Switch Light on/off on OH3 using ECMA script and HUE Dimmer Switch
Hi all
I’m struggling with my topic for some days …need community help now.
Trying to create a rule (attention: absolute beginner with OH3) which will react to events from hue dimmer switch.
my code till now:
var sofaLinks = ir.getItem('SteckerSofaLinks_Schalter');
var sofaRechts = ir.getItem('BirneSofaRechts');
if (receivedEvent == '1000.0') {
    if(sofaLinks.getState() == 'OFF'){
      events.sendCommand('SteckerSofaLinks_Schalter', 'ON');
      return;
      events.sendCommand('BirneSofaRechts', 100);
My rule is being called and the script executes but then there seems to be an error. Unfortunately I do not have any log possibility (running OH as service on Windows 10 …no log :frowning: )
Any hints? Actually I think there’s an issue comparing the event…
thank you in advance!
Best,
Matthias
There’s always a log on all operating systems. It’s in c:\openhab\userdata\logs (or where ever you unzipped openHAB to).
Without the log we’ve nothing to go on.
The best I can offer is if that number is a floating point number, is it ever exactly 1000.0? Often a floating point number like that would actually be 1000.00001234564, which of course is not exactly 1000.0.
Your code looks like Javascript right? its in the title :sleeping:
Try " event.itemState" instead of “receivedEvent”.
Yes there’s a log file but nit logging anything out of rules. The only thing inside the log are a lot on info line that there’s a problem with the log :slight_smile:
INFO   | jvm 1    | 2021/01/06 01:21:09 | Warning: Nashorn engine is planned to be removed from a future JDK release
    STATUS | wrapper  | 2021/01/06 01:21:11 | <-- Wrapper Stopped
    STATUS | wrapper  | 2021/01/06 01:21:12 | --> Wrapper Started as Service
    STATUS | wrapper  | 2021/01/06 01:21:12 | Launching a JVM...
    INFO   | jvm 1    | 2021/01/06 01:21:13 | Wrapper (Version 3.2.3) http://wrapper.tanukisoftware.org
    INFO   | jvm 1    | 2021/01/06 01:21:13 |   Copyright 1999-2006 Tanuki Software, Inc.  All Rights Reserved.
    INFO   | jvm 1    | 2021/01/06 01:21:14 | WARNING: An illegal reflective access operation has occurred
    INFO   | jvm 1    | 2021/01/06 01:21:14 | WARNING: Illegal reflective access by org.eclipse.osgi.storage.FrameworkExtensionInstaller (file:/C:/openHAB/runtime/system/org/eclipse/platform/org.eclipse.osgi/3.12.100/org.eclipse.osgi-3.12.100.jar) to method java.net.URLClassLoader.addURL(java.net.URL)
    INFO   | jvm 1    | 2021/01/06 01:21:14 | WARNING: Please consider reporting this to the maintainers of org.eclipse.osgi.storage.FrameworkExtensionInstaller
    INFO   | jvm 1    | 2021/01/06 01:21:14 | WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
    INFO   | jvm 1    | 2021/01/06 01:21:14 | WARNING: All illegal access operations will be denied in a future release
    INFO   | jvm 1    | 2021/01/06 01:21:14 | Jan. 06, 2021 1:21:14 VORM. org.apache.karaf.main.lock.SimpleFileLock lock
    INFO   | jvm 1    | 2021/01/06 01:21:14 | INFORMATION: Trying to lock C:\openHAB\userdata\tmp\lock
    INFO   | jvm 1    | 2021/01/06 01:21:14 | INFORMATION: Lock acquired
    INFO   | jvm 1    | 2021/01/06 01:21:14 | Jan. 06, 2021 1:21:14 VORM. org.apache.karaf.main.Main$KarafLockCallback lockAcquired
    INFO   | jvm 1    | 2021/01/06 01:21:14 | INFORMATION: Lock acquired. Setting startlevel to 100
    INFO   | jvm 1    | 2021/01/06 01:21:14 | Jan. 06, 2021 1:21:14 VORM. org.apache.karaf.main.ShutdownSocketThread run
    INFO   | jvm 1    | 2021/01/06 01:21:14 | INFORMATION: Shutdown socket thread is listening on 127.0.0.1:54971
    INFO   | jvm 1    | 2021/01/06 01:21:15 | org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Unable to create file ${sys:openhab.logdir}/openhab.log Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
    INFO   | jvm 1    | 2021/01/06 01:21:15 | java.io.IOException: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at java.base/java.io.WinNTFileSystem.canonicalize0(Native Method)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at java.base/java.io.WinNTFileSystem.canonicalize(WinNTFileSystem.java:438)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at java.base/java.io.File.getCanonicalPath(File.java:620)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at java.base/java.io.File.getCanonicalFile(File.java:645)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.util.FileUtils.makeParentDirs(FileUtils.java:142)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.appender.rolling.RollingFileManager$RollingFileManagerFactory.createManager(RollingFileManager.java:650)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.appender.rolling.RollingFileManager$RollingFileManagerFactory.createManager(RollingFileManager.java:631)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.appender.AbstractManager.getManager(AbstractManager.java:113)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.appender.OutputStreamManager.getManager(OutputStreamManager.java:114)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.appender.rolling.RollingFileManager.getFileManager(RollingFileManager.java:205)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.appender.RollingFileAppender$Builder.build(RollingFileAppender.java:146)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.appender.RollingFileAppender$Builder.build(RollingFileAppender.java:62)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.