Switch light on with Sunset does not work. What do I wrong?
I run openHAB on a Synology NAS.
I use two Sonoff S20 switches with MQTT to switch two different lamps. That is working well.
But one of the lamps I want to switch on with Sunset and off at 00:00 hours.
The switching on at sunset is not working, even if I can see an event for that in the eventlogg.
default.items
Switch 	Balkong 	"Balkongdörr"	{mqtt=">[mybroker:/BalkongdorrLamp/gpio/12:command:ON:1],>[mybroker:/BalkongdorrLamp/gpio/12:command:OFF:0],<[mybroker:/BalkongdorrLamp/lightState/Switch:command:OFF:0],<[mybroker:/BalkongdorrLamp/lightState/Switch:command:ON:1]"}
Switch 	Fonster 	"Fönster"  		{mqtt=">[mybroker:/VardagsrumLamp/gpio/12:command:ON:1],>[mybroker:/VardagsrumLamp/gpio/12:command:OFF:0],<[mybroker:/VardagsrumLamp/lightState/Switch:command:OFF:0],<[mybroker:/VardagsrumLamp/lightState/Switch:command:ON:1]"}
Switch 	Framdorr 	"Framdörr"  	{mqtt=">[mybroker:/UtomhusFramdorr/gpio/12:command:ON:1],>[mybroker:/UtomhusFramdorr/gpio/12:command:OFF:0],<[mybroker:/UtomhusFramdorr/lightState/Switch:command:OFF:0],<[mybroker:/UtomhusFramdorr/lightState/Switch:command:ON:1]"}
Switch 	Garage 		"Garage"  		{mqtt=">[mybroker:/UtomhusBalkong/gpio/12:command:ON:1],>[mybroker:/UtomhusBalkong/gpio/12:command:OFF:0],<[mybroker:/UtomhusBalkong/lightState/Switch:command:OFF:0],<[mybroker:/UtomhusBalkong/lightState/Switch:command:ON:1]"}
Switch 	Kontor 		"Kontor"  		{mqtt=">[mybroker:/UtomhusKontoret/gpio/12:command:ON:1],>[mybroker:/UtomhusKontoret/gpio/12:command:OFF:0],<[mybroker:/UtomhusKontoret/lightState/Switch:command:OFF:0],<[mybroker:/UtomhusKontoret/lightState/Switch:command:ON:1]"}
DateTime Date  "Date [%1$tY-%1$tm-%1$td %1$tH:%1$tM]"  { channel="ntp:ntp:demo:dateTime" }
default.things
ntp:ntp:demo [ hostname="se.pool.ntp.org", refreshInterval=60, refreshNtp=30 ]
default.rules
rule "lichtuit"
	Time cron "0 0 0 ? * *"
	sendCommand(Balkong, OFF)
rule "lichtaan"
	Item Sunset_Time received update ON
    sendCommand(Balkong, ON)
Item Sunset_Time is created in openHAB Paper UI.
Att Sunset time (19:51) is see the following events in events.log:
2018-04-12 19:50:52.296 [vent.ItemStateChangedEvent] - Date changed from 2018-04-12T19:49:52.274+0200 to 2018-04-12T19:50:52.284+0200
2018-04-12 19:51:00.055 [vent.ChannelTriggeredEvent] - astro:sun:906dd801:daylight#event triggered END
2018-04-12 19:51:00.058 [vent.ChannelTriggeredEvent] - astro:sun:906dd801:set#event triggered START
2018-04-12 19:51:52.318 [vent.ItemStateChangedEvent] - Date changed from 2018-04-12T19:50:52.284+0200 to 2018-04-12T19:51:52.304+0200
2018-04-12 19:54:52.425 [vent.ItemStateChangedEvent] - Date changed from 2018-04-12T19:53:52.404+0200 to 2018-04-12T19:54:52.414+0200
2018-04-12 19:55:00.016 [vent.ChannelTriggeredEvent] - astro:sun:906dd801:civilDusk#event triggered START
2018-04-12 19:55:00.019 [vent.ChannelTriggeredEvent] - astro:sun:906dd801:set#event triggered END
2018-04-12 19:55:52.439 [vent.ItemStateChangedEvent] - Date changed from 2018-04-12T19:54:52.414+0200 to 2018-04-12T19:55:52.424+0200
2018-04-12 19:56:52.446 [vent.ItemStateChangedEvent] - Date changed from 2018-04-12T19:55:52.424+0200 to 2018-04-12T19:56:52.434+0200
Can anybody tell me what I am doing wrong?
try to:
    Channel 'astro:sun:906dd801:set#event' triggered START
Thank you. This solved it.
