Switching from Docker to Proxmox LXC - Trying to avoid having to set up Homekit again
Hello
as part of my homelab migration to proxmox i am now at the point, where i want to migrate openhab with the openhabian scripts.
It all worked great and now i am at the point where i have to import my config.
I tried importing a OH-generated .zip (actually it was a .tar.gz and i unzipped it and zipped it to .zip) but it failed. So i just copied the files manually (text based setup here).#
I have 4 homekit bridges and copied all 4 corresponding homekit.json files.
The next thing i did was changing the ip adress of the homekit bridge in the .cfg to the new proxmox lxc.
Unfortunately the devices won’t come online. Is there another point where i have to tweak something or is it simply not possible without clearing pairings?
I would just do it but it takes a lot of time having +300 items and i did this so often before …
Thank you kindly