config.plugins.util.PluginBuilder.build(PluginBuilder.java:122)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.config.AbstractConfiguration.createPluginObject(AbstractConfiguration.java:1002)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.config.AbstractConfiguration.createConfiguration(AbstractConfiguration.java:942)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.config.AbstractConfiguration.createConfiguration(AbstractConfiguration.java:934)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.config.AbstractConfiguration.doConfigure(AbstractConfiguration.java:552)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.config.AbstractConfiguration.initialize(AbstractConfiguration.java:241)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.config.AbstractConfiguration.start(AbstractConfiguration.java:288)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.LoggerContext.setConfiguration(LoggerContext.java:579)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.LoggerContext.start(LoggerContext.java:285)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl.configureLog4J2(PaxLoggingServiceImpl.java:427)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl.updated(PaxLoggingServiceImpl.java:269)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.ops4j.pax.logging.log4j2.internal.PaxLoggingServiceImpl$1ManagedPaxLoggingService.updated(PaxLoggingServiceImpl.java:569)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1118)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1074)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:138)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at java.base/java.lang.Thread.run(Thread.java:834)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Could not create plugin of type class org.apache.logging.log4j.core.appender.RollingFileAppender for element RollingFile: java.lang.IllegalStateException: ManagerFactory [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$RollingFileManagerFactory@67053b26] unable to create manager for [${sys:openhab.logdir}/openhab.log] with data [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$FactoryData@4ea83afe[pattern=${sys:openhab.logdir}/openhab.log.%i, append=true, bufferedIO=true, bufferSize=8192, policy=CompositeTriggeringPolicy(policies=[OnStartupTriggeringPolicy, SizeBasedTriggeringPolicy(size=16777216)]), strategy=DefaultRolloverStrategy(min=1, max=7, useMax=true), advertiseURI=null, layout=%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n, filePermissions=null, fileOwner=null]] Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
    INFO   | jvm 1    | 2021/01/06 01:21:15 | java.lang.IllegalStateException: ManagerFactory [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$RollingFileManagerFactory@67053b26] unable to create manager for [${sys:openhab.logdir}/openhab.log] with data [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$FactoryData@4ea83afe[pattern=${sys:openhab.logdir}/openhab.log.%i, append=true, bufferedIO=true, bufferSize=8192, policy=CompositeTriggeringPolicy(policies=[OnStartupTriggeringPolicy, SizeBasedTriggeringPolicy(size=16777216)]), strategy=DefaultRolloverStrategy(min=1, max=7, useMax=true), advertiseURI=null, layout=%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n, filePermissions=null, fileOwner=null]]
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.appender.AbstractManager.getManager(AbstractManager.java:115)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Unable to invoke factory method in class org.apache.logging.log4j.core.appender.RollingFileAppender for element RollingFile: java.lang.IllegalStateException: No factory method found for class org.apache.logging.log4j.core.appender.RollingFileAppender Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
    INFO   | jvm 1    | 2021/01/06 01:21:15 | java.lang.IllegalStateException: No factory method found for class org.apache.logging.log4j.core.appender.RollingFileAppender
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.config.plugins.util.PluginBuilder.findFactoryMethod(PluginBuilder.java:234)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.config.plugins.util.PluginBuilder.build(PluginBuilder.java:134)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Cannot access RandomAccessFile java.io.IOException: Die Syntax für den Dateinamen, Verzeichnisnamen oder die Datenträgerbezeichnung ist falsch Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.appender.rolling.RollingRandomAccessFileManager$RollingRandomAccessFileManagerFactory.createManager(RollingRandomAccessFileManager.java:218)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.appender.rolling.RollingRandomAccessFileManager$RollingRandomAccessFileManagerFactory.createManager(RollingRandomAccessFileManager.java:191)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.appender.rolling.RollingRandomAccessFileManager.getRollingRandomAccessFileManager(RollingRandomAccessFileManager.java:108)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.appender.RollingRandomAccessFileAppender$Builder.build(RollingRandomAccessFileAppender.java:133)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | 	at org.apache.logging.log4j.core.appender.RollingRandomAccessFileAppender$Builder.build(RollingRandomAccessFileAppender.java:53)
