gagagu
(Gagagu)
1
Hi all,
i’ve a small problem with a switch in a sitemap.
sitemap default label=“Alarmanlage”
Text item=Entered_Code label=“Eingabe: [%s]” icon=“none"
Frame label=“Tastatur”{
Switch item=KEYPAD_SW1 label=”" mappings=[1=“1”, 2=“2”, 3=“3”]
Switch item=KEYPAD_SW2 label="" mappings=[4=“4”, 5=“5”, 6=“6”]
Switch item=KEYPAD_SW3 label="" mappings=[7=“7”, 8=“8”, 9=“9”]
Switch item=KEYPAD_SW4 label="" mappings=[CLEAR=“X”, 0=“0”, DELETE="<"]
Switch item=KEYPAD_SW5 label="" mappings=[ON=“On”, HOME=“Home”, OFF=“Off”]
In my rules file i’ve defined a simple rule to test the switch but it doesn’t work at all
var KeypadText=""
rule "Keypad1"
Item KEYPAD_SW1 received update
KeypadText += "bla1"
postUpdate(“Entered_Code”,KeypadText)
Any ideas why it’s nor working? Thx to all
hr3
(Harry)
2
postUpdate(Entered_Cod,KeypadText)
gagagu
(Gagagu)
3
Hi, thx for reply but it still won’t work.
rule "test"
postUpdate(Entered_Code,KeypadText)
hr3
(Harry)
4
I don’t know your item-configuration but consider the quotation marks in your sitemap
sitemap default label="Alarmanlage" {
Text item=Entered_Code label="Eingabe: [%s]" icon="none"
Frame label="Tastatur" {
Switch item=KEYPAD_SW1 label="" mappings=[1="1", 2="2", 3="3"]
Switch item=KEYPAD_SW2 label="" mappings=[4="4", 5="5", 6="6"]
Switch item=KEYPAD_SW3 label="" mappings=[7="7", 8="8", 9="9"]
Switch item=KEYPAD_SW4 label="" mappings=[CLEAR="X", 0="0", DELETE="<"]
Switch item=KEYPAD_SW5 label="" mappings=[ON="On", HOME="Home", OFF="Off"]
