I run Openhab 2.4 on a Raspbeerry 3 b+, everything is running without any Problems. There is just one annoying thing.
I configured some sonoff switches with paper UI and they work as expected, but on the sitemap in basic UI the switch state is shown on some switches and on some not.
Hers a screenshot from the channels.
It works with the formatter, but at the garage items are no labels, 2 show the state and one not.
That means i should use labels on all items even if i don´t need?
I know that each item has its own label, thats why i didn`t set them up in the sitemap for the garage items, u can see the item labels in my last screenshot. The state is also not NULL or UNDEF, it just dont show the state.
Okay, so none of those Item labels have [format]. To determine, you’d edit label value to Garage 1 [%s] etc.
Which leaves why they show differently by default. PaperUI seems inconsistent about how it shows Items that are defined in files. I get to see some of mine, but not all; but of course they are uneditable being file-based. I guess all yours are created in PaperUI - and you’re sure there are no duplicates in xxx.items files.
I suspect bindings can provide some kind of default format too, but all all your Items seem to b similar bindings, so I’d rule that out.
All items are created in Paper UI, there are no duplicates, checked more than 2 times, and all items are the same binding, MQTT binding.
Ill format the labels to get the reqired result. One day ill figure it out, and it will be like, OH thats why.
I think this area has changed. In the past if you had no [ format ] you got nothing. Now there seems to be some kind of defaulting at work, but not reliably.