    INFO   | jvm 1    | 2021/01/06 01:21:15 | org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Could not create plugin of type class org.apache.logging.log4j.core.appender.RollingRandomAccessFileAppender for element RollingRandomAccessFile: java.lang.IllegalStateException: ManagerFactory [org.apache.logging.log4j.core.appender.rolling.RollingRandomAccessFileManager$RollingRandomAccessFileManagerFactory@42bf9933] unable to create manager for [${sys:openhab.logdir}/events.log] with data [org.apache.logging.log4j.core.appender.rolling.RollingRandomAccessFileManager$FactoryData@3cbd4e8] Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
    INFO   | jvm 1    | 2021/01/06 01:21:15 | java.lang.IllegalStateException: ManagerFactory [org.apache.logging.log4j.core.appender.rolling.RollingRandomAccessFileManager$RollingRandomAccessFileManagerFactory@42bf9933] unable to create manager for [${sys:openhab.logdir}/events.log] with data [org.apache.logging.log4j.core.appender.rolling.RollingRandomAccessFileManager$FactoryData@3cbd4e8]
    INFO   | jvm 1    | 2021/01/06 01:21:15 | org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Unable to invoke factory method in class org.apache.logging.log4j.core.appender.RollingRandomAccessFileAppender for element RollingRandomAccessFile: java.lang.IllegalStateException: No factory method found for class org.apache.logging.log4j.core.appender.RollingRandomAccessFileAppender Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
    INFO   | jvm 1    | 2021/01/06 01:21:15 | java.lang.IllegalStateException: No factory method found for class org.apache.logging.log4j.core.appender.RollingRandomAccessFileAppender
    INFO   | jvm 1    | 2021/01/06 01:21:15 | org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Could not create plugin of type class org.apache.logging.log4j.core.appender.RollingRandomAccessFileAppender for element RollingRandomAccessFile: java.lang.IllegalStateException: ManagerFactory [org.apache.logging.log4j.core.appender.rolling.RollingRandomAccessFileManager$RollingRandomAccessFileManagerFactory@42bf9933] unable to create manager for [${sys:openhab.logdir}/audit.log] with data [org.apache.logging.log4j.core.appender.rolling.RollingRandomAccessFileManager$FactoryData@495c047e] Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
    INFO   | jvm 1    | 2021/01/06 01:21:15 | java.lang.IllegalStateException: ManagerFactory [org.apache.logging.log4j.core.appender.rolling.RollingRandomAccessFileManager$RollingRandomAccessFileManagerFactory@42bf9933] unable to create manager for [${sys:openhab.logdir}/audit.log] with data [org.apache.logging.log4j.core.appender.rolling.RollingRandomAccessFileManager$FactoryData@495c047e]
    INFO   | jvm 1    | 2021/01/06 01:21:15 | org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Null object returned for RollingFile in Appenders. Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
    INFO   | jvm 1    | 2021/01/06 01:21:15 | org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Null object returned for RollingRandomAccessFile in Appenders. Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
    INFO   | jvm 1    | 2021/01/06 01:21:16 | org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Unable to locate appender "LOGFILE" for logger config "root" Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
    INFO   | jvm 1    | 2021/01/06 01:21:16 | org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Unable to locate appender "AUDIT" for logger config "org.apache.karaf.jaas.modules.audit" Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
    INFO   | jvm 1    | 2021/01/06 01:21:16 | org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Unable to locate appender "EVENT" for logger config "openhab.event" Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
if you’ve any idea hot to get it run …would be cool.
Number as long: doc for the binding tells that this value should be compared like that (Hue Binding → Dimmer Swich).
Thank you for yout support!
please use code fences the next time. Makes it easier for others to read:
STATUS | wrapper | 2021/01/06 01:21:12 | Launching a JVM…
INFO | jvm 1 | 2021/01/06 01:21:16 | org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Unable to locate appender “LOGFILE” for logger config “root” Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
INFO | jvm 1 | 2021/01/06 01:21:16 | org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Unable to locate appender “AUDIT” for logger config “org.apache.karaf.jaas.modules.audit” Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
INFO | jvm 1 | 2021/01/06 01:21:16 | org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : Unable to locate appender “EVENT” for logger config “openhab.event” Ignored FQCN: org.apache.logging.log4j.spi.AbstractLogger
You need to figure out the reason why the log file cannot be created first. We can’t help with anything else until we can get some logs.
I don’t read German but it similar enough to English to make me guess that it’s complaining that your log4j2.xml file is not formatted correctly.
It is the original file from a clean install. Nothing changed. I think it might be the same issue like here: OH3 - Windows - Fresh Install - openhab.log and events.log not generated after installing service wrapper · Issue #1227 · openhab/openhab-distro · GitHub
OK, log is ok now. The original file which is deployed with the build seems to have some errors. Had to correct all paths from the sys:…/openhab… var to a fixed path (in my case c:\logs\openhab…) ..giving everyone all filesystem rights to that path.
