I started having issues with MySQL Persistence (not creating tables with string data). I decided to switch to the JDBC, if for no other reason than that it can use more meaningful table names.
I removed MySQL persistence, and when I try to install JDBC Persistence MySQL I I get this error in the log:
I tried installing the JDBC MySql on a clean install of 2.4.0. I created a new database in mysql, and granted permissions to the hab user. I’m now getting a long stacktrace in the log, starting with:
2019-10-27 16:58:16.900 [INFO ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: Driver is available::Yank setupDataSource
2019-10-27 16:58:18.087 [ERROR] [org.openhab.persistence.jdbc ] - bundle org.openhab.persistence.jdbc:1.13.0 (215)[org.openhab.persistence.jdbc(225)] : The activate method has thrown an exception
com.zaxxer.hikari.pool.HikariPool$PoolInitializationException: Failed to initialize pool: Could not create connection to database server.
My jbdc.config has url=jdbc:mysql://<myhost>:3306/openhab2 in it, along with the username and password settings for the user. I can connect from mysql workbench using that url with those credentials. I don’t know a way to test the jdbc connection string outside openhab.
MySql is running on the same machine, as a windows service. I placed the file mysql-connector-java-8.0.13.jar in the addons folder.
I’m left wondering if there’s really a connection problem, or if I’ve missed an installation or configuration step.
