Hello There,
I am trying to create a dashboard and have a switch to turn light bulb on and off as the OS of bulb is not supported I am using IFTTT webhooks.
The URL seems to work fine but my switch doesn’t work with the below code.
Switch Light_Switch { http=">[ON:POST:https://maker.ifttt.com/trigger/hallon/with/key/xxxxxx] >[OFF:POST:https://maker.ifttt.com/trigger/halloff/with/key/xxxx]" }
Thank You.
