Switching on a device through Aeotec ZW130 Wallmote Quad
I’m sure I’m missing here something very simple and basic but this is the situation:
On a OH 2.3 setup I’m trying to switch On and Off a light switch using the association group of an Aeotec ZW130 Quad WallMote and I can’t get it to work.
The light switch is a NeoCoolcam EU-1 Z-Wave switch. It is working perfectly well and I can control it with OH without any problems.
Basically I want to use the WallMote in tandem with the EU-1 switch as a 2-way switch setup to control a single light.
I added the WallMote as a thing and I can see it in the paper UI and HABmin. It is recognized and the buttons light up and vibrates when I press them so I assume that it works correctly.
I didn’t link any channels or created any items for the WallMote because I wanted to use associations.
What I did was set up the WallMote Association group 1 (Lifeline) to the OH controller and association group 2 to the EU-1 switch. I was under the impression that this will enable the WallMote to send an On/Off command to the EU-1 switch directly. The problem is that it doesn’t work and the light doesn’t switch on or off at all.
Anyone has an idea what I’m doing wrong or have a different trick to emulate a 2-way switch using rules and two Z-Wave wall switches?
TIA
Claude
I have this device and just use rules based on the state changes:
	Item m_quad_scene received update
	if (m_quad_scene.state == 1.0) {
		outlet.sendCommand(ON)
		m_quad_scene.postUpdate(1.1)
The post update is just to avoid issues with the wife when she presses the same button multiple times.
We tried to sort this out a while ago with no luck. See here. I was not able to get it to work using associations. At this point, a rule is the way to go as @anonymous.one points out above.
Hi Mark
did you email Aeotec? This seems like the most basic of functionality that should work out of the box.
As I commented in the other thread that mhilbush links to it works for me when controlling a dimmer in direct association mode, but now to controll an on/off swich. The dimmer can be turned on and off (click) and dimmed up and down (Click+hold). on/off switches do not react to any command.
I didn’t. I typically do everything through openHAB rules.
Is this an OH2 or Aeotec issue? Seems like an Aeotec right? I’m happy to drive it with Aeotec Support
