Switch on recievedCommand falling to default case
The rule below is falling through to the default case on all occasions.
can someone advise?
Paul
rule "Automated Humidity Control"
Item BR1_Humid_auto received command or
Item BR2_Humid_auto received command or
Item BR3_Humid_auto received command or
Item BR4_Humid_auto received command or
Item LR_Humid_auto received command or
Item GR_Humid_auto received command or
Item HO_Humid_auto received command
	logInfo("auto_humid.rules", triggeringItem.name + " received a command:" +  receivedCommand)
	switch receivedCommand {
		case "ON" :	{logInfo("autohumid.rules", triggeringItem.name + " humidity contorl has been enabled")}
		case "OFF" : {logInfo("autohumid.rules", triggeringItem.name + " humidity control has been disabled")}
		default : {logInfo("autohumid.rules", "Unexpectedly reached default case")}
I think this will be a state like ON , not a string “ON”
Thanks.
I had tried is simply with using ON and OFF without quotes but the said something about not a boolean.
Now I have it working correctly using the following.
	logDebug("auto_humid.rules", triggeringItem.name + " received a command: " +  receivedCommand)
		case receivedCommand == ON :	{logInfo("autohumid.rules", triggeringItem.name + " humidity contorl has been enabled")}
		case receivedCommand == OFF : {logInfo("autohumid.rules", triggeringItem.name + " humidity control has been disabled")}
		default : {logError("autohumid.rules", "Unexpectedly reached default case")}
	//if (receivedCommand == ON) logInfo("autohumid.rules", triggeringItem.name + " humidity contorl has been enabled")
	//if (receivedCommand == OFF) logInfo("autohumid.rules", triggeringItem.name + " humidity control has been disabled")
Paul
Either use
switch receivedCommand.toString
or
case ON: ...
case OFF: ...
This cannot work as the result is a boolean (true or false)
case receivedCommand == ON: ...
case receivedCommand == OFF: ...
  • The type of items ? ( Switch or String ? )
  • Try with only one item in rule to debug
Actually, this could work in Rules DSL. Switch statements behave a little differently in Xtend then what we are used to. Unlike other languages where the Switch statement really is its own thing, here it is just a shorthand way to write out a bunch of if/else statements. If you have a case that returns a boolean then it should execute that case.
See this from the Time of Day DP:
  switch now {
        case now.isAfter(morning_start) && now.isBefore(day_start):       curr = "MORNING"
        case now.isAfter(day_start) && now.isBefore(afternoon_start):     curr = "DAY"
        case now.isAfter(afternoon_start) && now.isBefore(evening_start): curr = "AFTERNOON"
        case now.isAfter(evening_start) && now.isBefore(night_start):     curr = "EVENING"
        case now.isAfter(night_start):                                    curr = "NIGHT"
        case now.isAfter(bed_start) && now.isBefore(morning_start):       curr = "BED"
And here is the docs: http://www.eclipse.org/xtend/documentation/203_xtend_expressions.html#switch-expression.
So the case receivedCommand == ON, while redundant, should have worked, assuming that the Items are Switch Items. However, I’ve never used a Switch statement with the Enum types (i.e. ON/OFF, OPEN/CLOSED, etc) so there may be something incompatible with the OH Enum types and the Xtend switch statement.
@idkpmiller, you can normalize and eliminate all the possible problems with types by using:
switch receivedCommand.toString {
    case "ON": ...
Convert the command to a String and use a String for all the cases and so long as it is spelled right it will work.
Thanks, i didn’t expect that.
