ changed from OFF to ON
2019-03-17 18:00:58.435 [ome.event.ItemCommandEvent] - Item 'Switch1_KanalJ' received command OFF
2019-03-17 18:00:58.460 [vent.ItemStateChangedEvent] - Switch1_KanalJ changed from ON to OFF
2019-03-17 18:05:44.401 [vent.ItemStateChangedEvent] - Switch1_KanalJ changed from OFF to ON
The lines with “received command” are executed by myself (Basic UI).
Here is the thing definition of the channel::
Type switch : KanalJ "Drucker" [ ga="0/6/23+<0/6/24" ]
item definition:
Switch Switch1_KanalJ "Drucker" <printer> (gGeraete, gSchaltaktor20f) [ "Switchable" ] {channel="knx:device:bridge:schaltaktor20f:KanalJ", autoupdate="true"}
I have 19 other channels and item on that knx thing with out any problem and same configuration, expect the ga’s and channel names.
Have anybody an idea what is the problem.
Thank you for your help!
