after setup the zwave stick in openhab 2 build 694 my openhab crashed with the following error:
/usr/bin/java: symbol lookup error: /root/openHAB2/userdata/tmp/libNRJavaSerial_HF_root_0/libNRJavaSerial_HF.so: undefined symbol: __fdelt_chk
What I did:
install openhab default (just unzip)
start it (start.sh)
select basic ui (expert ui with same problem)
install zwave addon / binding
add thing and configure the correct device ( /dev/ACM0 )
get error -1 when press save/add
see error on shell, openhab process died
Before I run openhab 1.8.2 with org.openhab.io.habmin-1.7.0-SNAPSHOT.jar and org.openhab.binding.zwave-1.8.2.jar on the same raspberry with zwave and no problems.
I use a Z-Wave ZME_UZB1 Stick
BR,
Manuel