There’s no error but logging event var all properties are ‘undefined’
2021-01-09 20:25:22.544 [INFO ] [g.openhab.core.model.script.itemName] - undefined
2021-01-09 20:25:22.560 [INFO ] [.openhab.core.model.script.itemState] - undefined
2021-01-09 20:25:22.560 [INFO ] [enhab.core.model.script.oldItemState] - undefined
2021-01-09 20:25:22.560 [INFO ] [rg.openhab.core.model.script.command] - undefined
2021-01-09 20:25:22.607 [INFO ] [org.openhab.core.model.script.items ] - undefined
any hints what’s wrong?
as written before all event properties are undefined :frowning:
any hints?
I see ‘script’ and assume (in the last line) your script is named ‘items’? Correct?
Implicit variables (like event.itemState) are only available in scripts executed in a rule, triggered by a “When” action.
If you run a script, it will not work, if you run a rule manually (by clicking the “play button”, which in turn executes the script), it will not work.
The hue dimmer switch is a Philips remote right? I use them too. As a test, please try the following:
  1. Create a NEW rule
  2. Give it a name (testrule)
  3. Under When → click add trigger → show all → select “a trigger channel fires” → under item, select something similar to philips rwl01 … ButtonI
  4. Under Then → click add action → click run script → click ECMAscript → paste the following:
    logger.info(event);
Then click save
Now if you press the I button on your remote you should see something like this in your logs:
2021-01-07 10:43:37.494 [INFO ] [org.openhab.rule.ea62a8ea30         ] - Event: zigbee:philips_rwl021:25e772bd74:0017880104ad1d88:buttonI triggered SHORT_PRESSED
Hope this helps!
ok, di all this things you’ve written. Much better now.
But all event properties are still undefined …any hints on that?
2021-01-09 22:03:50.307 [INFO ] [org.openhab.rule.d33fab3097         ] - --- rule start ---
2021-01-09 22:03:50.307 [INFO ] [org.openhab.rule.d33fab3097         ] - event:hue:0820:ecb5fa2cecf9:22:dimmer_switch_event triggered 1000.0
2021-01-09 22:03:50.307 [INFO ] [org.openhab.rule.d33fab3097         ] - itemName:undefined
2021-01-09 22:03:50.307 [INFO ] [org.openhab.rule.d33fab3097         ] - itemState:undefined
2021-01-09 22:03:50.307 [INFO ] [org.openhab.rule.d33fab3097         ] - oldItemState:undefined
2021-01-09 22:03:50.307 [INFO ] [org.openhab.rule.d33fab3097         ] - command:undefined
2021-01-09 22:03:50.307 [INFO ] [org.openhab.rule.d33fab3097         ] - items:undefined
my script looks at the moment like that
var Log = Java.type('org.slf4j.LoggerFactory').getLogger('org.openhab.rule.' + ctx.ruleUID);
Log.info("--- rule start ---");
Log.info("event:" + event);
Log.info("itemName:"+event.itemName);
Log.info("itemState:"+event.itemState);
Log.info("oldItemState:"+event.oldItemState);
Log.info("command:"+event.command);
Log.info("items:"+items[event.itemName]);
and yes it is an hue dimmer switch
Cool!
Channel events are a bit different:
“event.channel” should contain the “item name”. (“hue:0820:ecb5fa2cecf9:22:dimmer_switch_event”)
I forgot the name for variable of the value..
“event.event” should contain the value (“1000.0”)
see here for all available variables.
exactly what I’ve been searching for …thank you!
other question …do you also use motion sensors from hue?
There I’ve the issue that they do react to motion very well …but then, once no more for some seconds and then again …weird :frowning:
script which I use:
this.myTimer = (this.myTimer===undefined) ? null : this.myTimer;
events.sendCommand('Lampe_Vorzimmer', 50);
var ScriptExecution = Java.type("org.openhab.core.model.script.actions.ScriptExecution");
var ZonedDateTime   = Java.type("java.time.ZonedDateTime");
if(this.myTimer != undefined && this.myTimer != null){
  this.myTimer.cancel();
  this.myTimer = null;
this.myTimer = ScriptExecution.createTimer(ZonedDateTime.now().plusSeconds(60), function(){
        events.sendCommand('Lampe_Vorzimmer', 0);
Not sure but I think you missed 2 = in your if statement:
if(this.myTimer !== undefined && this.myTimer !== null){
oh and this.myTimer should never be undefined here as you assigned null if undefined :slight_smile:
Yes, that was it.
Thank you!
That is standard motions sensor behavior. It detects and reports motion and then it waits a certain amount of time before it will report more motion again. Usually the amount of time it waits is configurable.
