Switch Rule causes continuous ON/OFF loop
I have a group switch to turn on and off 4 tv’s and also have individual switches for each. when I press the group button all 4 switches go into a continuous loop turning each switch on and off. This also happens to each switch individually when pressed.
Rules:
// Turn TV1 ON/OFF
rule "Power ON LGvTV1 via WOL"
    Item PBATV1Power received command
    if ( receivedCommand == ON )
        sendCommand( PBATV1_WOL, ON )
        logInfo("LG.rules", "TV1 Power ON")
rule "Power OFF LGvTV1 "
    if ( receivedCommand == OFF )
        sendCommand( PBATV1Power, OFF )
        logInfo("LG.rules", "TV1 Power Off")
**** I tried this alternate rule and it does the same thing
// Turn TV2 On/Off rules
rule "Power on LGvTV2 via WOL"
    Item PBATV2Power received command
    if (receivedCommand == ON)
        sendCommand( PBATV2_WOL, ON )
    else
        sendCommand( PBATV2Power, OFF )
        logInfo("LG.rules", "TV2 Power Off")
ITEMS:
Group PBAtv  "PBA-TVS"  <lgtv>
Group:Switch:OR(ON, OFF)  TVs      "All TVs [(%d)]"
Switch   PBATV1Power   "TV1 Power"  (PBAtv, TVs)  {channel="lgwebos:WebOSTV:93d6e248-596d-40b2-bf27-2f93e0c70c1b:power"}
Switch   PBATV2Power   "TV2 Power"  (PBAtv, TVs)  {channel="lgwebos:WebOSTV:c9bd12f1-9313-4903-b117-bb58460250cc:power"}
Switch   PBATV3Power   "TV3 Power"  (PBAtv, TVs)  {channel="lgwebos:WebOSTV:3670e8fa-33e6-45cf-b1de-857ec1d3f7bf:power"}
Switch   PBATV4Power   "TV4 Power"  (PBAtv, TVs)  {channel="lgwebos:WebOSTV:6947719a-7e95-4e3d-b463-a9758d69780d:power"}
Switch   PBATV1_WOL         { wol="192.168.25.255#A8:23:FE:9D:21:46" }
Switch   PBATV2_WOL         { wol="192.168.25.255#A8:23:FE:CC:11:0C" }
Switch   PBATV3_WOL         { wol="192.168.25.255#A8:23:FE:7D:98:DC" }
Switch   PBATV4_WOL         { wol="192.168.25.255#A8:23:FE:C8:85:2E" }
SITEMAP:
	Frame label="LG_TV" {
        Switch item=PBAtv icon="tv" mappings=[OFF="Off", ON="On"]
		Text label="LG TVs" icon="tv" {
           // Group item=TVs label="ALL TVs"
            Frame label="TV-1" {
                Switch item=PBATV1Power
                Switch item=TV1Input label="INPUT" mappings=[0="PC", 1="DVD", 2="HDMI-1",3="HDMI-2",4="HDMI-3"]
            Frame label="TV-2" {
                Switch item=PBATV2Power
                Switch item=TV2Input label="INPUT" mappings=[0="PC", 1="DVD", 2="HDMI-1",3="HDMI-2",4="HDMI-3"]
            Frame label="TV-3" {
                Switch item=PBATV3Power
                Switch item=TV3Input label="INPUT" mappings=[0="PC", 1="DVD", 2="HDMI-1",3="HDMI-2",4="HDMI-3"]
            Frame label="TV-4" {
                Switch item=PBATV4Power
                Switch item=TV4Input label="INPUT" mappings=[0="PC", 1="DVD", 2="HDMI-1",3="HDMI-2",4="HDMI-3"]
EVENTS.LOG
* this is what happens when a single tv switch is pressed:
2019-10-02 15:28:29.600 [ome.event.ItemCommandEvent] - Item 'PBATV1Power' received command OFF
2019-10-02 15:28:29.616 [ome.event.ItemCommandEvent] - Item 'PBATV1Power' received command OFF
2019-10-02 15:28:29.631 [ome.event.ItemCommandEvent] - Item 'PBATV1Power' received command OFF
OPENHAB.LOG
2019-10-02 15:29:12.017 [INFO ] [ipse.smarthome.model.script.LG.rules] - TV1 Power ON
2019-10-02 15:29:12.017 [INFO ] [ipse.smarthome.model.script.LG.rules] - TV1 Power Off
You have two rules that are triggered both on:
So each time that item received a command both are triggered. In the second rule you send a command to that item, so all starts over again.
Could you recommend how to code it. If you could show a nubie :thinking: .
I tried this and it did the same:
    else
In all three examples, you have a Rule that gets triggered when PBATV2Power receives command OFF. Then you immediately sendCommand(OFF) to that same Item, which retriggers the Rule and on and on.
So what are you trying to accomplish? Why the two OFF commands to the same Item? We can’t tell you how do do it when we don’t understand what it is you are trying to accomplish. The Rule makes no sense as written.
As what @rlkoshak said, it’s not clear what you want.
But based on your rule, i would suggest this:
  Item PBATV1Power received command ON
  PABTV1_WOL.sendCommand(ON)
  Item PBATV1Power received command OFF
  PBATV1WOL.sendCommand(OFF )
This way, the rules won’t fire each other. I noticed now that in the first rule you sendCommand to PABTV1_WOL and the second rule you sendCommand to PABTV1POWER. The latler will create the loop.
Wake On Lan to Power Off the TV will not work :wink:
That makes no sense… there is your loop … sendCommand( PBATV1Power, OFF ) triggers the rule in loop
Try it like this … :slight_smile:
rule "Power ON / OFF LGvTV1"
  Item PBATV1_SWITCH received command
  if (receivedCommand == ON) {
  } else if (receivedCommand == OFF) {
Switch   PBATV1_SWITCH "Power Switch for TV PBATV1"
Switch   PBATV1Power   "TV1 Power"   {channel="lgwebos:WebOSTV:93d6e248-596d-40b2-bf27-2f93e0c70c1b:power"}
Switch   PBATV1_WOL    "TV1 WOL"     { wol="192.168.25.255#A8:23:FE:9D:21:46" }
Made the changes and that stopped the looping. The TV’s turn on with the WOL command but they don’t turn OFF, and every time I do a turn On it generates a new UID and puts it in the INBOX. is that the reason it doesn’t respond to the power off command? How can I stop i from creating a new UID every time it wakes up the TVs.
