Hello together,
I have installed openHAB version: 2.4 and added two lamp via an homematic actor (2-channels).
Now I want to switch on both lamps (individual channels) at the same time.
Currently I´m doing:
rule “Switch1”
Item SKUECHE_1_PressShort changed to ON
SA_KUECHE_FENSTER_LAMPE_RECHTS_1_State.sendCommand(ON)
SA_KUECHE_FENSTER_LAMPE_LINKS_2_State.sendCommand(ON)
But here the lamps go on one after each other. Is there a way to switch on the lights at the same time.
Looks currently a little bit funny if the lamps going on with a delay of 1 second.
maybe you try to merge the affected lights into a group (of type switch) and then send the ON command to this group instead of each individual light – I usually do it this way I’m fine with that
